gps-pmb-648 Troubles with NMEA-String #28500
nomad
hi,
today i make tests with my GPS_PMB-648.
on my C3
device connected (yellow-wire to P07 and +5v and Gnd)
on gps first redLed blink, then steady...
1. test:
with !GPS_Propeller.spin: output on pst: longitude and latitude OK
2. Test with GPS_Str_NMEA_Lite.spin
- same P07 and yellow wire
- on pst-terminal == no output
- test fail
the same happened with GPS_Str_NMEA.spin
with the GPSDriver_Demo.spin: on pst-terminal on one line 00000....0000 slow
questions:
- is NMEA possible with only the yellow-wire (P07 or P06) ??
- have somebody the names of the blue, and white wire
- or is tx and rx needed ??
- what's the best baudrate for pst ???
i don't know what i should do now
have somebody hints, tricks and help for me?
thanks
regards nomad
on my C3
1. test:
- test fail
questions:
thanks
regards nomad
http://learn.parallax.com/KickStart/28500
thanks for your answer,
in the meantime
- 1) i can run the Spin-program GPS-Propeller.zip
All values are okL
- 2) I know now that GPS-Str-NMEA-(lite).spin are Drivers and not Demos,
excuse me
- 3) yesterday i found in this forum some Programms for reading NMEA-strings (in the year 2010)
included in the parallaxBook about Propeller (chapter 09)
if i have troubles in the future ;-) i make a post.
thanks
regards nomad
