Wire and Spice — Parallax Forums
Wire and Spice
edited 2012-07-03 23:56 in General Discussion
Wire and Spice
Some say design circuits with wire,
Some say with Spice.
From what I've tasted of desire
I hold with those who favor wire.
But if I had to solder twice,
I know enough of saving time
To say that for redoing it Spice
Is very prime
And will suffice.
Apologies to Robert Frost. :)
Inspired by my frustrations designing a JFET RF amplifier to feed a Prop input. LTSpice made things much easier!
    edited 2012-06-28 15:34
    Of JFET RF amps & such:
    PhiPi does it
    He's our man
    If he can't do it
    No one can!
    Apologies to high school cheerleaders everywhere...
    edited 2012-06-28 15:38
    'Twas brillig and the JFET amps
    All mimsy were the LED lamps!
    I got more...
    Don't make me bust out my Haiku skillz...
    edited 2012-06-28 15:55
    Internet of things
    Connected to the ether
    Refrigerator
    Edit: prior to fixing, the first line started with "The" making it the 6 erco is referring to.
    edited 2012-06-28 15:58
    mindrobots wrote: »
    The Internet of things
    Refrigerator
    That's 6-7-5
    Gotta be 5-7-5
    Oops, that's more Haiku!
    edited 2012-06-28 16:01
    Phil knows I can't count or do math!
  • Mark_TMark_T Posts: 1,981
    edited 2012-06-29 03:35
    My favorite haiku (not electronics themed) is the last one on this page: http://www.hippos.com/haiku.htm
    edited 2012-06-29 07:10
    It's sad to see what happens when people have too much time on their hands instead of concentrating on a propeller project ; - )
    edited 2012-06-29 11:08
    COG PASM to Pin
    Bit bash protocol in code
    Soft Peripheral
    edited 2012-06-29 11:58
    There once was a language called Spin
    It could toggle the state of a pin
    The stack would grow
    And it did overflow
    Much to the programmer's chagrin
    edited 2012-06-29 12:39
    Then Propeller GCC came in
    Linux and OS X no longer a sin
    The benefits of Open Source it will show
    But the language of C you must know
    edited 2012-06-29 20:52
    Two pins diverged from a tiny jfet and I,
    shakey as I was, could solder neither.
    And that has made all of the difference.
    edited 2012-06-30 05:05
    Spinning and spinning in the widening gyre
    The propeller cannot hear the PropTool
    Things fall apart, Vcc cannot hold
    Thermal noise is loosed upon the circuit
    The AC ripple is loosed, and everywhere
    The orderly spinning of cogs is disrupted
    The best lack all synchronization, while the worst
    Are in full bore thermal runaway.
    edited 2012-07-03 16:29
    At Parallax Chip Gracey ran
    A fabless IC factory
    For circuits not yet known to Man
    Where Cogs and Hubs and PASM can
    use any pin generically
    (Sorry, this is too much fun not to kick :-)
  • bsnutbsnut Posts: 521
    Here's my spin on PASM.
    Phil
    All around
    Spin
    Man
