Measuring solar panel voltage.
I know this is a vague question, but I have no idea where to start.
I have a solar panel and I've hooked it up to an LED on the solderless breadboard on the BOE Board, but now I'd like to use the BS2 chip to measure the voltage of the solar panel. I know that I might use RCTime, a capacitor, and maybe a trasistor? I'm really lost and would like help if your willing to spare the time.
May I ask how big the panels are and what kind of a load you are placing on them? Reason I say this is because solar panels should be measured in two different ways to determine the maximum amount of power that they can deliver. First with an open circuit, and then with a known or dynamic load applied to them. With larger panels and requirements this becomes more important. With smaller applications it's not as critical.
Edit: I tested with out the resistor it worked great, thank you! There was a very small maximum voltage however, so I'll get that resistor soon. Thanks!
I took care of that for you, but in the future you would do it by editing your message and selecting Advanced Mode. Take care.
solar energy system
