output state not changing
Tumbler
Hello,
I'm having troubles with my code:
When i press buttons 1 to 11, an output will be toggled: ok
When i press the 0 button an half a second, i see the message 'All Off' in the terminal. so the second cog is running, however, the ouputs are not changing.
What i'm doing wrong here?
PUB Main | i
'start cogs
cognew(BtnAllOff, @stack[0])
dira[0..15] := %0000_0000_0000_0000 ' P0 -P15 → input (this command is redundant)
dira[16..27]:= %1111_1111_1111 ' P16-P27 → output
Pause(100)
vid.Start(115_200) 'start debug screen
'set first relais on
set(16)
pause (100)
repeat
'check buttons 1..11
repeat i from 1 to 11
if button.ChkBtnPulse(i, 0, 60)
toggle(16+i)
PUB BtnAllOff | time
repeat
time := button.ChkBtnHoldTime(0, 0, 60, 500)
if time
if time==500
AllOff
PUB Set(output)
outa[output]:=1
vid.str(string("Set Output "))
vid.dec(output)
vid.str(string(" ",cr))
PUB Reset(output)
outa[output]:=0
vid.str(string("Reset Output "))
vid.dec(output)
PUB AllOn
'set = ~~
'reset= ~
outa[16..27]~~
vid.str(string("All On",cr))
PUB AllOff
outa[16..27]~
vid.str(string("All Off",cr))
PUB Toggle(output)
vid.str(string("Toggle output "))
vid.dec(output)
!outa[output]
PUB pause(ms) | t
t := cnt
repeat ms
waitcnt(t += MS_001)
If one cog sets a pin as high another cog can't change to low.
Edit: Phil bet me to it (again).
Solved with some global vars
