Is there an inverted version of the ULN2803 or ULN2003
I am using the ULN2803 on a new 16x16·LED matrix using a positive input into the ULN2803 which then gives a negative input into the Cathodes of my LED matrix.
However on the flip side for the Anodes, I am using 2N3906 PNP transistor / resistor circuits. A negative input goes into the transistor / resistor circuit and provides a positive input to the Anodes of the LED matrix. I would like to not to have to use the transistor / resistors as they are a bit of a pain to solder up. I would like an inverted version of the ULN2803 or something anyone can recommend that provides the drive current for the anodes of·my LED matrix. I also want to keep the chip count down so I don't want to use an inverter chip·AND another driver chip if possible.
So·2 postive driver chips for the anodes and·2·negative driver chips for the cathodes (something like this - if possible).
Any ideas? Comments?
Post Edited (T&E Engineer) : 4/11/2007 5:42:13 PM GMT
Any ideas on something like this 8 channel source driver?
...and I discovered that they are most efficient when pulling to ground, and have a voltage drop, then, of only .65 volts (with a five volt supply)· When pulling towards the positive side current must flow through a pull-up resistor that you supply, so they are not as efficient in that direction.
An LM339 is a quad device, not octal like the uln2803, and I forget at the moment·the max current possible, but I imagine it's not·quite as robust as the·2803.
Hex inverters (they come in·in a six-pack) might work also...
tommy·
The LM339 is an analog comparitor not a digital driver or buffer IC for max current out needed for the LED matrix. So this will not work - but I appreciate your input.
Paul Baker
The Find Chips search engine will give you a number of distributors. Here is a link to it:
http://www.findchips.com/
Bruce Bates
the UDN2981 is available from rapid electronics order code 82-2202
this does work very well for sourcing current instead of sinking it
http://www.rapidonline.com/Electronic-Components/Udn2981a-8-channel-Power-Driver-82-2202/?sid=0f19c2a4-62e2-4b9d-9383-0ab8bb920c17
It is parallel and darlington (Emitter out / Sourcing drive), but you may be able to find a lower drop, serial variant to cut PCB traces amongst all the LED drivers everyone seems to be rushing to offer ?
hehe, oops, that explains why the TLC59213 was overlooked.... back then, it did not exist yet
