minimal assembly dual propeller kits?
I'm looking for a kit that includes everything I need for a dual propeller setup. Does such a thing exist? I also hope it doesn't require surface mount soldering.
thanks!!!!
thanks!!!!
sssidney, I am guessing the full kit order I got today was from you
I will email you later today.
Bill
Frank
Slave Prop on QuickStart Proto Board
Breadboarding multiple Propellers
The basic support circuitry for the Prop is rather simple and can be wired on a protoboard or breadboard for experimenting. The tetra-prop is also a great board to multi-prop with.
As you may have noticed, PropForth and multiple Propellers go together very well
