wonder if my prop chip is fried? but surely if it was i wouldn't be able to program it would i?
Go back through the PEK Education Labs, and see if you can blink a LED on each pin. That will tell you if the Propeller is working. Run through the whole lab and you will understand much of what is being discussed here.
Golly gee. That doesn't sound like 2m_fm_modulation1.spin.
I think it's time to hit the books.
_clkmode = XTAL1 + PLL16X _xinfreq = 5_000_000 { FFFF_FFFF / (CLKFREQ / (80Mhz / PLL16)) } c80mhz = %0001_0000__0000_0000__0000_0000__0000_0000 { FFFF_FFFF / (CLKFREQ / (100Mhz / PLL16)) } c100mhz = %0001_0100__0000_0000__0000_0000__0000_0000 { FFFF_FFFF / (CLKFREQ / (140Mhz / PLL16)) } c140mhz = %0001_1100__0000_0000__0000_0000__0000_0000 { FFFF_FFFF / (CLKFREQ / 6.550Mhz) } c6p550mhz = 351_650_447 { FFFF_FFFF / (CLKFREQ / 6.500Mhz) } c6p500mhz = 348_966_092 PUB Main | cog VCFG := %10 << 29 + COGID << 23 + %1000_0000 'set for broadcast aural on pin 7 using this COG CTRB:=%00001_111 << 23 'setup the broadcast PLL internal 16x FRQB:=c80mhz 'start the PLL PlayWAV 'play PUB PlayWAV | p, time, x DIRA[7]~~ CTRA:=%0001_011 << 23 'setup internal PLL 1x x:=clkfreq/11025 'sample rate repeat p := @beback + 44 time := cnt repeat while p++ < @end FRQA := c6p500mhz + byte[p] << 14 'modulate carrier and amplify the sample waitcnt(time += x) waitcnt(clkfreq + cnt) DAT beback byte File "expectu.wav" end byte 0Is it just the fact that they are both using the same transmit pin ?
