Why do all 3 leds blink at same rate ?
Not sure why my previous post never made it to the forum..... hopefully this one will...
I am brand new to the propeller.... like the idea of 8 'cogs'.....
How come the following code has the result of all 3 leds blinking at the same time..... verses each of them 'twinkling' at their own rate as I thought the program specifies....
FYI... I originally had the Twinkle method as PUB... but get the same results
I am an accomplished MCU developer.... but not on Propeller... so thanks for being patient.
TJ
CON
_clkmode = xtal1 + pll16x 'Establish speed
_xinfreq = 5_000_000 '80Mhz
OBJ
led: "E555_LEDEngine.spin" 'Include LED methods object
VAR
byte Counter 'Establish Counter Variable
long stack[90] 'Establish working space
PUB Main
cognew(Twinkle(16,clkfreq/150), @stack[0]) 'start Twinkle cog 1
cognew(Twinkle(17,clkfreq/200), @stack[30]) 'start Twinkle cog 2
cognew(Twinkle(18,clkfreq/250), @stack[60]) 'start Twinkle cog 3
PRI Twinkle(PIN,RATE) 'Method declaration
repeat 'Initiate a master loop
repeat Counter from 0 to 100 'Repeat loop Counter
led.LEDBrightness(Counter, PIN) 'Adjust LED brightness
waitcnt(RATE + cnt) 'Wait a moment
repeat Counter from 100 to 0 'Repeat loop Counter
led.LEDBrightness(Counter,PIN) 'Adjust LED brightness
TJ
Delete Counter from the VAR section.
I'm not sure if that will solve the problem. It just jumps out at me.
