Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
VGA Breakout Adapter w/resistor color fix — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Oldbitcollector (Jeff)
8,091
2012-07-31 19:38
edited 2012-07-31 20:39
in
Propeller 1
I'm considering doing a run of these... Thoughts?
Jeff
550 x 439
74K
74.3K
Phil Pilgrim (PhiPi)
23,514
2012-07-31 19:47
edited 2012-07-31 19:47
There's a layer missing from the image. Can you post a schematic, too, please? 'Wanna check those resistors!
8,091
2012-07-31 19:53
edited 2012-07-31 19:53
I pretty much drew this from scratch in the PCB editor (it's the same layout at the new VGA+ boards)
Here's the circuit I'm using...
440 x 343
23K
23.3K
23,514
2012-07-31 20:39
Jeff,
A better set of values would be 240 and 510 for the DAC series resistors, and 130 to ground. This accounts for the Prop's internal 27-ohm resistance. But try it first and measure the output on a scope to make sure it peaks at 0.7V with a 75-ohm load
Sign In
Register
to comment.
