Font Editor (preview #5) - Page 2 — Parallax Forums
24
    edited 2012-08-10 23:11
    Ok, making some progress here. I've got the vb.net program writing Spin programs. It works for any font. I've been working on squeezing fonts into 1 byte per line as that halves the size of the font files compared with one word per line. The way it works out is that 16 point fonts fit in this size if they are fixed width fonts. So I've done Courier New in 16 point and the Parallax font in 16 point. I also experimented with variable width fonts. The widest character is generally the "@", and sometimes the %. Arial Narrow at 15 point is the largest one that fits. Times is getting a bit illegible in this size but works fine if you have one word per line. In the zip is an example of the DAT section only for Times 18.
    And the nice thing about storing fonts in this format is you can see the font, and hence you can edit it easily. If anyone wants me to process some other fonts let me know. To process a file start with http://www.angelcode.com/products/bmfont/ Turn off aliasing and if you look at the visualise window and zoom in you can count the pixels and get a feel for the width and height.
    Then run it through a vb.net program to write the spin code. This loads the output from the bmfont program
        Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
            Dim Filepath, Sourcefile, DestinationFile, pngfile As String
            Filepath = TextBox2.Text ' directory
            OpenFileDialog1.Multiselect = False
            OpenFileDialog1.InitialDirectory = Filepath
            OpenFileDialog1.FileName = "*.fnt" ' select .fnt file.
            OpenFileDialog1.ShowDialog() ' open the openfile dialog
            Sourcefile = OpenFileDialog1.FileName ' get the filename
            Sourcefile = Strings.Mid(Sourcefile, Strings.Len(Filepath) + 2) ' strip off directory
            pngfile = Strings.Left(Sourcefile, Strings.Len(Sourcefile) - 4) + "_0.png"
            Dim img As Image
            Dim fs As New FileStream(Filepath + "\" + pngfile, IO.FileMode.Open) ' open the picture
            img = Image.FromStream(fs) ' load in the file
            fs.Close() ' close the picture
            PictureBox3.Image = img ' display the picture
            RichTextBox1.LoadFile(Filepath + "\" + Sourcefile, RichTextBoxStreamType.PlainText)
            TextBox3.Text = Sourcefile
            TextBox4.Text = Strings.Left(Sourcefile, Strings.Len(Sourcefile) - 4) + ".ifn"
            TextBox5.Text = Strings.Left(Sourcefile, Strings.Len(Sourcefile) - 4) + ".spin"
        End Sub
    and this produces the spin code
      Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
            Dim SpinProgram(10000) As String
            Dim Ascii, x, y, i, j, Width, Height, Xoffset, Yoffset, Xadvance, Fontvalue, Base As Long
            Dim Mycolor As Color
            Dim MyBitmap As New System.Drawing.Bitmap(PictureBox3.Image) 'image from picture box
            Dim LineOfText As String
            Dim FontHeight As Byte
            Dim Counter As Long = 0
            Dim start1, start2, finish1, finish2, loopstep1, loopstep2 As Long
            Dim FontString, Destinationfile As String
            Dim ByteWord As String = "Word" ' if font is narrow 1 to 8 pixels wide, use "Byte" otherwise use Word
            If CheckBox1.Checked = True Then ByteWord = "Byte" ' small fonts
            AddSpinline(SpinProgram, Counter, "CON")
            AddSpinline(SpinProgram, Counter, "  _clkmode      = xtal1 + pll16x                        ' use crystal x 16    ")
            AddSpinline(SpinProgram, Counter, "  _xinfreq      = 5_000_000")
            AddSpinline(SpinProgram, Counter, "VAR")
            AddSpinline(SpinProgram, Counter, "byte FontHeight")
            AddSpinline(SpinProgram, Counter, "word CursorX")
            AddSpinline(SpinProgram, Counter, "word CursorY")
            AddSpinline(SpinProgram, Counter, "OBJ")
            AddSpinline(SpinProgram, Counter, "tch:           " + Strings.Chr(34) + "Touch" + Strings.Chr(34) + "                                 ' touchscreen driver    ")
            AddSpinline(SpinProgram, Counter, "PUB Main | i,f ' debug value")
            AddSpinline(SpinProgram, Counter, "  tch.BeginProgram")
            AddSpinline(SpinProgram, Counter, "  tch.Clearscreen($FFFF)                           ' clear the screen to white")
            AddSpinline(SpinProgram, Counter, "  CursorX := 0")
            AddSpinline(SpinProgram, Counter, "  CursorY := 0")
            AddSpinline(SpinProgram, Counter, "  FontHeight := FontBitmap[0]")
            AddSpinline(SpinProgram, Counter, "  PrintString(string(" + Strings.Chr(34) + "Hello World" + Strings.Chr(34) + "))")
            AddSpinline(SpinProgram, Counter, vbCrLf)
            AddSpinline(SpinProgram, Counter, "PUB PrintString(stringptr)                              ' print a string on the screen")
            AddSpinline(SpinProgram, Counter, "    repeat strsize(stringptr)")
            AddSpinline(SpinProgram, Counter, "      Text(byte[stringptr++])")
            AddSpinline(SpinProgram, Counter, "PUB Text(Ascii) | w,i,row,f")
            AddSpinline(SpinProgram, Counter, "    i := 2 + (Ascii - 32)* (FontHeight+1)               ' fontheight + 1 as there is the xadvance byte")
            AddSpinline(SpinProgram, Counter, "    w := FontBitmap[i]                                  ' xadvance for this character")
            AddSpinline(SpinProgram, Counter, "    tch.Draw(CursorX,CursorY,CursorX+w-1,CursorY+FontHeight-1) ' set up drawing location")
            AddSpinline(SpinProgram, Counter, "    i += 1                                              ' increment pointer")
            AddSpinline(SpinProgram, Counter, "    repeat row from 1 to FontHeight")
            AddSpinline(SpinProgram, Counter, "      f := FontBitmap[i]                                ' get row of pixels")
            AddSpinline(SpinProgram, Counter, "      repeat w")
            AddSpinline(SpinProgram, Counter, "        if f & %10000000                                ' change this if using words")
            AddSpinline(SpinProgram, Counter, "          tch.pixel($0000)                              ' black")
            AddSpinline(SpinProgram, Counter, "        else")
            AddSpinline(SpinProgram, Counter, "          tch.pixel($FFFF)                              ' white background")
            AddSpinline(SpinProgram, Counter, "        f := f << 1                                     ' bitshift")
            AddSpinline(SpinProgram, Counter, "    CursorX += w                                        ' move cursor by this character width")
            AddSpinline(SpinProgram, Counter, "    If CursorX > 230                                    ' end of the line")
            AddSpinline(SpinProgram, Counter, "      CursorY += FontHeight                             ' move down a line")
            AddSpinline(SpinProgram, Counter, "DAT")
            AddSpinline(SpinProgram, Counter, "  FontBitmap")
            For Each Line As String In RichTextBox1.Lines ' much faster than for i=0 to richtextbox1.lines.length
                LineOfText = Line
                If Strings.Left(LineOfText, 6) = "common" Then
                    FontHeight = Strings.Val(Strings.Mid(LineOfText, 19, 2))
                    Base = Strings.Val(Strings.Mid(LineOfText, 27, 2)) ' base is a better measure of height
                    AddSpinline(SpinProgram, Counter, "Byte " + Strings.Str(FontHeight) + " ' font height")
                    AddSpinline(SpinProgram, Counter, "Byte " + Strings.Str(Base) + " ' base")
                End If
                If Strings.Left(LineOfText, 7) = "char id" Then
                    'char id=32   x=96    y=21    width=1     height=1     xoffset=0     yoffset=23    xadvance=7     page=0  chnl=15
                    Ascii = Strings.Val(Strings.Mid(LineOfText, 9, 3)) ' sub 17
                    x = Strings.Val(Strings.Mid(LineOfText, 16, 3))
                    y = Strings.Val(Strings.Mid(LineOfText, 24, 3))
                    Width = Strings.Val(Strings.Mid(LineOfText, 36, 3))
                    Height = Strings.Val(Strings.Mid(LineOfText, 49, 3))
                    Xoffset = Strings.Val(Strings.Mid(LineOfText, 63, 3))
                    Yoffset = Strings.Val(Strings.Mid(LineOfText, 77, 3))
                    Xadvance = Strings.Val(Strings.Mid(LineOfText, 92, 3))
                    start1 = y ' outside loop
                    start2 = x ' inside loop
                    finish1 = y + Height - 1
                    finish2 = x + Width - 1
                    loopstep1 = 1 ' add 1 to each step
                    loopstep2 = 1
                    If Width > 8 And ByteWord = "Byte" Then
                        MsgBox("Ascii '" + Strings.Chr(Ascii) + "' too wide to fit in a Byte, use Words instead")
                        Exit Sub
                    End If
                    AddSpinline(SpinProgram, Counter, "' character " + Strings.Str(Ascii) + " " + Strings.Chr(Ascii))
                    AddSpinline(SpinProgram, Counter, "Byte " + Strings.Str(Xadvance) + " ' xadvance")
                    ' add in lines with no pixels so all characters the same height
                    For i = 1 To Yoffset
                        If ByteWord = "Byte" Then
                            AddSpinline(SpinProgram, Counter, ByteWord + " %00000000")
                        Else
                            AddSpinline(SpinProgram, Counter, ByteWord + " %0000000000000000")
                        End If
                    Next
                    For j = start1 To finish1 Step loopstep1
                        FontString = "" ' now add in the font data
                        For i = 1 To Xoffset
                            FontString += "0" ' add leading spaces if any
                        Next
                        For i = start2 To finish2 Step loopstep2
                            Mycolor = MyBitmap.GetPixel(i, j) ' get the color
                            Fontvalue = Mycolor.R ' grayscale so RGB should be the same
                            If Fontvalue > 128 Then
                                FontString += "1"
                            Else
                                FontString += "0"
                            End If
                        Next
                        FontString = Strings.Left(FontString + "0000000000000000", 16) ' pad with zeros
                            FontString = Strings.Left(FontString, 8) ' only 8 wide if using bytes
                        End If
                        FontString = ByteWord + " %" + FontString
                        AddSpinline(SpinProgram, Counter, FontString)
                    Next
                    ' add in lines at the bottom
                    For i = 1 To FontHeight - (Height + Yoffset)
                        Else
                        End If
                    Next i
                End If
            Next
            Destinationfile = TextBox2.Text + "\" + TextBox5.Text
            FileOpen(1, Destinationfile, OpenMode.Output)
            For i = 0 To Counter
                Print(1, SpinProgram(i) + vbCrLf) ' send to disk
            Next
            FileClose(1)
        End Sub
        Private Sub AddSpinline(ByVal Spinprogram() As String, ByRef Counter As Long, ByVal LineOfText As String)
            ' use byref to return counter to the calling program
            Spinprogram(Counter) = LineOfText
            Counter += 1
        End Sub
    I have attached the three spin files as an example. Also an example of what it would look like with words - just the DAT section for Times Roman 18 point.
    Example Hello World in Arial Narrow 15 point
    CON
    VAR
    byte FontHeight
    word CursorX
    word CursorY
    OBJ
    tch:           "Touch"                                 ' touchscreen driver
      tch.BeginProgram
      CursorX := 0
      CursorY := 0
      PrintString(string("Hello World"))
          repeat w
            else
          CursorX := 0
    DAT
      FontBitmap
    Byte  15 ' font height
    Byte  12 ' base
    ' character  32
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  33 !
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  34 "
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10100000
    Byte %10100000
    Byte %10100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  35 #
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01010000
    Byte %01010000
    Byte %11111000
    Byte %01010000
    Byte %10100000
    Byte %11111000
    Byte %10100000
    Byte %10100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  36 $
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %01110000
    Byte %10101000
    Byte %10100000
    Byte %01110000
    Byte %00101000
    Byte %00101000
    Byte %10101000
    Byte %01110000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    ' character  37 %
    Byte  8 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000100
    Byte %10101000
    Byte %10101000
    Byte %01010000
    Byte %00010100
    Byte %00011010
    Byte %00101010
    Byte %00100100
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  38 &
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %01010000
    Byte %01010000
    Byte %00100000
    Byte %11101000
    Byte %10011000
    Byte %10011000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  39 '
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  40 (
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %01000000
    Byte %00000000
    ' character  41 )
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %10000000
    Byte %00000000
    ' character  42 *
    Byte  4 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %11100000
    Byte %01000000
    Byte %10100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  43 +
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %00100000
    Byte %11111000
    Byte %00100000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  44 ,
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %01000000
    Byte %10000000
    Byte %00000000
    ' character  45 -
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  46 .
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  47 /
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %01000000
    Byte %01000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  48 0
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  49 1
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %01100000
    Byte %10100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  50 2
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %00010000
    Byte %00010000
    Byte %00100000
    Byte %01000000
    Byte %10000000
    Byte %11110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  51 3
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %00010000
    Byte %01100000
    Byte %00010000
    Byte %00010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  52 4
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00010000
    Byte %00110000
    Byte %01010000
    Byte %01010000
    Byte %10010000
    Byte %11111000
    Byte %00010000
    Byte %00010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  53 5
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01110000
    Byte %01000000
    Byte %10000000
    Byte %11100000
    Byte %00010000
    Byte %00010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  54 6
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10000000
    Byte %10100000
    Byte %11010000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  55 7
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11110000
    Byte %00010000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  56 8
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  57 9
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10010000
    Byte %10110000
    Byte %01010000
    Byte %00010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  58 :
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  59 ;
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %01000000
    Byte %10000000
    Byte %00000000
    ' character  60 <
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00010000
    Byte %01100000
    Byte %10000000
    Byte %01100000
    Byte %00010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  61 =
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11110000
    Byte %00000000
    Byte %11110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  62 >
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %01100000
    Byte %00010000
    Byte %01100000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  63 ?
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %00010000
    Byte %00100000
    Byte %01000000
    Byte %01000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  64 @
    Byte  9 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00011100
    Byte %00100010
    Byte %01011011
    Byte %10100101
    Byte %10100101
    Byte %10100101
    Byte %10100101
    Byte %10011110
    Byte %01000001
    Byte %00100010
    Byte %00011100
    ' character  65 A
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00100000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %01110000
    Byte %10001000
    Byte %10001000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  66 B
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11110000
    Byte %10001000
    Byte %10001000
    Byte %11110000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %11110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  67 C
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00111000
    Byte %01000100
    Byte %10000100
    Byte %10000000
    Byte %10000000
    Byte %10000100
    Byte %01000100
    Byte %00111000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  68 D
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11100000
    Byte %10010000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %10010000
    Byte %11100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  69 E
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11111000
    Byte %10000000
    Byte %10000000
    Byte %11111000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %11111000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  70 F
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01111000
    Byte %01000000
    Byte %01000000
    Byte %01110000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  71 G
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00111000
    Byte %01000100
    Byte %10000100
    Byte %10000000
    Byte %10011100
    Byte %10000100
    Byte %01000100
    Byte %00111000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  72 H
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %11111000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  73 I
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  74 J
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00010000
    Byte %00010000
    Byte %00010000
    Byte %00010000
    Byte %00010000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  75 K
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %10010000
    Byte %10100000
    Byte %11100000
    Byte %10100000
    Byte %10010000
    Byte %10010000
    Byte %10001000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  76 L
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %11110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  77 M
    Byte  8 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000010
    Byte %11000110
    Byte %11000110
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10010010
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  78 N
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000100
    Byte %11000100
    Byte %10100100
    Byte %10100100
    Byte %10010100
    Byte %10010100
    Byte %10001100
    Byte %10000100
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  79 O
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00110000
    Byte %01001000
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %01001000
    Byte %00110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  80 P
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11110000
    Byte %10001000
    Byte %10001000
    Byte %10001000
    Byte %11110000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  81 Q
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00110000
    Byte %01001000
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %01011000
    Byte %00110100
    Byte %00000100
    Byte %00000000
    Byte %00000000
    ' character  82 R
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01111000
    Byte %01000100
    Byte %01000100
    Byte %01111000
    Byte %01010000
    Byte %01001000
    Byte %01000100
    Byte %01000010
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  83 S
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01110000
    Byte %10001000
    Byte %10000000
    Byte %01110000
    Byte %00001000
    Byte %10001000
    Byte %10001000
    Byte %01110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  84 T
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11111000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  85 U
    Byte  7 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %10000100
    Byte %01001000
    Byte %00110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  86 V
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %10001000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  87 W
    Byte  8 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10010010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %01000100
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  88 X
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000100
    Byte %01001000
    Byte %01001000
    Byte %00110000
    Byte %00110000
    Byte %01001000
    Byte %01001000
    Byte %10000100
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  89 Y
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %01010000
    Byte %01010000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  90 Z
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11111000
    Byte %00001000
    Byte %00010000
    Byte %00100000
    Byte %00100000
    Byte %01000000
    Byte %10000000
    Byte %11111000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  91 [
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %11000000
    Byte %00000000
    ' character  92 \
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00100000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  93 ]
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %11000000
    Byte %00000000
    ' character  94 ^
    Byte  4 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %10100000
    Byte %10100000
    Byte %10100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  95 _
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11111000
    Byte %00000000
    Byte %00000000
    ' character  96 `
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  97 a
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11100000
    Byte %00010000
    Byte %01110000
    Byte %10010000
    Byte %10010000
    Byte %01110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  98 b
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10100000
    Byte %11010000
    Byte %10010000
    Byte %10010000
    Byte %11010000
    Byte %10100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  99 c
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10000000
    Byte %10000000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  100 d
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00010000
    Byte %00010000
    Byte %01010000
    Byte %10110000
    Byte %10010000
    Byte %10010000
    Byte %10110000
    Byte %01010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  101 e
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %11110000
    Byte %10000000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  102 f
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %01000000
    Byte %11100000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  103 g
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01010000
    Byte %10110000
    Byte %10010000
    Byte %10010000
    Byte %10110000
    Byte %01010000
    Byte %00010000
    Byte %11100000
    Byte %00000000
    ' character  104 h
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10100000
    Byte %11010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  105 i
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  106 j
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %00000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %11000000
    Byte %00000000
    ' character  107 k
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10010000
    Byte %10100000
    Byte %11000000
    Byte %10100000
    Byte %10010000
    Byte %10010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  108 l
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  109 m
    Byte  8 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10100110
    Byte %11011010
    Byte %10010010
    Byte %10010010
    Byte %10010010
    Byte %10010010
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  110 n
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10100000
    Byte %11010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  111 o
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  112 p
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10100000
    Byte %11010000
    Byte %10010000
    Byte %10010000
    Byte %11010000
    Byte %10100000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    ' character  113 q
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01010000
    Byte %10110000
    Byte %10010000
    Byte %10010000
    Byte %10110000
    Byte %01010000
    Byte %00010000
    Byte %00010000
    Byte %00000000
    ' character  114 r
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10100000
    Byte %11000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  115 s
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11100000
    Byte %10010000
    Byte %01000000
    Byte %00100000
    Byte %10010000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  116 t
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01000000
    Byte %01000000
    Byte %11100000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  117 u
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10010000
    Byte %10110000
    Byte %01010000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  118 v
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %10001000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %00100000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  119 w
    Byte  8 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10010010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %10101010
    Byte %01000100
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  120 x
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %01010000
    Byte %00100000
    Byte %00100000
    Byte %01010000
    Byte %10001000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  121 y
    Byte  6 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10001000
    Byte %01010000
    Byte %01010000
    Byte %01010000
    Byte %00100000
    Byte %00100000
    Byte %00100000
    Byte %01000000
    Byte %00000000
    ' character  122 z
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11110000
    Byte %00010000
    Byte %00100000
    Byte %01000000
    Byte %10000000
    Byte %11110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    ' character  123 {
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %01100000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %10000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00100000
    Byte %00000000
    ' character  124 |
    Byte  2 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %10000000
    Byte %00000000
    ' character  125 }
    Byte  3 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %00100000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %01000000
    Byte %11000000
    Byte %00000000
    ' character  126 ~
    Byte  5 ' xadvance
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %11101000
    Byte %10110000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    Byte %00000000
    800 x 600 - 70K
  • RaymanRayman Posts: 15,898
    edited 2012-08-11 03:29
    Personally, I prefer the binary file so that the font is only 3 lines of code in the main program and not hundreds of lines...
    That format is nice to see the font, but I started this thread to show work and get ideas on my font editor that lets you visualize the font, create it, and edit it.
    But, I'll provide text output options for Spin and C for cases where you'd rather have the font that way...
    Guess the downside the binary format is that it doesn't include any info on height, width, etc....
    Perhaps we need an optional 8 (or so) byte header that describes the font.
    That way, the code can automatically know the font type and it can be imported back into the editor easily...
    Think it needs: height, width, bpp, start char, end char, type (fixed, variable, etc).
    Maybe make it 12 bytes with the first 4 bytes equalling "Font" for easy recognition...
  • jmgjmg Posts: 15,198
    edited 2012-08-11 04:16
    Rayman wrote: »
    but you can include a file, so why does how many lines that file has, matter ?
    and also ASM ? (as then you can create a combination of Fonts into a Font ROM image )
    Rayman wrote: »
    Here you uncover the reason few use Binary files, unless they really have to.
    They do not self-document, and so you need to store/archive/post TWO lots of information, the Binary file and then also the record format.
    Since this font info is going thru a tool-chain step I don' t quite see that you are forced to use Binary ?
    More useful to me, is an ASCII-round-trip ability - ie to Load/Edit/Save of a simple ASCII format, that can be handled by other scripts.
    edited 2012-08-11 04:47
    These are good points. I just don't want to clutter up my main program with hundreds of lines of code that are just the font...
    Maybe there's a way to make a font object file so that the text could go there...
    I'm not sure what you mean by "ASM" Do you mean Propeller assembly?
    BTW: In spin, you can include binary files, but not text files (at least, with the Prop Tool).
    Here's what I'm thinking of for text export options (Am I missing anything?):
    481 x 521 - 29K
    edited 2012-08-11 18:19
    Rayman wrote: »
    There do seem to be solutions now to this, and surely such a shortcoming will quickly be fixed ?
    http://forums.parallax.com/showthread.php?95031-PreSpin-a-Preprocessor-for-Spin&p=655470#post655470
    I see #include is top of the list here
    http://propeller.wikispaces.com/Propeller+Tool+-+Enhancement+Requests
    Both Prop PASM, and more general ASM, as options - the more general ASM is useful for creating SPI Flash images.
    All the std assemblers I know support ; as comment, and DB as DataByte, so those are the only two syntax elements needed, and I have found some ASMs do not like very long lines.
    I can see a Prop-case where it might be useful to have the Widths in a table before the Chars ?
    (that would allow a quick-sum to find the char start )
    With an index, you need to define size and byte order.
    24 bits seems std for SPI flash up to 128MBit, but you also need a means to merge multiple fonts into that SPI flash pgm file.
    (which is where the General ASM support helps ).
    I'll check some ASMs, for larger Font handling, - NASM looks like a good candidate, small enough, (single EXE and < 1MB download), and supported on many OS's.
    http://www.nasm.us/
    NASM looks to create BIN or Intel Hex etc files, and allows includes.
    Not sure about 24 bit DB - but 8/16/32/64 are all there - simplest is DD LabelName for 32 bit, little endian index.
    edited 2012-08-11 18:48
    All good points.
    I suppose one big decision is whether you are going to have an SD card available. If yes, then it makes sense to put the font on the SD card as a file, in which case the file can be a lot larger. But the downside is you need SD driver code, which can take up 1/3 of hub ram. On the other hand, if you didn't have an SD card, then you might be more tempted to put the font in the code.
    I'm not sure whether one is better than the other. Maybe one needs to output both binary and text?
    Re descriptions of characters, the demo I wrote above is not the most efficient for memory. Fonts are padded out to 8 wide, and the height is larger than it needs to be for most characters. So you can either store the width, height, xoffset, yoffset, xadvance for each character, or you can pad them and then you only need to store the xadvance.
    For the touchscreens I am using, it is quicker to dump a whole picture than it is to send the individual pixels. So a full picture of a character fully aliased is the quickest. But I don't think that is the case for TV and VGA so I think it leads you down a different path there. Certainly editing is easier with unaliased fonts. And I don't know much about true type fonts - I think characters are described with curves and lines rather than with pixels.
    I guess one thing I found is there are some great online libraries of free fonts out there on the interweb.
    edited 2012-08-11 19:31
    More on using NASM to create Font files for SPI Flash (etc)
    Turns out the 'non scalar' error messages I got here, on the obvious (SomeLabel >> 8), are explained here :
    forum.nasm.us
    and NASM uses a Section Relative system, using this rule
    The difference between two labels (in the same section!) is a "scalar value". The linker/loader can change the two values, but the distance between them remains the same. Therefore, we can do a calculation on it
    This is not actually a problem, as a multi-file font merge, would use difference approach anyway, it just needs a specific difference syntax.
    Here are some NASM examples, that work, and it can create large bin/hex files, from a simple or multiple FONT sources.
    18 00000001 [2148]                  DW LastByte    ; Gives warning as Address > 2 Byte
        19 00000003 [21480100]              DD LastByte
        20 00000007 [2148010000000000]      DQ LastByte
        21
        26
        27 00000014 [00000000]              DD	$$   ; $ is PC, $$ is Section start, here it is Zero
        28 00000018 01                      DB  (LastByte-$$) & 07H
        29 00000019 2008                    DW  (LastByte-$$) & 0FF0H
        30
        31                                  ; Generate a 24 bit relative index
        32 0000001B 28                      DB  ((F8x8_Char5-FONT8x8_Start) >> 0) & 0FFH
        33 0000001C 00                      DB  ((F8x8_Char5-FONT8x8_Start) >> 8) & 0FFH
        34 0000001D 00                      DB  ((F8x8_Char5-FONT8x8_Start) >> 16) & 0FFH
        35
        36                                  ; another section relative index, other endian, 24 bits.
        37 0000001E 01                      DB  ((LastByte-$$) >> 16) & 0FFH
        38 0000001F 48                      DB  ((LastByte-$$) >> 8) & 0FFH
        39 00000020 21                      DB  ((LastByte-$$) >> 0) & 0FFH
    The command line is simply
    ..\nasm -f ith F8X8.ASM -l F8x8.lst
    ith = intel hex, or bin for binary file.
    edited 2012-08-12 07:22
    Ok, I can provide text output in the 8088 assembly syntax.
    There may be people who would use this for 8051 programming anyway...
    But, the output of your assembler would just be the binary file we talked about earlier...
    You could just use some tool to concatenate binary files instead of going through the whole assembly process.
    But maybe what we really need is a simple file system for flash...
    I worked a little on one, but that's a different project...
    edited 2012-08-12 15:00
    Rayman wrote: »
    Sounds good.
    It can optionally be binary, which allows present PropTool include, but it can also be HEX, or the ASM might link into a HLL project
    on AVR/8051/etc.
    "concatenate binary files" is not so simple, as you usually need some means to index across fonts.
    With ASM, you can easily manage that, and choose if you want relative, or absolute addresses.
    ASM could also create a simple File system header, with some font info comments.
    This would be a simple, master ASM that was a stack of %include's for each font, and with some index DB's added.
    NASM (which I had not looked at for a while..) seems quite good for this, as it has a 'hidden' linker, and can build (very) large binary/hex files, and you can just point a single command line, and Assemble/Include any desired set of font files, all under the control of a Text editor, and with full version control. You also get a LST file, as confirmation of what happened.
    edited 2012-08-14 08:39
    Ok, I've added a lot of output options...
    The new version is in the top post.
    It now saves as .rfd files, but you can still import and export Windows Bitmaps.
    There are a lot of text output options now...
    Haven't gotten to variable pitch yet...
    edited 2012-08-14 13:38
    Looks good :) - ASM output worked fine with NASM.
    Minor comments :
    I would add the export settings as comments too, especially the scan ones.
    I would also add a couple of ASM labels, eg
    ProGoCo_8x16_Font:
    so that a user can %include any series of font files, and build a simple font index using those labels.
    Any Width/Offset tables, should also have labels.
    Idea is they can Grab any saved Font, wiggle some pixels, export and build, without needing to edit the export file.
    I guess here some means to export-the-same-as-before would be useful ?
    Maybe a backup/rename of old file, could help protect users ?
    I did notice there is no save-as, and save does not have an over-write warning.
    Do you plan to support import/export in the xml file of glcd-font-creator ?
    That would allow access to larger user base, as I get the impression that glcd is inherited and somewhat frozen.
    (because they have other packages for $$$, no surprise..)
    edited 2012-08-14 16:35
    Thanks for the suggestions. I'll look into your xml format tomorrow. I used to have an xml parser, I'll try to dig that up...
    edited 2012-08-15 17:05
    jmg, can you please test the attached version and see if it can import your xml font?
    Also, if you could post a couple full xml files, that might help me figure out how to make it work.
    Especially, a variable pitch font...RaysFontEditor_15Aug12.zip
    edited 2012-08-15 17:54
    I tried a paste, but I think it ran out of paste-space as the last text was not the XML end - easy to fix...
    Attached is xml_font_examples.zip, which is three font files.
    Not sure if the simple LCD font manager can cope with variable spaced fonts ?
    I did try this - which is quickly add a width modifier to 3 lines, & height to 1, and GLCD Font Creator will read this fine.
    (ie it simply ignored the added WIDTH="7", HEIGHT="13" etc )
    Of course, on save it removes the ignored text, but it does tolerate it nicely, so you may have a safe superset there.
        <FONTSIZE WIDTH="8" HEIGHT="15" PROPORTIONAL="0" FONTKIND="0"/>
         <RANGE FROM="32" TO="127"/>
         <CHARS>
              <CHAR CODE="32" WIDTH="7" HEIGHT="13" PIXELS="16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215"/>
              <CHAR CODE="33" WIDTH="8" PIXELS="16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,16777215,0,0,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,16777215,0,0,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215"/>
              <CHAR CODE="34" WIDTH="9" PIXELS="16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215"/>
              <CHAR CODE="35" PIXELS="16777215,16777215,16777215,16777215,16777215,0,16777215,16777215,16777215,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,16777215,16777215,16777215,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,0,0,0,0,0,0,0,0,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,0,16777215,16777215,16777215,0,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215,16777215"/>
    Notice I did not trim the pixel lines, and doing that does confuse GLCD Font Creator. (no surprise)
    So I think the compatibility rule is to use a largest-box for the header, and always export to that size, but allow the width modifier per character to optionally trim below that. ( left justified ? )
    I guess also Height could be variable too..
    So you can load any of their files and save read-compatible, but add Width to this format.
    edited 2012-08-16 13:52
    jmg, Ok, I think it imports and exports your xml fonts now...
    Made an intial stab at variable pitch capture too...
    Try this one: RaysFontEditor_16Aug12.zip
    I'm getting close to calling it done...
    Just need to implement the variable pitch export options and add some additional controls...
    edited 2012-08-16 14:57
    Rayman wrote: »
    Comments:
    Import via paste still fails, looks like a simple paste-limit issue.
    Import via Read from File looks OK.
    Export into GLCK Font creator locks up.
    You can get a free copy here :
    http://www.mikroe.com/eng/downloads/get/1654/glcd_font_creator_v120.zip
    I spotted three easily fixed issues in a quick glance at the file
    - Missing tail lines
    </CHARS>
    </FONT>
    - bonus CR instead of CRLF
    - Extra quote in the <RANGE FROM="32" TO="127""/>
    I also see Import 'clobbers' the currently open font, without prompting for a new option. Not a nice default.
    It crashed once, when I was checking save / save-as with a few fonts open.
    Not easy to reproduce, but I suspect some 'cross pollination' effect as the message said something about Sizes
    edited 2012-08-16 17:31
    Ok, I'll fix these xml export errors tomorrow...
    Also, I'll add an "undo" and "redo" option that should address your clobbering...
    Let me know if you can figure out what makes it crash...
    edited 2012-08-16 19:53
    Rayman wrote: »
    See attached screen shot.
    This was after a XML import from a GLCD font, and fails @ save.
    Some seem to XML import/save ok, some do not.
    I also see that a 21x22 font imported, renders fine, but double-click to edit, selects a char somewhere else...
    (ie the selected-char decision, is not quite properly applying the real font size )
    I have not seen a crash on load (except on a file that crashed on save, and that's not a fair test..)
    So the LCD files seem to import, and render as I would expect, but maybe some info needed for save, is not
    properly updated ?
    If you download GLCD and NewFont.ImportSystemFont, you can quickly create a series of .LCD test files, of various XY sizes.
    Suggestion:
    The whole font preview is great, but as it zooms, it crops off the screen, even tho there is plenty of render space.
    A simple binary size makes sense, but fitting all the chars is also important.
    Perhaps a user Chars-per-row, and even a re-size option on the render area ?
    I'm thinking of a screen-grab as a quick and simple means to document fonts and changes.
    (I've added a font grab example, of a screen grab saved as .png )
    1024 x 740 - 63K
    1024 x 451 - 37K
    edited 2012-08-17 12:36
    Ok, I've added a lot of features today (of course that is just more things that might not work right...)
    Anyway, I think I've fixed all the things you found...
    Also, it can now export variable pitch in a way that I think Dr_Acula wanted...
    Please try this version: RaysFontEditor_17Aug12.zip
    edited 2012-08-17 13:30
    Looks more stable. Import/export round trip is OK, and I can now GLCD load a exported .lcd Nice.
    Some house-keeping issues :
    a) When I select XML format, it should flip the import default from .txt, to .lcd { Saves mouse clicks...}
    b) Import into a blank sheet, should apply the imported name.
    c) I see the cursor shows Dec/Hex Chr value, - would be nice if the Character Editor did that too, maybe in the top line ?
    d) Copy / Paste of chars is nifty, but it only works in a pre-valid slot ?
    If I import a file < 256, and copy/paste 'Q' into a visible, but not white BG cell, it does nothing.
    I can copy-over into any white BG cell.
    e) I see the Editor has the same issue - It opens, and I can flip pixels, but it will not save into a not white BG cell
    (ie does not create a new Char position)
    I'm not sure needing a blank page before import is a good idea.
    Import should be like any text editor, it should default to a NEW page, (named as the import file ), but allow experienced users to merge-import over the top of an open font. (with warnings)
    Right now, it does not merge import over an open font, it wipes the whole sheet.
    ie I quickly edited a XML file, to place 'Q' in CHR0 location, and I should be able to import that, into an open font (of the same XY) and have 'Q' pop into @0, with the rest of the font untouched.
    Single char import works, apart from the unwanted clear-all first.
    Edit: To clarify, the import file may have one or more chars, and even be sparse, and they should merge-over and create new chars if needed. Export should be only of defined chars, and may also be sparse.
    A common use is to harvest std forts for the lower 128, and use more custom sources for > 128 and sometimes < 32.
    edited 2012-08-17 14:46
    Thanks for checking it out. I'll work these issues...
    edited 2012-08-17 18:20
    Just one thing... There's now a "font settings" menu... If you change the valid character range, you should be able to paste there.
    Actually, I think it did paste before, you just can't see it because of the font's character range setting...
    I do want the imports not to clear the existing font before importing... I'll have to figure out how to do that..
    edited 2012-08-17 19:38
    Rayman wrote: »
    Yes, I can paste into hidden chars, and then on manual adjust of the limits, they become visible.
    So, perhaps a user paste could auto-adjust-limits, to make it WYSIWYG ?
    edited 2012-08-20 11:00
    Here's an updated version with a few new features...
    RaysFontEditor_20Aug12.zip
    edited 2012-08-20 16:57
    Rayman wrote: »
    Looks nice.
    Paste Auto adjusts nicely.
    However, I see manual edit does not. Even tho Edit.OK works, I have to manually go into FontSettings, to 'see' the newly edited char, if it is outside the bounds. This should auto-adjust-limits the same as paste.
    Width control is good, but this will also need a means to move the whole char ( << Char and Char >> ? )
    and I guess height and Char Up Char Dn set, almost complete the tile controls.
    One feature I have frequently wanted, is an font insert/delete row/column, (just like in a spread sheet).
    Applied to a font it would default to copy of the indicated row/column - used to easily stretch/trim characters, that are almost a fit.
    Import still over-writes a non-empty slate, and import merge instead clears - still on the to-do list I guess.
    edited 2012-08-20 17:21
    Thanks for checking this out jmg. I think I'm with you on the first two things. Can you please explain more the last two things?
    I thought I had the import the way you wanted it...
    edited 2012-08-20 18:10
    Rayman wrote: »
    I have a single Char .lcd file (actually Q in Chr(0) ), and import of that into an open-font, still clears the whole font ?
    Also, import into any open (non blank) font, should ask if the user wants a new window (default) or Merge/replace.
    ie It is too easy to over-write an existing font.
    I don't see a 'about' or build version anywhere ?
    Edit:
    This is what I mean, is that supposed to be working on this build ?
    edited 2012-08-21 09:16
    Ok, I see what you mean now... I fixed it for "Capture System Font", but not for "Import Font"...
    I'll try to get to that today or early tomorrow... Thanks.
    There should be a tiny "about" button close to the top right corner of the window...
    edited 2012-08-22 10:56
    jmg wrote: »
    I'm trying to figure out how to do this... Can you please explain some more exactly what you'd like?
    Do you want to add a blank column? Or, do you want to insert a copy of a column to the left or right?
    Do you want this to operate on the whole font, or just one character?
    Here's the latest version with many of the suggestions implemented:
    RaysFontEditor_22Aug12.zip
    edited 2012-08-22 16:16
    Rayman wrote: »
    Where I've done this, is to clean-up, or scale imported fonts.
    The LCD editor pgm mentioned before, adds blank rows/columns but this is limited to edges. - so it is part way there.
    A Move Char U/D/L/R would effectively add a blank row on one edge, and remove on the other, keeping tile size
    Works like the 'Hand' control in Acrobat - the Font just moves within the tile
    A insert Row/Col, would take the cursor as a prompt, and usually copy, the selected R/C, but blank might be a user option
    SW based Insert saves a LOT of clicks over 'insert manually'.
    Of course, the question then rises of which surplus stripe is trimmed, after insert
    Since variable width is supported, maybe a delete row/col is all that is needed, but a user might accidently make a 17x8 tile ?
    The spread sheet method, users should already know/understand and that is a simple insert/delete, and there you can select/copy any r/c if you want a copy.
    Pixel-rectangle select/copy/paste would be sweet, but might be over-engineering this ?
