Mlx90615
Hello, i have recently purchased a MLX90614 and MLX90615. I'm trying to use it to detect the temperature of a human, theses seems like a good place to start. I've found on the OBEX code for the MLX90614 and after reading through the datasheet i didn't see much difference between the 14 and 15. The main difference i saw was the registers. I noticed that in the MLX90614 object the only register that is used has the same address in the MLX90615. It is possible i missed other registers being used in the code, but i don't think so. So my question is, does anyone have any experience with the MLX90615? Also, does anyone have any other suggestions on temperature sensors i should try? Again I'm trying to get the temperature of a human body.
Joseph
Joseph
http://www.melexis.com/Assets/Comparative-table-between-the-MLX90614-and-the-MLX90615-5480.aspx
