Code Issue - Method vs. "Main"
Jon Keinath
I'm having an issue moving some of my code from my "main" method do a sub method. If I do everything in the main method it works as I would expect. The "main" structure is below:
If I use the following program structure the outputs in x0 through x7 are not what I would expect.
A separate PUB (and COG) takes the values in x0 through x7 and displays them on a matrix led board. For some reason x0 is correct in both instances but the remainder of the x terms are incorrect.
Any suggestions?
DAT lH byte %10001, %10001, %10001, %11111, %10001, %10001, %10001, %00000 VAR long x[8] long x0, x1, x2, x3, x4, x5, x6, x7 PUB go x0 := ((lH[0] & |<0)<<0)+((lH[0] & |<1)<<2)+((lH[0] & |<2)<<4)+((lH[0] & |<3)<<6)+((lH[0] & |<4)<<8) x1 := ((lH[1] & |<0)<<0)+((lH[1] & |<1)<<2)+((lH[1] & |<2)<<4)+((lH[1] & |<3)<<6)+((lH[1] & |<4)<<8) x2 := ((lH[2] & |<0)<<0)+((lH[2] & |<1)<<2)+((lH[2] & |<2)<<4)+((lH[2] & |<3)<<6)+((lH[2] & |<4)<<8) x3 := ((lH[3] & |<0)<<0)+((lH[3] & |<1)<<2)+((lH[3] & |<2)<<4)+((lH[3] & |<3)<<6)+((lH[3] & |<4)<<8) x4 := ((lH[4] & |<0)<<0)+((lH[4] & |<1)<<2)+((lH[4] & |<2)<<4)+((lH[4] & |<3)<<6)+((lH[4] & |<4)<<8) x5 := ((lH[5] & |<0)<<0)+((lH[5] & |<1)<<2)+((lH[5] & |<2)<<4)+((lH[5] & |<3)<<6)+((lH[5] & |<4)<<8) x6 := ((lH[6] & |<0)<<0)+((lH[6] & |<1)<<2)+((lH[6] & |<2)<<4)+((lH[6] & |<3)<<6)+((lH[6] & |<4)<<8) x7 := ((lH[7] & |<0)<<0)+((lH[7] & |<1)<<2)+((lH[7] & |<2)<<4)+((lH[7] & |<3)<<6)+((lH[7] & |<4)<<8)
PUB go convert(lH) PUB convert(letter) x0 := (((letter[0] & |<0)<<0)+((letter[0] & |<1)<<2)+((letter[0] & |<2)<<4)+((letter[0] & |<3)<<6)+((letter[0] & |<4)<<8)) x1 := (((letter[1] & |<0)<<0)+((letter[1] & |<1)<<2)+((letter[1] & |<2)<<4)+((letter[1] & |<3)<<6)+((letter[1] & |<4)<<8)) x2 := (((letter[2] & |<0)<<0)+((letter[2] & |<1)<<2)+((letter[2] & |<2)<<4)+((letter[2] & |<3)<<6)+((letter[2] & |<4)<<8)) x3 := (((letter[3] & |<0)<<0)+((letter[3] & |<1)<<2)+((letter[3] & |<2)<<4)+((letter[3] & |<3)<<6)+((letter[3] & |<4)<<8)) x4 := (((letter[4] & |<0)<<0)+((letter[4] & |<1)<<2)+((letter[4] & |<2)<<4)+((letter[4] & |<3)<<6)+((letter[4] & |<4)<<8)) x5 := (((letter[5] & |<0)<<0)+((letter[5] & |<1)<<2)+((letter[5] & |<2)<<4)+((letter[5] & |<3)<<6)+((letter[5] & |<4)<<8)) x6 := (((letter[6] & |<0)<<0)+((letter[6] & |<1)<<2)+((letter[6] & |<2)<<4)+((letter[6] & |<3)<<6)+((letter[6] & |<4)<<8)) x7 := (((letter[7] & |<0)<<0)+((letter[7] & |<1)<<2)+((letter[7] & |<2)<<4)+((letter[7] & |<3)<<6)+((letter[7] & |<4)<<8))
Any suggestions?
Lawson
PUB convert(addr) : n repeat 8 x0[n++] := table[byte[addr][n]] ' treat x0..x7 like an array, i.e. x0[8] DAT table word 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 word 16, 17, 17, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31The table has to be filled with the expected bit patterns of course.PUB convert(letter) : i | b repeat i from 0 to 7 x0[i] := 0 repeat b from 0 to 4 x0[i] += (byte[letter][i] & |<b)<<(b*2)Andy
I think I almost understand that, kuro.
All except the x0[n++].
We are moving bytes into longs, right?
One byte into each long?
Is that how it reads?
So what happends is we read a byte from the character definition, transform that into a word (table access) and assign it to a long. Does that make sense?
n is an alias for result which starts at zero.
Yes sir, although I skipped over the intermediate word conversion.
Thank you.
It was the :n in the PUB declaration that I am lacking.
That colon shows up in Ariba's Convert pub also.
I have not seen that before.
Richard
the colon is another trick of spin.
You can RETURN a value from your spin-method. lets say RETURN 10 or RETURN VarName. But you also can us a implicit existing variable named RESULT. So instead of RETURN 10 you can write RESULT:=10.
and if you do not like the name RESULT for that implicit existing variable wich gets returned you can RENAME it.
and that does that colon after the Method-name
so
PUB test | myvar
myvar:=10
RETURN myVar
is the same as
PUB test | myVar
RESULT:=myVar
is the same as
PUB test : myReturn | myVar
myVar:=10
myReturn:=myVar
And in opposite to all your local variables like myVar (wich are NOT initialized) RESULT is inirtialized as 0.
Enjoy!
