The Propeller could beat up Chuck Noris... — Parallax Forums
LawsonLawson Posts: 870
edited 2012-07-28 19:50 in Propeller 1
So, turns out a Prop will run (Overclocked to 96MHz) almost perfectly off a power supply rail like the one shown below.
A 3.3 volt average 1.2 volt peak to peak saw tooth is not normally considered a good supply rail. :innocent: The only two clues something was wrong was the serial link to the computer would drop half a line of text randomly, and the board hummed softly.
This second power rail works perfectly though... A 0.8v peak to peak saw tooth is within spec for the Propeller. :cool:
Lawson
P.S. Turns out the TLV1117 regulators only work if the output capacitor has a 0.2-10 ohm equivalent series resistance. Using a 10uF ceramic capacitor turns it into a noisy saw tooth oscillator. (and it's even worse running with 0.4uF...) Easy to miss this part of the datasheet.
640 x 480 - 10K
640 x 480 - 10K
  • plainsteveplainsteve Posts: 34
    edited 2012-07-27 15:29
    Dear all,
    Lawson departed this world at 4:07 PM GMT-6. Cause of death was determined to be a roundhouse kick to the abdomen. Due to damage sustained by the body, the service will be closed-casket.
    RIP Lawson.
  • jmgjmg Posts: 15,200
    edited 2012-07-27 15:53
    Lawson wrote: »
    Parts that are that fussy, should be banned.
    Too easy to have a cap go outside that "I'm OK jack" band, with age, or temperature.
    Change brands, or service the device, and you have a new lottery...
  • RickInTexasRickInTexas Posts: 124
    I had a strange regulator issue with my Propeller Proto Board USB. I blew up a few SD cards and was pulling my hair out. Finally discovered that the 5v regulator was ​intermittently jumping to around 8 volts or so. Didn't have my scope handy but I suspect it was oscillating. Just replaced it with a good ol' LM7805 and went merrily on my way. Love those old things - bulletproof and I've never seen one fail in my 30 some odd years of geekdom.
    BTW, the only SD card that survived the abuse was an old 512MB Sandisk.
