Using counter modules to control frequency of sine, square, or triangle wave — Parallax Forums
Mad AMad A Posts: 17
edited 2012-07-01 05:35 in Propeller 1
I am building a function generator with my propeller. So far I can generate the basic square, sine and triangle waves. On the sin wave, I can only achieve a speed of about 5 KHz because I am reading from the sin table in main memory every sample. So I was thinking of reading one cycle of the sine wave into cog memory and then using a counter module to control writing the samples to the output pins (which are connected to an 8 bit DAC) faster. I am not certain how to do this. Also I eventually want to add knobs to control frequency and maybe amplitude....
    edited 2012-06-29 14:28
  • groggorygroggory Posts: 205
    edited 2012-06-29 14:35
    LOL @ this thread being like #1 or #2 on the forum right now
  • Mad AMad A Posts: 17
    edited 2012-06-29 14:36
    I did see that thread, the problem is the lack of sine wave. Making the sine wave faster is my major sticking point. I did download the object though and am going to look through it,
    edited 2012-06-29 14:48
    Hmmm, no sine wave? Well thats an oversight. Here is a program I have been using on a CNC resolver exciting a coil at 30kHz....
  • jmgjmg Posts: 15,199
    edited 2012-06-29 15:09
    Mad A wrote: »
    How much faster do you actually need, and at what precision ? (Frequency step size and distortion )
    I see you also have this thread :
    http://forums.parallax.com/showthread.php?140784-Sine-wave-generator
    Sine generation has two dimensions, and you can choose to work in either.
    You can use low precision Y axis, and try to compensate for that with more samples in X, or a higher precision Y axis, allows less samples in X.
    As I mentioned in the other thread, fast polling a NCO gives the best natural scaling, and you then choose a DAC.
    The Sine ROM gives 16 bit sine values, so an obvious step is to feed an external i2s DAC, which can run to 192KHz Stereo 16/24/32bit update rates.
    This means 19.2 sample points in a 10KHz sine, and 192 sample points in a 1KHz sine, but those points are precisely placed in X & Y, so filtering gives low distortion sine results.
    Parallel DACs could give more bandwidth, but using more pins, and at higher prices (outside the high volume areas)
    Edit : I see Beau has posted an exact example of fast NCO polling, using the Prop 'Duty' mode DAC.
    I think PhiPi found the Prop 'Duty' Mode DAC limit was ~12-13 bits (ignoring crosstalk effects).
    So below 5-10KHz, using an external i2s DAC could be expected to give much better numbers, in distortion.
    Above 20-30KHz the i2s DAC will 'run out of steam' with limited samples per sine.
    Frequency Granularity is the same, independent of DAC choice, I make that 18.6 milli hertz.
    There is a trade off in the XY points : At the 30KHz reference point Beau mentioned, you have 41.66 updates/full cycle, and around a 6 bit DAC equivalent.
    At that speed, an i2s DAC still delivers >> 16 bit Y axis, but has dropped to 6.4 updates/full cycle
  • Mark_TMark_T Posts: 1,981
    edited 2012-06-30 11:07
    Frequency granularity can be arbitrarily high when doing direct digital synthesis - just make the phase accumulator and frequency registers larger - only the top bits of the phase-accumulator get to index the sine table.
    If using I2S with a sample rate of 96kHz then a 32 bit frequency / phase register setup gives a frequency increment of 22.35 micro Hz... The 18.6 milli Hz figure applies to one sample per system clock (which is unlikely for a sine-table lookup). Make the registers 64 bit then the frequency precision is greater than you will ever need!
    edited 2012-06-30 13:12
    Mark_T wrote: »
    True, but then you have flipped from a Hardware adder, to a software one.
    I guess at 96/192KHz that is do-able, if i2s from clocked-video is practical.
    The sine table is only 16b, which will limit how usable that 22.34uHz is, but there may be time for linear interpolate, to push that Y axis precision higher ?
    Going by the small code size of these loops, there is room to give a user choice of all of these in 1 COG
    ** NCO square wave
    ** Prop DAC Loop Sawtooth/triangle/square
    ** Sine LUT Loop, i2s Stereo DAC, HW adder
    ** Sine LUT Loop, i2s Stereo DAC, SW adder, (possible extended precision Y ?).
    Edit : In case anyone is wondering why 18.6mHz vs 22.35uHz is even being discussed, more precision is always good, especially on test systems :)
    Some real examples where 18.6mHz might be coarse, are testing crystals, and Physics experiments where you might select two very close frequencies to give a constant slow phase advance in multi-resonant systems. (18.6mHz is 56 seconds for full phase move.)
    The other important reason for high-frequency resolution is reducing spurious signals when sythesizing frequency- and phase-modulated signals.
