Emic 2 speaks!
Just received my Emic 2 today and I recorded it saying "forward" on my computer which sounds amazing in 5.1 surround even though it is mono. It also sounds very good plugged into the Veho 360 speaker. But the forum won't let me upload a .wav file or I would let you hear at least the default voice.
Edit: it is in the zip file. Now correct file
Did you see the examples by Joe Grand on Youtube?
and the first spin podcast: http://www.firstspin.tv/2012/07/03/first-spin-episode-033-emic-2-text-to-speech-module/
I guess at 6700 posts, I am officially verbose!
No, we'll NEVER see that. EVER.
When? And don't say Prop 2.
PropCAM, then?
God bless you, PhiPi!
I am new to Robotics but not programming. I have the Emic-2 TTS module and Veho speaker as well as the STAMP serial board. I don't see how to connect the TTS module to the Stamp module for the Serial input to TTS.
I see how to do power and speakers though.
The TTS PDF file shows what needs to be connected but not the Serial input from STAMP module to TTS board.
Any help appreciated.
Gary
In the Basic Stamp example on the product page, It shows the EMIC TX and RX connected to the BS2 PIN0 and PIN1, (look at the I/O definitions in the program.
The code says;
EMIC_TX PIN 0 ' Serial output (connects to Emic 2 SIN)EMIC_RX PIN 1 ' Serial input (connects to Emic 2 SOUT)
Where is EMIC_RX and EMIC_RX connectors on STAMP module ?
See attachment snapshot. I don't see where to connect jumpers.
Gary
The P0 and P1 serial connections are on the X1 APPMod Header.
Gary
emic_rogersyd.zip
