What causes "bootsdcard" to fail? — Parallax Forums
edited 2012-08-29 14:51 in Propeller 1
I've run into a series of unexplainable situations where fsrw's "bootsdcard" routine fails to properly launch another binary.
Can someone give me a idea of what factors would cause this to fail? I thought it had to do with the size of the destination program, but my testing shows this isn't a factor.
From FSRW
pub bootsdcard
   return sdspi.bootsdcard(datablock, filesize <# $8000)
From SDPIFEMTO
pub bootsdcard(addr,count) | t
  if count < 16
    return true
  repeat t from 0 to 7
    if (t <> cogid) and (t <> (cog-1))
        cogstop(t)
  t := iospiboot | iostopldr | cogid
  long[control][1] := count << 16
  long[control][0] := (t << 24) | (addr & $ffffff)
  repeat while long[control][0] & iotestrdy
  return (long[control][0] & iotesterr) <> 0
The solution of "simply switch to Kye's isn't going to work, as I need the memory space.
Any help unraveling this would be appreciated.
  • lonesocklonesock Posts: 917
    edited 2012-08-28 20:51
    Which version of FSRW is this?
    Jonathan
    edited 2012-08-28 21:15
    The only thing that I know of that will cause this to fail is either an SD card hard read error or a program that's bigger than the extent size. The entire program has to fit in a contiguous region on the SD card and the only way to guarantee this is to use an extent size of 32K or greater. Kye's boot routine avoids this problem by providing a table of the start and size of all extents up to 32K total.
    edited 2012-08-28 21:24
    lonesock wrote: »
    Jonathan
    2.6
    edited 2012-08-28 21:25
    Mike Green wrote: »
    So I am to understand that the physical size of the program could be a factor here? The one that fails is currently a 15k binary. Others that work fine are various sizes.
    Jeff
  • AribaAriba Posts: 2,695
    edited 2012-08-28 21:35
    The allocated sectors for the file must be contiguous. For bigger files the chance is higher that this is not the case. Sectors inside a cluster are always contiguous so if you format your SD card with 32kB clusters, you are on the safe side. You can do this from the cmd console in Windows with:
    format X: /fs:fat /a:32k
    X is your drive letter of the SD card.
    Andy
    edited 2012-08-29 06:08
    This code isn't in FSRW 2.6. However, it sounds like it might in the femto code, which I have never used. Maybe the particular file that's causing problems is correupted. Can you read it on a Windows or Linux box?
    @Andy,
    Ah! Allocation Units! Ok.. I've got it.
    That seemed to have been the ticket! Programs which were failing seem to be working correctly. Thank you!
    Jeff
    Ariba wrote: »
    Andy
