help propeller tool cant find propeller chip?
I bought this item from ebay as a cheap alternative to the prop plug as they were sold out at the time. Can you guys advise me as to how to get this working?
http://www.ebay.co.uk/itm/USB-2-0-to-UART-TTL-6Pin-COM-Module-Converter-Adapter-CP2102-Chip-with-Cable-New-/271010411682?pt=UK_Computing_Parallel_Serial_PS_2&hash=item3f197ab4a2
but i can't seem to get it to work the computer (windows 7 or osx 10.6 with brians tool) sees the usb to uart and loads the silicon drivers but propeller tool just can't find the propeller chip on port com3. Its driving me nuts. My circuit is just the default circuit listed in the datasheet
Any ideas would be greatly appreciated!
Someone on the forum has provided instructions on what changes you'll need to make. It might require a transistor as Mike suggested.
I don't have time to find the link now. I'll look for it later if you still need it. I might have a link to the instructions in my index (see signature), but I'm not sure.
http://forums.parallax.com/showthread.php?133335-Cheap-PropPlug-replacement-USB-TTL-converter-US-4.60-and-a-modification
