VGA Breakout Adapter w/resistor color fix — Parallax Forums
edited 2012-07-31 20:39 in Propeller 1
I'm considering doing a run of these... Thoughts?
Jeff
    edited 2012-07-31 19:47
    There's a layer missing from the image. Can you post a schematic, too, please? 'Wanna check those resistors! :)
    edited 2012-07-31 19:53
    I pretty much drew this from scratch in the PCB editor (it's the same layout at the new VGA+ boards)
    Here's the circuit I'm using...
    440 x 343 - 23K
    Jeff,
    A better set of values would be 240 and 510 for the DAC series resistors, and 130 to ground. This accounts for the Prop's internal 27-ohm resistance. But try it first and measure the output on a scope to make sure it peaks at 0.7V with a 75-ohm load
