The Propeller could beat up Chuck Noris...
So, turns out a Prop will run (Overclocked to 96MHz) almost perfectly off a power supply rail like the one shown below.
A 3.3 volt average 1.2 volt peak to peak saw tooth is not normally considered a good supply rail.
The only two clues something was wrong was the serial link to the computer would drop half a line of text randomly, and the board hummed softly.
This second power rail works perfectly though... A 0.8v peak to peak saw tooth is within spec for the Propeller. :cool:
Lawson
P.S. Turns out the TLV1117 regulators only work if the output capacitor has a 0.2-10 ohm equivalent series resistance. Using a 10uF ceramic capacitor turns it into a noisy saw tooth oscillator. (and it's even worse running with 0.4uF...) Easy to miss this part of the datasheet.
Lawson
Lawson departed this world at 4:07 PM GMT-6. Cause of death was determined to be a roundhouse kick to the abdomen. Due to damage sustained by the body, the service will be closed-casket.
RIP Lawson.
Parts that are that fussy, should be banned.
Too easy to have a cap go outside that "I'm OK jack" band, with age, or temperature.
Change brands, or service the device, and you have a new lottery...
BTW, the only SD card that survived the abuse was an old 512MB Sandisk.
