A simple Music Maker
So now I'm working on a simple method for playing lists of notes. I'm trying to use a combination of lookupz and lookdownz to "translate" the note name into the freqa value that will set the counter for generating a square wave at the note frequency. For my test "track" I have a list of all the "addressed" notes in ascending order. Unfortunately every other loop is returning "1" for the lookdownz.
To trouble shoot I tacked on a little vga debug terminal.
Thanks for your attention.
{{MusicMaker frqa values for 80MHz C6 = 56_184 D6 = 63_066 E6 = 70_786 F6 = 74_995 G6 = 84_181 A6 = 94_489 B6 = 105_629 C7 = 112_528 D7 = 126_127 E7 = 141_572 F7 = 149_990 G7 = 168_362 A7 = 188_978 B7 = 212_123 C8 = 224_734 }} CON _clkmode= xtal1+pll16x _xinfreq= 5_000_000 bpm = 120 bps = bpm/60 OBJ text : "vga_text" VAR long stack[64] PUB PLAYMUSIC | index text.start(16) ctra[30..26]:= 100 'Set ctra for "NCO, single-ended" ctra[5..0]:= 4 'set ctra pin to 4 frqa:= 0 dira[4]~~ repeat index from 0 to 15 note[index]:=lookdownz(long[@notes][index]: "C6", "D6", "E6", "F6", "G6", "A6", "B6", "C7", "D7", "E7", "F7", "G7", "A7", "B7", "C8", "R") frqa:=(frequency:=lookupz(note[index]: 56_184, 63_066, 70_786, 74_995, 84_181, 94_489, 105_629, 112_528, 126_127, 141_572, 149_990, 168_362, 188_978, 212_123, 224_734, 0)) waitcnt((bps*clkfreq)/(long[@tempo][index])+cnt) 'hold repeat index from 0 to 15 text.str(string(13, " index")) text.dec(index) text.str(string(" Note==")) text.dec(note[index]) DAT note long 0[16] frequency long 0[16] notes long "C6", "D6", "E6", "F6", "G6", "A6", "B6", "C7", "D7", "E7", "F7", "G7", "A7", "B7", "C8", "R" tempo long 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4 {{ C6 = 56_184 D6 = 63_066 E6 = 70_786 F6 = 74_995 G6 = 84_181 A6 = 94_489 B6 = 105_629 C7 = 112_528 D7 = 126_127 E7 = 141_572 F7 = 149_990 G7 = 168_362 A7 = 188_978 B7 = 212_123 C8 = 224_734 }}So what have I done?
Actually, I think I'd do it as an array of strings...
You can then use a printString function and give it the address: @noteStrings+index*3
but it was too lame to present. Only 8 keys. Real hard to do the black keys too.
I'm not sure I see the notes in your numbers.
This is what I used...
CON
A = 440
B = 493
C = 523
D = 587
E = 659
F = 689
G = 783
Expand on that?
Note Frequency (Hz) Wavelength (cm)
C0 16.35 2100.
C#0/Db0 17.32 1990.
D0 18.35 1870.
D#0/Eb0 19.45 1770.
E0 20.60 1670.
F0 21.83 1580.
F#0/Gb0 23.12 1490.
G0 24.50 1400.
G#0/Ab0 25.96 1320.
A0 27.50 1250.
A#0/Bb0 29.14 1180.
B0 30.87 1110.
C1 32.70 1050.
C#1/Db1 34.65 996.
D1 36.71 940.
D#1/Eb1 38.89 887.
E1 41.20 837.
F1 43.65 790.
F#1/Gb1 46.25 746.
G1 49.00 704.
G#1/Ab1 51.91 665.
A1 55.00 627.
A#1/Bb1 58.27 592.
B1 61.74 559.
C2 65.41 527.
C#2/Db2 69.30 498.
D2 73.42 470.
D#2/Eb2 77.78 444.
E2 82.41 419.
F2 87.31 395.
F#2/Gb2 92.50 373.
G2 98.00 352.
G#2/Ab2 103.83 332.
A2 110.00 314.
A#2/Bb2 116.54 296.
B2 123.47 279.
C3 130.81 264.
C#3/Db3 138.59 249.
D3 146.83 235.
D#3/Eb3 155.56 222.
E3 164.81 209.
F3 174.61 198.
F#3/Gb3 185.00 186.
G3 196.00 176.
G#3/Ab3 207.65 166.
A3 220.00 157.
A#3/Bb3 233.08 148.
B3 246.94 140.
C4 261.63 132.
C#4/Db4 277.18 124.
D4 293.66 117.
D#4/Eb4 311.13 111 .
E4 329.63 105.
F4 349.23 98.8
F#4/Gb4 369.99 93.2
G4 392.00 88.0
G#4/Ab4 415.30 83.1
A4 440.00 78.4
A#4/Bb4 466.16 74.0
B4 493.88 69.9
C5 523.25 65.9
C#5/Db5 554.37 62.2
D5 587.33 58.7
D#5/Eb5 622.25 55.4
E5 659.26 52.3
F5 698.46 49.4
F#5/Gb5 739.99 46.6
G5 783.99 44.0
G#5/Ab5 830.61 41.5
A5 880.00 39.2
A#5/Bb5 932.33 37.0
B5 987.77 34.9
C6 1046.50 33.0
C#6/Db6 1108.73 31.1
D6 1174.66 29.4
D#6/Eb6 1244.51 27.7
E6 1318.51 26.2
F6 1396.91 24.7
F#6/Gb6 1479.98 23.3
G6 1567.98 22.0
G#6/Ab6 1661.22 20.8
A6 1760.00 19.6
A#6/Bb6 1864.66 18.5
B6 1975.53 17.5
C7 2093.00 16.5
C#7/Db7 2217.46 15.6
D7 2349.32 14.7
D#7/Eb7 2489.02 13.9
E7 2637.02 13.1
F7 2793.83 12.3
F#7/Gb7 2959.96 11.7
G7 3135.96 11.0
G#7/Ab7 3322.44 10.4
A7 3520.00 9.8
A#7/Bb7 3729.31 9.3
B7 3951.07 8.7
C8 4186.01 8.2
C#8/Db8 4434.92 7.8
D8 4698.64 7.3
D#8/Eb8 4978.03 6.9
Too much tease. No link!
I did post a link to a link.
I have a bunch of S2 links in post #12 of my index, including a link to the product page.
I agree, it would have been nice if I included a direct link.
The values I'm using for my frqa register are based on the equation from page 137 of the Propeller Education Kit Labs Fundamentals:
FRQ register = PHS bit 31 frequency
Thanks Duane. Bookmarked for further study.
I think Rayman 's solution is the one I was looking for, but I need to mull it over a bit more.
again, thanks for your help and patience.
BTW, you had set the high bits of ctra to 100 (decimal) instead of %00100 (binary). I also cleaned up your formatting a little bit to make the program more readable. Finally, your computation for BPS would not yield a smooth tempo gradient, due to integer division. But by changing it to beats per millisecond, you get many more possible tempos.
I have not tested these changes. If it doesn't work, just come back here to ask for more help.
