Ripping a single bit out of a Long
I am trying to take just the MSB of a long (one bit of info), and depending on if it is a 1 or a 0 do some other program trickery with if/else statements. Is there an easy way of doing this? I initially tried this:
(L[BasePin] is a 128 long buffer that is loaded from an SD card earlier in the program, just to get that clarified.)
but that really gets confusing since that is actually a negative number when converted to decimal, so there is no way to base a greater than/less than off of this method when taking into consideration that the rest of the bits in the var "NetTemp" could be anything, making it a positive or negative number. I also tried:
and I was still getting odd results. anyone know of some way of isolating just the MSB, even if it is to another variable so that I can do some true/false work?
NetTemp := L[BasePin]
repeat 32
if NetTemp => 00_0000_0000_0000_0000_0000_0000_0000
else
NetTemp <-= 1
NetTemp := ||L[BasePin] if NetTemp => 00_0000_0000_0000_0000_0000_0000_0000 .....
if x < 0
Jonathan
I assume that does not matter, and lonesock is still correct?
Duane J
I do
Pub Bits (In,bit,value) Result := (In & !(1 << bit)) | (value << bit)Where...
value = 1 or 0
in = the original number
bit = what bit in the long.
Thanks !
Clever code :-)
This is my version from a user-friendly programming template for the EFX-TEK HC-8+
pub set_bit(target, pos, newbit) if ((pos => 0) and (pos =< 31)) ' if good bit position if (newbit) ' if true/1 target |= (1 << pos) ' set the bit else ' if false/0 target &= !(1 << pos) ' clear the bit return targetMy version is a little less clever than the neat one-liner that Bits showed you; again, mine is built into a programming template that is intended to be easy on Spin newbies. Mine will also set the bit for any non-zero value in the newbit parameter. This allows me to use true and false results from other operations, for example, as in this program I was working on yesterday that looks for specific numbered files on an SD card
repeat idx from 0 to 15 make_filename(idx) inventory := set_bit(inventory, idx, open_file(@FileName, "r")) close_fileYour solution is pretty close to my first thoughts, it's very easily understood and has indeed an advantage with non-zero-or-one values.
Bits solution seems efficient (faster ?), so I guess it's still true that there are pros and cons with every design.
/Nick
