Propeller II - Page 21 — Parallax Forums
Propeller II
1181921232445
  • cgraceycgracey Posts: 14,289
    edited 2012-08-14 13:21
    Rayman wrote: »
    I thought the whole reason for this is that I2C eeprom is just too slow for the much larger boot code for Prop2...
    That's right, plus they cost a lot more for the amount of storage you get. Here are the cheapest two 128k x 8 parts from Digikey, of each type:
    I2C (2 pins), 1MHz, "CAT24M01WI-GT3", $0.94/1k units
    SPI, (4 pins), 104MHz, "MX25L1006EMI-10G", $0.37/1k units
  • SapiehaSapieha Posts: 2,964
    edited 2012-08-14 13:28
    Hi Chip.
    I know it is maybe BAD idea
    BUT why not use CUSTOM fuses to have them decide what type and PINS of device them will use as BOOT.
    And have only Serial as default in not preprogrammed Propeller II !!
    edited 2012-08-14 13:34
    Here is an off-the-wall boot question. Could I use one of those cheap AVR-USB chips in place of an FTDI chip and have it act as the serial interface to the P2? The idea would be to then hook some of the AVR pins to the SPI boot pins on the P2 and use the AVR flash as the boot device. The AVR could emulate a SPI flash. That way you wouldn't need the SPI flash boot chip at all if you were going to have a USB2serial interface. Actually, I guess the same thing could be done with P1 but having the AVR emulate an I2C EEPROM.
  • jmgjmg Posts: 15,199
    edited 2012-08-14 13:48
    Sapieha wrote: »
    Hi Chip.
    No, that is a very good idea, provided the fuses are proven enough.
    It should default to on, and a zapped fuse disables that load option, with all zapped (doofus!) perhaps giving SPI ?
    (or, a back to the default ? gives more oops useful silicon, but does allow hacking/tamper attacks..)
    I can see some users would want hacking/tamper protection @ loader, and Serial-load-first has delays and risks...
    Also those who worry about pins-waggling unexpectedly can manage that via the fuses.
    edited 2012-08-14 13:50
    David Betz wrote: »
    Emulating a SPI slave in a AVR is non-trivial - there is no 'wait' handshake, and the Prop will not know the AVR is waiting on Windows...
    edited 2012-08-14 14:08
    jmg wrote: »
    I was actually more thinking that the pseudo SPI flash would read from the AVR flash or SRAM not from the PC but I see your point.
    edited 2012-08-14 14:25
    ...why do you want to reverse the order of d0-d3? I know its only one REV instruction, but why is it needed?
    Because it limits pin creep going downwards. If you have a single-bit SPI flash, a Quad SPI flash, or even two Quad SPI flash chips, they can all boot the same by only using pins 87 (din) and pins 86 (dout) for the data paths in single-bit mode.
    All SPI:
    89 = cs
    88 = clk
    Single SPI:
    87 = din
    86 = dout
    Quad SPI:
    87 = io0/din
    86 = io1/dout
    85 = io2
    84 = io3
    For additional Quad SPI:
    83 = io0
    82 = io1
    81 = io2
    80 = io3
    edited 2012-08-14 14:33
    Sapieha wrote: »
    Hi Chip.
    I'm kind of glad to be getting away from I2C chips, as they are not only slow, but take a ton of code to talk to. Here's from the Prop I loader:
    '* I2C routines for 24x256/512 EEPROM *
    '* assumes fastest RC timing - 20MHz  *
    '*   SCL low time  =  8 inst, >1.6us  *
    '*   SCL high time =  4 inst, >0.8us  *
    '*   SCL period    = 12 inst, >2.4us  *
    ' Begin eeprom read
    ee_read			mov	address,#0		'reset address
    			call	#ee_write		'begin write (sets address)
    			mov	eedata,#$A1		'send read command
    			call	#ee_start
    	if_c		jmp	#shutdown		'if no ack, shutdown
    			mov	count,h8000		'set count to $8000
    ee_read_ret		ret
    ' Begin eeprom write
    ee_write		call	#ee_wait		'wait for ack and begin write
    			mov	eedata,address		'send high address
    			shr	eedata,#8
    			call	#ee_transmit
    			mov	eedata,address		'send low address
    			call	#ee_transmit
    ee_write_ret		ret
    ' Wait for eeprom ack
    ee_wait			mov	count,#400		'	400 attempts > 10ms @20MHz
    :loop			mov	eedata,#$A0		'1	send write command
    			call	#ee_start		'132+
    	if_c		djnz	count,#:loop		'1	if no ack, loop until done
    	if_c		jmp	#shutdown		'	if no ack, shutdown
    ee_wait_ret		ret
    ' Start + transmit
    ee_start		mov	bits,#9			'1	ready 9 start attempts
    :loop			andn	pina,mask_scl		'1(!)	ready scl low
    			or	dira,mask_scl		'1!	scl low
    			nop				'1
    			andn	dira,mask_sda		'1!	sda float
    			call	#delay5			'5
    			or	pina,mask_scl		'1!	scl high
    			nop				'1
    			test	mask_sda,pina	wc	'h?h	sample sda
    	if_nc		djnz	bits,#:loop		'1,2	if sda not high, loop until done
    	if_nc		jmp	#shutdown		'1	if sda still not high, shutdown
    			or	dira,mask_sda		'1!	sda low
    ' Transmit/receive
    ee_transmit		shl	eedata,#1		'1	ready to transmit byte and receive ack
    			or	eedata,#%00000000_1	'1
    			jmp	#ee_tr			'1
    ee_receive		mov	eedata,#%11111111_0	'1	ready to receive byte and transmit ack
    ee_tr			mov	bits,#9			'1	transmit/receive byte and ack
    :loop			test	eedata,#$100	wz	'1	get next sda output state
    			andn	pina,mask_scl		'1!	scl low
    			rcl	eedata,#1		'1	shift in prior sda input state
    			muxz	dira,mask_sda		'1!	sda low/float
    			call	#delay4			'4
    			nop				'1
    			djnz	bits,#:loop		'1,2	if another bit, loop
    			and	eedata,#$FF		'1	isolate byte received
    ee_receive_ret
    ee_transmit_ret
    ee_start_ret		ret				'1	nc=ack
    ' Stop
    ee_stop			mov	bits,#9			'1	ready 9 stop attempts
    :loop			andn	pina,mask_scl		'1!	scl low
    			nop				'1
    			call	#delay5			'5
    			call	#delay3			'3
    			call	#delay4			'4
    ee_jmp	if_nc		jmp	#shutdown		'1	if sda still not high, shutdown
    ee_stop_ret		ret				'1
    ' Cycle delays
    delay5			nop				'1
    delay4			nop				'1
    delay3			nop				'1
    delay2
    delay2_ret
    delay3_ret
    delay4_ret
    delay5_ret		ret				'1
    Compare that to the SPI code in the loader I posted a few pages back. Where we once had mere calls to these I2C routines, we now have minor bit twiddling to do the whole task.
    edited 2012-08-14 14:39
    Sapieha wrote: »
    In that case WHY not stay with small I2C reboot device --- Give only Factory dedicated 4 pins.
    This has pros and cons, and diminishing returns.
    Cheapest-possible i2c come in SOT23 (a plus), but only 256 bytes (64 longs) at 9c@6K
    So you need to bump to a larger i2c, still in SOT23, to just over 20c in the some-thousands column.
    A far larger storage SPI flash part is already under 40c, so you can see the diminishing returns effect.
    Chip has indicated Fuses can manage boot choices, and they give a good solution, but here I would caution that the Fuse handler/reader needs to be proven with confidence, as you really want to avoid a drop-dead situation.
    Some 'safety nets' should be in the SW that checks fuses...eg loader does a sanity-check on fuses, before applying the details.
    edited 2012-08-14 14:46
    Hi Chip.
    It is not as I will have it --- BUT others postuladed simpler solution --- That was my answer
    BUT have You read my post on use CUSTOM fuses du decide what device's will be used with BOOT and what pins them will be connected to ??
    ' Begin eeprom read
                call    #ee_start
    ee_read_ret        ret
                shr    eedata,#8
                call    #ee_transmit
                call    #ee_transmit
    ee_write_ret        ret
    ee_wait_ret        ret
    ' Start + transmit
                nop                '1
                call    #delay5            '5
                nop                '1
    ' Transmit/receive
                or    eedata,#000000_1    '1
                jmp    #ee_tr            '1
    ee_receive        mov    eedata,#111111_0    '1    ready to receive byte and transmit ack
                call    #delay4            '4
                nop                '1
    ee_receive_ret
    ee_transmit_ret
    ' Stop
                nop                '1
                call    #delay5            '5
                call    #delay3            '3
                call    #delay4            '4
    ee_stop_ret        ret                '1
    ' Cycle delays
    delay5            nop                '1
    delay4            nop                '1
    delay3            nop                '1
    delay2
    delay2_ret
    delay3_ret
    delay4_ret
    delay5_ret        ret                '1
    edited 2012-08-14 14:57
    Sapieha wrote: »
    Hi Chip.
    Yes, we could do something like that, but it would be good to minimize risk and, better yet, come up with a plan that is simple, robust, and constant.
    How about trying to boot an SD card after flash fails, using the same pins (someone suggested this, above)? This would not increase the pin footprint at boot-up, and if customers wanted to have both SD and flash, they could put the boot medium on the dedicated pins, and locate the other elsewhere.
    Does anyone know (sorry I haven't discovered this myself), whether there is mutual exclusion between SD and flash SPI commands? If there is separation in commands, we could have a policy of SD 1st / flash 2nd or flash 1st / SD 2nd, or even make it selectable through a fuse bit. Any suggestions on this?
    edited 2012-08-14 15:11
    Hi Chip.
    For them that need update theirs programs in field by customer from SD that is not good as it will be always Flash that override SD bootind
    SD for that need be first in chain
    BUT how if I have other things connected to pins BOOT scan for its devices --- And disturb them ??
    Ps. Not mention That that can simplify for designers placement of components !!
    edited 2012-08-14 15:23
    Blowing fuses makes me nervous because it is a one-way proposition. I guess not a big deal for mass production applications, though.
    edited 2012-08-14 15:27
    Hi Invent-O-Doc
    Even for mass production You need program Flash to every entity
    edited 2012-08-14 15:30
    Hi Chip..
    OK --- Maybe other solution.
    Use one fuse that instruct BOOT loader to override its standards and use preprogrammed in fuses.
    edited 2012-08-14 15:33
    You could put the fuse settings in one of those 9-cent EEPROMS that jmg mentioned and use a separate programming protocol for setting them.
    edited 2012-08-14 15:51
    Some vendors bond two die into one package. I wonder if a smallest-die EEPROM would fit ?
    If the Prop 2 Fuses work 100%, (and cost less than 9c to implement) then they are a good option.
    Only minus is the OTP nature, tho for some security/ID options, that is a plus.
    edited 2012-08-14 16:14
    HOW ABOUT THIS?
    pin 91 = Serial RX
    pin 90 = Serial TX
    pin 89 = SPI CS
    pin 88 = SPI CLK
    pin 87 = SPI DI
    pin 86 = SPI DO
    *** THAT'S IT ***
    Boot sequence:
    1) Serial
    2) SPI SD
    3) SPI Flash
    ...And maybe a fuse bit could optionally reorder #2 and #3.
    This way, booter pin use is tightly limited and if you wanted BOTH flash and SD, you could relocate the non-booting one's CS to another pin.
    How would this be?
    edited 2012-08-14 16:28
    Boot sequence:
    1) Serial
    2) SPI SD
    3) SPI Flash
    How would this be?
    I can see that some would want to skip #1, as it has a time cost, and an attack risk.
    #2 would also have some risks - if there is a flash connected, that somehow triggers on a SD load, you are dead.
    So the least-reliable boot I think should be last, and all 3 should have options to skip.
    Default shipping would be all enabled ( I would do Serial/Flash/SD), and users could flip off.
    An all-off case would need to default to something other than nothing. - I'd choose SPI Flash, as that can always re-enable serial.
    What happens on boot failure ? A POST LED ?
  • RaymanRayman Posts: 15,980
    edited 2012-08-14 16:33
    I think I agree with jmg that SD should be last (especially in case it doesn't wind up working right...)
    Also, I think I'd try to make the serial more forgiving that Prop I... People seem to often have trouble connecting...
  • SRLMSRLM Posts: 5,045
    edited 2012-08-14 16:35
    Somebody mentioned it earlier, but it would be nice if the boot sequence supported booting via wireless devices. Apparently it doesn't work on the Prop1 because of timing difficulties? I don't have a source for that. The closest (and only?) thing that we have for the Prop 1 is the Wixels: http://forums.parallax.com/showthread.php?139534-Wireless-Programming-of-a-Propeller-chip-(video)
    edited 2012-08-14 16:40
    Rayman wrote: »
    I put SD in the middle just for this reason. If it doesn't work right, your P2 powered widget can fail gracefully rather than just let the user keep resetting it with a bad SD.
    edited 2012-08-14 16:47
    There's ONE thing you guys might not be considering:
    Everything is authenticated by SHA-256 HMAC before it is allowed to run. This way, there is no way anyone can slip in any unauthorized code, since it must be signed using the secret 128 fuse bits dedicated to this purpose. So, all that matters is the boot *sequence*, not what boots are attempted. If any authentic code is found on any medium, YOU put it there.
    edited 2012-08-14 16:49
    HOW ABOUT THIS?
    pin 91 = Serial RX
    pin 90 = Serial TX
    pin 89 = SPI CS
    pin 88 = SPI CLK
    pin 87 = SPI DI
    pin 86 = SPI DO
    *** THAT'S IT ***
    How would this be?
    Don't forget you need to define the QuadSPI pins, and at least internal Pull-Up-Resistor/ Light drive Hi the unused D1..D3 during Boot preamble, in order to KNOW you have placed any QuadSPI device, into 1 bit mode for the Boot process, from any reset action. (as you mentioned before)
    Boot is one-bit, but the connected Flash Chip may not be ( and is less likely to be 1 bit over time).
    A small stub loader would slip into 4 bit mode, and likely all Eval Boards / ref designs would do this, but that code is in Flash, not ROM.
    This allows coverage of OctalSPI ** and even DDR spi, for those that want it.
    ** an OctalSPI user would have to do their own Reset preamble on the upper nibble device, prior to read.
    edited 2012-08-14 16:57
    Hi Chip.
    Looks good for BOOT ---
    BUT not for reusing Flash and SD in other systems activities to its full capablitys
    If You need have SPI for boot on this pins
    pin 89 = SPI CS
    pin 88 = SPI CLK
    pin 87 = SPI DI
    pin 86 = SPI DO
    so with fuse swap it need have at least fuse to add one more pin group to possibility to run SD from other pins that this ones.
    I know You will made it simple --- BUT I think that usability counts to.
    HOW ABOUT THIS?
    pin 91 = Serial RX
    pin 90 = Serial TX
    pin 89 = SPI CS
    pin 88 = SPI CLK
    pin 87 = SPI DI
    pin 86 = SPI DO
    *** THAT'S IT ***
    Boot sequence:
    1) Serial
    2) SPI SD
    3) SPI Flash
    How would this be?
    edited 2012-08-14 17:00
    mindrobots wrote: »
    If you want "fail gracefully " you must have SPI flash installed, and then your 2) SPI Flash can 'short-boot' skip to SD read, and so you get the best of both worlds.
    I guess you can either call the default ROM SD loader, if that works for you, or have your own, revisable, in the SPI flash.
    jmg wrote: »
    The saving grace with all SPI parts is that commands are sent on DI (io0), only, regardless of 1-, 2-, or 4-bit modes. So, you needn't worry about pulling the initially-unused pins high. You WOULD want to pull any other flash's DI(io0) high, though, if it was sharing the CS and CLK pins with the booting device.
    edited 2012-08-14 17:02
    I think you do need to pull D2 and D3 high because they are /WE and /HOLD when in single bit mode. The /HOLD will be a problem if it happens to float low won't it?
    edited 2012-08-14 17:06
    David Betz wrote: »
    It doesn't have to be. Those SPI flash's have a non-volatile config bit which causes those /WE and /HOLD pins to be ignored. When programming the flash chip, the loader doing the programming would set this bit for you (while driving /WE and /HOLD high), along with loading the code into the device. It won't matter after that, as those /WE and /HOLD pins will be don't-care.
    edited 2012-08-14 17:09
    Have you confirmed that in tests, as that is not what the data sheets I have here say ?
    (Add: Also as #632 says, those pins are /WE /HOLD in 1 bit mode and are now connected to Prop Pins )
    QuadSPI is designed for speed, so some modes are 'sticky'.
    Yes, a cold reset is to 1 bit mode, but a user may be in a Quad mode when a reset arrives.....
