VGA Breakout Adapter w/resistor color fix
Oldbitcollector (Jeff)
I'm considering doing a run of these... Thoughts?
Jeff
Jeff
Here's the circuit I'm using...
A better set of values would be 240 and 510 for the DAC series resistors, and 130 to ground. This accounts for the Prop's internal 27-ohm resistance. But try it first and measure the output on a scope to make sure it peaks at 0.7V with a 75-ohm load
