Wire and Spice
Wire and Spice
Some say design circuits with wire,
Some say with Spice.
From what I've tasted of desire
I hold with those who favor wire.
But if I had to solder twice,
I know enough of saving time
To say that for redoing it Spice
Is very prime
And will suffice.
Apologies to Robert Frost.
Inspired by my frustrations designing a JFET RF amplifier to feed a Prop input. LTSpice made things much easier!
Is very prime
And will suffice.
PhiPi does it
He's our man
If he can't do it
No one can!
Apologies to high school cheerleaders everywhere...
All mimsy were the LED lamps!
I got more...
Don't make me bust out my Haiku skillz...
Connected to the ether
Refrigerator
Edit: prior to fixing, the first line started with "The" making it the 6 erco is referring to.
That's 6-7-5
Gotta be 5-7-5
Oops, that's more Haiku!
Bit bash protocol in code
Soft Peripheral
It could toggle the state of a pin
The stack would grow
And it did overflow
Much to the programmer's chagrin
Linux and OS X no longer a sin
The benefits of Open Source it will show
But the language of C you must know
shakey as I was, could solder neither.
And that has made all of the difference.
The propeller cannot hear the PropTool
Things fall apart, Vcc cannot hold
Thermal noise is loosed upon the circuit
The AC ripple is loosed, and everywhere
The orderly spinning of cogs is disrupted
The best lack all synchronization, while the worst
Are in full bore thermal runaway.
A fabless IC factory
For circuits not yet known to Man
Where Cogs and Hubs and PASM can
use any pin generically
(Sorry, this is too much fun not to kick :-)
Phil
All around
Spin
Man
