BS2 Ezmouse Interface
I'm trying to interface Ezmouse PS/2 mouse adapter to BS2 and convert the movement data from the ezmouse to pwm output on two separate pins·of BS2, in order to control two potentiometers with movement data from the ezmouse adapter. I basically need to convert the synchronous serial data from the ezmouse adapter into two pwm outputs for analog joystick. Any sample code and any help at all would be appreciated.
I'm trying to get my hands on an ezmouse from multilabs but it seems they've gone out of business. If someone could refer me to a similar item, or if someone has a spare that they are willing to part with I would greatly appreciate it!!
thanks!
dr
