SD Card Test (Please test - may be used for boot code for the Prop2) - Page 2 — Parallax Forums
2456
    edited 2012-08-22 08:34
    Thanks for the results. I have not given up - just extremely busy interstate and will be so until the end of the month. Please keep them coming.
    I have only seen one MBR/VBR where data is in the area I want to store the pointer.
    Does anyone have an SDXC that they can post results?
  • pgbpsupgbpsu Posts: 460
    edited 2012-08-22 09:19
    I tried the SDformat program (for mac) as someone suggested, then ran Clock Loop's modified code and I still get garbage. I don't know what's going on but it seems to not like this card.
    p
    edited 2012-08-22 10:44
    pgbpsu wrote: »
    p
    Something in the program is still messed up because I also get garbage at first for about 4 seconds, and then it works.
  • jazzedjazzed Posts: 11,803
    edited 2012-08-22 10:51
    Brand: Unknown
    Type:MicroSD
    Works with windows.
    testing...
    Parameters used...
    00 00 00 FF 00 00 00 FF 00 00 00 FF 00 00 00 FF
    00 00 00 FF 08 AA 00 FF 37 AA 00 FF 29 AA 00 FF
    11 00 00 FF 00 FF 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MBR sector 0...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    edited 2012-08-22 12:47
    WARNING!!!!!!!!!!!!!
    ALL PREVIOUS SD CARD RESULTS ARE INVALID DUE TO BROKEN PASM CODE!!!!
    I found this out by only starting the FULLDUPLEXSERIAL object AFTER the sdroutines in PASM were done.
    Now my SDHC 16gb PNY card reads like this:
    [code]
    Parameters used...
    00 00 01 FF 08 AA 01 FF 37 00 01 FF 29 00 01 FF
    37 00 01 FF 29 00 01 FF 37 00 01 FF 29 00 01 FF
    MBR sector 0...
    FA 33 C0 8E D0 BC 00 7C 8B F4 50 07 50 1F FB FC
    edited 2012-08-22 13:32
    Hi Clock Loop-
    I tried this modified code with my troublesome Panasonic card with no change in result. I also tried it with the Lexar card above and found no difference.
    [code]
    Parameters used...
    00 00 01 FF 08 AA 05 FF 37 AA 01 FF 29 AA 01 FF
    37 AA 01 FF 29 AA 00 FF 11 00 00 FF FE FF 00 00
    MBR sector 0...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 ................
    39 00 06 1F FF DF F5 00 00 00 0B 83 1E 00 00 00 9..
  • Tracy AllenTracy Allen Posts: 6,658
    edited 2012-08-22 13:51
    Clock Loop,
    I too had modified the spin code, first because of the pin assignments, but also
    1) my SD card power is switched by p12 and
    2) I was getting garbage data.
    I too found that there was a weird interaction between the serial port and the SD card test, so I ended up moving the serial port initialization to after the test. Here is how I modified Cluso's spin code, only the first PUB. I'm using BST/Mac, so I left off the long startup delay.
    [SIZE=1][FONT=courier new]pub Main : i | tm
    ' This Spin code is not part of the boot code, it
    ' just starts the PASM cog and shows the result
      dira[12]~~            ' for Tracy only...
      outa[12]~             '  This turns on power to my SD card
      waitcnt(clkfreq/10+cnt)
      bytefill(@done,0,4+512+512)  'clear the buffers
      done[0] := $FF                'set busy
      cognew(@entry, @done)
      repeat until (done[0] == 0)
      dbg.start(31,30,0,9600)
      dbg.str(string("testing...",13))
      DisplayParam
      DisplayMBR
      repeat
    [/FONT][/SIZE]
    On a quick test with one SanDisk 4Gb card, your program (with the appropriate pin assignments) and mine give the same results. But how do you know they are correct?
    edited 2012-08-22 14:14
    pgbpsu wrote: »
    Hi Clock Loop-
    Does it still throw out the GARBAGE? before the mbr result?
    The result you show could be correct, if your mbr really doesn't contain any data. (your result does show some data actually, at the bottom of the mbr)
    You could try to write data to the mbr and see if it shows up. Its possible you don't have a problem with your sd cards?
  • Don MDon M Posts: 1,647
    edited 2012-08-22 14:18
    Brand: Sandisk
    Type:MicroSD
    Works with windows and Prop.
    Parameters used...
    MBR sector 0...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 01  ..............€.
    01 00 06 FE FF FF 3F 00 00 00 84 EF 3A 00 00 00  ...þÿÿ?...„ï:...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA  ..............Uª
    edited 2012-08-22 14:20
    Because you modified the code to fix the sd PASM and fullduplexserial PASM stomping on eachother, before you tested, your results are probably correct. (as correct as can be?)
    Technically the only perfect way to know we are getting good MBR data is to write custom data to our MBR, and then do this read.
    (the program "winimage" allows the modification of MBR data) (CAREFULL, you can seriously screw up your computers mbr with this program)
    Others here used the original code, and most their results show the MBR with all 0 data. (except the very end)
    (it could be correct, but i figured its best to re-test because with my card, before the fix, it showed all 0's in the mbr (except the very end), and then after the PASM fix it showed tons of data in the mbr at the beginning.
    edited 2012-08-22 14:21
    Brand: Unknown. Bought from OBC same as the ones Parallax now sells
    Type:MicroSD
    [code]
    Parameters used...
    37 00 01 FF 29 00 00 FF 3A 00 00 FF 11 00 00 FF
    FE FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MBR sector 0...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 ................
    04 00 06 04 E4 C9 81 00 00 00 7F CF 1D 00 00 00 ....
    edited 2012-08-22 14:25
    Brand: Wintec
    Type:MicroSD
    [code]
    Parameters used...
    37 00 01 FF 29 00 01 FF 37 00 01 FF 29 00 00 FF
    3A 00 00 FF 11 00 00 FF FE FF 00 00 00 00 00 00
    MBR sector 0...
    08 00 06 1F DF BF 85 00 00 00 7B 07 3B 00 00 00 ...߿
    edited 2012-08-22 14:34
    I wrote to my sd cards MBR using winimage.
    I did this by saving the mbr in winimage as mbr.bin file, I then opened it up in NOTEPAD and started typing, I then saved it as is. I then imported it into winimage, writing to the mbr of the sd card.
    Heres the result with the fixed spin program.
    Clusos program as it is now in the first post (he hasn't fixed it yet) will not even push this information to the terminal, it will just throw out garbage due to the pasm stomping.
    It seems that due to variations in the sd card logic speeds, some see the problem, and others do not.
    But rest assured, the sd PASM, and the fullduplexserial PASM are stomping on eachother in the original program.
    Brand:SanDisk
    Type: MicroSD
    Parameters used...
    MBR sector 0...
    49 20 6F 70 65 6E 65 64 20 75 70 20 61 20 74 65  I opened up a te
    78 74 20 66 69 6C 65 20 69 6E 20 6E 6F 74 65 70  xt file in notep
    61 64 20 61 6E 64 20 73 74 61 72 74 65 64 20 74  ad and started t
    79 70 69 6E 67 20 74 65 78 74 2C 20 61 6E 64 20  yping text, and
    74 68 65 6E 20 73 61 76 65 64 20 69 74 20 61 73  then saved it as
    20 61 20 6D 62 72 2E 62 69 6E 20 66 69 6C 65 20   a mbr.bin file
    61 6E 64 20 74 68 65 6E 20 69 6D 70 6F 72 74 65  and then importe
    64 20 69 74 20 69 6E 74 6F 20 74 68 65 20 6D 61  d it into the ma
    73 74 65 72 20 62 6F 6F 74 20 72 65 63 6F 72 64  ster boot record
    20 63 6F 64 65 20 70 72 6F 70 65 72 74 69 65 73   code properties
    20 77 69 6E 64 6F 77 20 69 6E 20 77 69 6E 69 6D   window in winim
    61 67 65 2E 20 20 49 20 72 65 61 6C 6C 79 20 68  age.  I really h
    6F 70 65 20 77 65 20 63 61 6E 20 75 73 65 20 73  ope we can use s
    64 20 63 61 72 64 73 20 74 6F 20 62 6F 6F 74 20  d cards to boot
    74 68 65 20 70 72 6F 70 2E 20 20 20 20 20 20 20  the prop.
    20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
    20 20 20 20 20 20 20 20 00 00 00 00 00 00 80 03          ......€.
    3D 00 06 1F FF D7 F9 00 00 00 07 44 1E 00 00 00  =..ÿ×ù....D....
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA  ............ÿ
    edited 2012-08-22 14:37
    BTW I have no idea what I'm looking for in this data. Is what I posted any good? I am using the latest code that Clock Loop posted on a Prop BOE board.
    edited 2012-08-22 14:41
    Don M wrote: »
    It LOOKs good, there is data at the end of your MBR, but not at the beginning, most SD cards that have original format have nothing in the beginning of the MBR. (but most show some data near the end, like yours.)
    The only way data gets into the MBR of a sd card is if you used a utility with it that wrote data to the mbr. (linux boot, etc...)
    I expect most sd card results here to match yours IF they use my modified program.
    If they use clusos, the beginning of the mbr could possibly show all 0's but really have data in it. (like my 16 gig sdhc pny card did, in my post above)
    edited 2012-08-22 14:43
    I used the SD formatter program from the SD org website on my Mac to format the cards before I used your program. It formats them to FAT16.
    edited 2012-08-22 14:48
    Don M wrote: »
    It looks like anyone who did that, or has original mbr format, ends up with this at the very end of the MBR, while most of the other mbr data is all 0's.
    55 AA
    edited 2012-08-22 15:15
    I used the program winimage to "reset" the mbr of my sd card and heres what now shows up in the mbr.
    [code]
    Parameters used...
    MBR sector 0...
    33 C0 8E D0 BC 00 7C FB 50 07 50 1F FC BE 1B 7C 3
  • SapiehaSapieha Posts: 2,964
    edited 2012-08-22 16:02
    Hi Clock Loop.
    On Image I post You can see what every value near end say to You.
    Look on table on right side of picture
    Clock Loop wrote: »
    [code]
    Parameters used...
    MBR sector 0...
    1024 x 709 - 148K
    edited 2012-08-22 16:17
    Hi Cluso.
    To that You can use mos of BOOT spaces area --- As long You don't will boot from that SC on windows machine. -- Reading else writing to That SD give You never problems.
    Only reserved place are Parameters area
    Cluso99 wrote: »
    edited 2012-08-22 16:22
    Sapieha wrote: »
    Hi Clock Loop.
    Oh right, I suppose this is the best way to verify the MBR data, open up winhex, and compare it to the values output by the spin program.
    If I did that I would have immediately noticed the discrepancy and posted here about it.
    But after fixing the original program, it made me aware that my previous MBR reads with the original broken program cluso posted were bad reads.
    Some of my sd cards worked fine with the code cluso posted, like others here.
    But 3 of my sd cards wouldn't show the result, and only throw garbage at the terminal continuously, which is what made me aware of the program being buggy.
    At first I just added some wait counts, and that helped, it would still initially throw out garbage, but then would show the mbr data.
    Then after figuring out the real problem (main spin code PASM stomping on sub object's PASM (or vice versa), it all cleared up and the garbage problem went away.
    Im still curious, ... I didn't know it was possible for PASM in the main spin file, to interact with PASM in an object that is included in that main spin file.
    But its happening in the original program. Its probably a simple fix, but I understand very little PASM.
    Its also completely possible that I am not even close to what the cause of this problem really is. (i.e. memory stomping) (PASM labels being identical?)
    edited 2012-08-22 19:38
    Sapieha,
    What version of Winhex do you have? I was thinking about buying.
    edited 2012-08-22 20:04
    Sorry guys, I am really busy.
    What is most likely happening are 2 problems..
    1. The card is slow and therefore the busy is being returned for a long time and this is filling up my hub buffer and overruning hubram. It could also occur on large cards. I have no checks, just a buffer of 8K longs. This is the 37 xx xx FF 29 xx 01 FF code repeating. I have not timeout checks, nor overrun checks.
    2. The upper ASCII characters >= $80 should e checked and masked. Some of these may upset PST.
    I did notwant the MBR changed so that I could see what else may be there that we might upset in my method. Seems most either have nothing (all $00) in the boot code, or a small bootloader with the message somthing like not found. We can utilise these without any risk. They all seem to be FAT16 or FAT 32. If the card is raw (no formatting) then it is all $00 with no MBR identifier $55 $AA at the very end. Often you can see partition table data - the last 4 * 16 bytes before the $55 $AA identifier.
    To repeat again, my method does not care what formatting (read file system) is on the card. This way, we can best utilise whatever open file system is devised later to deal with the larger SD cards without falling foul of MS patents. I am sure this will happen, and we will be able to write (without any changes to the ROM) a new boot loader to take care of this. We also can utilise the full encryption of the P2 as well. This is the simplest and safest method possible.
    I posted P1 code that can locate a Boot File within the FAT16/32 filesystem and write this pointer and an Identifier into the MBR boot area. This could be simply modified to copy the direct sector of a boot partition should you wish to utilise this method. It just works simply guys, so why al the fuss.
    I am more concerned to make sure that we have the logic correct to read a few raw sectors from the SD card using the P2 ROM. Just enough to locate a small boot program (or whole P2 program). This can load up a file system, partition system, or nothing but raw access. My method can cater for almost anything, all with minimum ROM usage.
  • pedwardpedward Posts: 1,642
    edited 2012-08-22 21:50
    Here is a dump from mindrobot's (Rick Post) Lexar 2GB card that doesn't work with PropGCC:
    testing..._
    Parameters used...
    MBR sector 0...
    3F 00 06 17 D7 D7 FB 00 00 00 05 7F 3C 00 00 00  ?...???....?<...
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA  ..............U?
    Dump of MBR:
    00000000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000020  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000030  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000040  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000050  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000060  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000070  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000080  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000090  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000a0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000b0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000c0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000d0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000000f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000100  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000110  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000120  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000130  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000140  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000150  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000160  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000170  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000180  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    00000190  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000001a0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000001b0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 03  |................|
    000001c0  3f 00 06 17 d7 d7 fb 00  00 00 05 7f 3c 00 00 00  |?...........<...|
    000001d0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |..............U.|
    edited 2012-08-22 21:53
    Dump from 4GB SanDisk card that *does* work with PropGCC:
    testing..._
    Parameters used...
    MBR sector 0...
    FA 31 C0 8E D8 8E D0 BC 00 7C 89 E6 06 57 8E C0  ?1??????.|??.W??
    FB FC BF 00 06 B9 00 01 F3 A5 EA 1F 06 00 00 52  ???..?..????...R
    52 B4 41 BB AA 55 31 C9 30 F6 F9 CD 13 72 13 81  R?A??U1?0???.r.?
    FB 55 AA 75 0D D1 E9 73 09 66 C7 06 8D 06 B4 42  ?U?u.??s.f?.?.?B
    EB 15 5A B4 08 CD 13 83 E1 3F 51 0F B6 C6 40 F7  ?.Z?.?.???Q.??@?
    E1 52 50 66 31 C0 66 99 E8 66 00 E8 21 01 4D 69  ?RPf1?f??f.?!.Mi
    73 73 69 6E 67 20 6F 70 65 72 61 74 69 6E 67 20  ssing operating
    73 79 73 74 65 6D 2E 0D 0A 66 60 66 31 D2 BB 00  system...f`f1??.
    7C 66 52 66 50 06 53 6A 01 6A 10 89 E6 66 F7 36  |fRfP.Sj.j.??f?6
    F4 7B C0 E4 06 88 E1 88 C5 92 F6 36 F8 7B 88 C6  ?{??.??????6?{??
    08 E1 41 B8 01 02 8A 16 FA 7B CD 13 8D 64 10 66  .?A?..?.?{?.?d.f
    61 C3 E8 C4 FF BE BE 7D BF BE 07 B9 20 00 F3 A5  a??????}??.? .??
    C3 66 60 89 E5 BB BE 07 B9 04 00 31 C0 53 51 F6  ?f`????.?..1?SQ?
    07 80 74 03 40 89 DE 83 C3 10 E2 F3 48 74 5B 79  .?t.@????.??Ht[y
    39 59 5B 8A 47 04 3C 0F 74 06 24 7F 3C 05 75 22  9Y[?G.<.t.$?<.u"
    66 8B 47 08 66 8B 56 14 66 01 D0 66 21 D2 75 03  f?G.f?V.f.?f!?u.
    66 89 C2 E8 AC FF 72 03 E8 B6 FF 66 8B 46 1C E8  f?????r.???f?F.?
    A0 FF 83 C3 10 E2 CC 66 61 C3 E8 62 00 4D 75 6C  ????.??fa??b.Mul
    74 69 70 6C 65 20 61 63 74 69 76 65 20 70 61 72  tiple active par
    74 69 74 69 6F 6E 73 2E 0D 0A 66 8B 44 08 66 03  titions...f?D.f.
    46 1C 66 89 44 08 E8 30 FF 72 13 81 3E FE 7D 55  F.f?D.?0?r.?>?}U
    AA 0F 85 06 FF BC FA 7B 5A 5F 07 FA FF E4 E8 1E  ?.?.???{Z_.????.
    00 4F 70 65 72 61 74 69 6E 67 20 73 79 73 74 65  .Operating syste
    6D 20 6C 6F 61 64 20 65 72 72 6F 72 2E 0D 0A 5E  m load error...^
    AC B4 0E 8A 3E 62 04 B3 07 CD 10 3C 0A 75 F1 CD  ??.?>b.?.?.<.u??
    18 F4 EB FD 00 00 00 00 00 00 00 00 00 00 00 00  .???............
    00 00 00 00 00 00 00 00 EE 13 01 00 00 00 80 02  ........?.....?.
    03 01 0B 30 F0 C0 00 20 00 00 00 0C 76 00 00 00  ...0??. ....v...
    Dump of MBR:
    00000010  fb fc bf 00 06 b9 00 01  f3 a5 ea 1f 06 00 00 52  |...............R|
    00000020  52 b4 41 bb aa 55 31 c9  30 f6 f9 cd 13 72 13 81  |R.A..U1.0....r..|
    00000030  fb 55 aa 75 0d d1 e9 73  09 66 c7 06 8d 06 b4 42  |.U.u...s.f.....B|
    00000040  eb 15 5a b4 08 cd 13 83  e1 3f 51 0f b6 c6 40 f7  |..Z......?Q...@.|
    00000050  e1 52 50 66 31 c0 66 99  e8 66 00 e8 21 01 4d 69  |.RPf1.f..f..!.Mi|
    00000060  73 73 69 6e 67 20 6f 70  65 72 61 74 69 6e 67 20  |ssing operating |
    00000070  73 79 73 74 65 6d 2e 0d  0a 66 60 66 31 d2 bb 00  |system...f`f1...|
    00000080  7c 66 52 66 50 06 53 6a  01 6a 10 89 e6 66 f7 36  ||fRfP.Sj.j...f.6|
    00000090  f4 7b c0 e4 06 88 e1 88  c5 92 f6 36 f8 7b 88 c6  |.{.........6.{..|
    000000a0  08 e1 41 b8 01 02 8a 16  fa 7b cd 13 8d 64 10 66  |..A......{...d.f|
    000000b0  61 c3 e8 c4 ff be be 7d  bf be 07 b9 20 00 f3 a5  |a......}.... ...|
    000000c0  c3 66 60 89 e5 bb be 07  b9 04 00 31 c0 53 51 f6  |.f`........1.SQ.|
    000000d0  07 80 74 03 40 89 de 83  c3 10 e2 f3 48 74 5b 79  |..t.@.......Ht[y|
    000000e0  39 59 5b 8a 47 04 3c 0f  74 06 24 7f 3c 05 75 22  |9Y[.G.<.t.$.<.u"|
    000000f0  66 8b 47 08 66 8b 56 14  66 01 d0 66 21 d2 75 03  |f.G.f.V.f..f!.u.|
    00000100  66 89 c2 e8 ac ff 72 03  e8 b6 ff 66 8b 46 1c e8  |f.....r....f.F..|
    00000110  a0 ff 83 c3 10 e2 cc 66  61 c3 e8 62 00 4d 75 6c  |.......fa..b.Mul|
    00000120  74 69 70 6c 65 20 61 63  74 69 76 65 20 70 61 72  |tiple active par|
    00000130  74 69 74 69 6f 6e 73 2e  0d 0a 66 8b 44 08 66 03  |titions...f.D.f.|
    00000140  46 1c 66 89 44 08 e8 30  ff 72 13 81 3e fe 7d 55  |F.f.D..0.r..>.}U|
    00000150  aa 0f 85 06 ff bc fa 7b  5a 5f 07 fa ff e4 e8 1e  |.......{Z_......|
    00000160  00 4f 70 65 72 61 74 69  6e 67 20 73 79 73 74 65  |.Operating syste|
    00000170  6d 20 6c 6f 61 64 20 65  72 72 6f 72 2e 0d 0a 5e  |m load error...^|
    00000180  ac b4 0e 8a 3e 62 04 b3  07 cd 10 3c 0a 75 f1 cd  |....>b.....<.u..|
    00000190  18 f4 eb fd 00 00 00 00  00 00 00 00 00 00 00 00  |................|
    000001b0  00 00 00 00 00 00 00 00  ee 13 01 00 00 00 80 02  |................|
    000001c0  03 01 0b 30 f0 c0 00 20  00 00 00 0c 76 00 00 00  |...0... ....v...|
  • average joeaverage joe Posts: 795
    edited 2012-08-22 22:35
    PNY optima 2GB
    [code]
    testing...
    Parameters used...
    MBR sector 0...
    0C 00 0B 38 F8 B8 89 00 00 00 77 9F 3A 00 00 00 ...8
    edited 2012-08-23 01:48
    Hi Don.
    http://www.winhex.com/winhex/
    Don M wrote: »
    Sapieha,
    edited 2012-08-23 02:51
    Cluso99 wrote: »
    SO this test was just to see if most sd cards COULD read their MBRS? AND to see if any of the regular formatted sd cards had anything in the mbr?
    It looks like everyones sd cards read fine with the test program, and most mbr's are empty. I like not relying on a specific format or file system to boot the p2. This will allow any p2 developer to even develop their OWN operating system and file system if they choose. And this also allows other file systems like linux ext3 to be utilized if the user so chooses, because the p2 is only looking for mbr data in specific location for boot code. What the developer does from that point on is wide open. Just the way everyone here likes it. FREEDOM!
    I think that the only reason any one would suggest it be tied to a specific file system format, is because they don't understand the nature of the mbr and how it dosen't care what file system you use, the mbr chugs along oblivious to any file system format, making it perfectly suited for modification with pointer code. (exactly how computers work today)
    The p2 is pretty much a computer in a single chip, so it makes sense to adopt mbr booting.
    Perhaps I missing some gotchas? Consider how long computers have been utilizing mbr to boot a plethora of OS's, even today with our modern 64-bit cpus, OS's and super immersive gaming, but yet it all starts with a simple MBR method that was invented decades ago, and hasn't changed at all since, even with our 4ghz, 16gig ram, solid state hard drives, 64-bit cpus, etc... all the wonderful advanced hardware and software, but yet we still rely on the good ol' simple MBR to get it all going.
    This method has worked so well for so long, I am kinda surprised to see opposition to it, and even more surprised to see people saying that the p2 ROM should contain FAT support!!!!!! HELL NO. o.O
    A few of my sd cards had info in the mbr, but thats because i had used those sd cards for bootable utilities, firmware updaters, and mini-linux, and I had to use a special tool to format and write data to those cards.
    It looks like, ALL sd cards so far can read the mbr just fine, and like you said, they all have no data in the mbr. (with original sd format)
    The idea to use the sd mbr as pointer to locate boot code for p2, looks like it will work great! Now let hope it gets implemented.
    (its pretty easy to plop a binary file onto the sd card, and then use a tool to find its start address, then inject that start address into the mbr at pre-defined location.)
    Is this something a new user to the p2 will be able to easily do? No, not at first.
    But then after the guru's here hack on it, they will develop a tool that allows one to automate most of the process, by just supplying the drive letter of the sd card, and the prop2 program to be booted.
    A tool could be developed for different sd formats also.
  • dMajodMajo Posts: 855
    edited 2012-08-23 03:42
    Clock Loop wrote: »
    [code]
    Parameters used...
    MBR sector 0...
    edited 2012-08-23 04:03
    Clock Loop wrote: »
    The same Prop (P1 or P2) can be the tool:
    1) serially upload to prop ram the firmware for this purpose
    2) send the information on what pins the SD is wired
    3) send data to write to SD
