Audio circuits
I know this has been discussed here at least once before but I want to build an audio device using SIDcog and I'm wondering what good choices are for the filter components on the audio output pins? I know there was some discussion about whether the C3 audio output filter was designed correctly for decent audio. What are the recommended values for the filter components for line level audio output?
David
David
I use a 1k resistor and .01uf cap. Ceramic caps work fine. I also recommend a 1uf in addition to parallax's stock filter. See the bottom middle of the touchburger schematic for example.
*edit*
Only because I didn't look for the schematic!
addit - averagejoe beat me by 1 minute!
I am using the 1K, 0.01uF lowpass and a 1uF Electrolytic blocking capacitor (+ hooked to lowpass filter, - to the center conductor of my audio jack), the filter sounds great.
zappman
Hello Phil,
I found out that sallen key filters don't work as well as expected with the prop. The reason is that the feedback capacitor conducts HF noise to the output and its bandwidth is way above what a cheap opamp can handle. A second order passive RC low pass followed by a simple non-inverting buffer works better (no feedback connected to the input = no HF bypass).
