output state not changing
Hello,
I'm having troubles with my code:
When i press buttons 1 to 11, an output will be toggled: ok
When i press the 0 button an half a second, i see the message 'All Off' in the terminal. so the second cog is running, however, the ouputs are not changing.
What i'm doing wrong here?
PUB Main | i 'start cogs cognew(BtnAllOff, @stack[0]) dira[0..15] := %0000_0000_0000_0000 ' P0 -P15 → input (this command is redundant) dira[16..27]:= %1111_1111_1111 ' P16-P27 → output Pause(100) vid.Start(115_200) 'start debug screen 'set first relais on set(16) pause (100) repeat 'check buttons 1..11 repeat i from 1 to 11 if button.ChkBtnPulse(i, 0, 60) toggle(16+i) PUB BtnAllOff | time repeat time := button.ChkBtnHoldTime(0, 0, 60, 500) if time if time==500 AllOff PUB Set(output) outa[output]:=1 vid.str(string("Set Output ")) vid.dec(output) vid.str(string(" ",cr)) PUB Reset(output) outa[output]:=0 vid.str(string("Reset Output ")) vid.dec(output) vid.str(string(" ",cr)) PUB AllOn 'set = ~~ 'reset= ~ outa[16..27]~~ vid.str(string("All On",cr)) PUB AllOff outa[16..27]~ vid.str(string("All Off",cr)) PUB Toggle(output) vid.str(string("Toggle output ")) vid.dec(output) vid.str(string(" ",cr)) !outa[output] PUB pause(ms) | t t := cnt repeat ms waitcnt(t += MS_001)
If one cog sets a pin as high another cog can't change to low.
Edit: Phil bet me to it (again).
Solved with some global vars
