BS2 Ezmouse Interface — Parallax Forums
Sinista MaceSinista Mace Posts: 2
edited 2012-06-26 13:29 in BASIC Stamp
I'm trying to interface Ezmouse PS/2 mouse adapter to BS2 and convert the movement data from the ezmouse to pwm output on two separate pins·of BS2, in order to control two potentiometers with movement data from the ezmouse adapter. I basically need to convert the synchronous serial data from the ezmouse adapter into two pwm outputs for analog joystick. Any sample code and any help at all would be appreciated.
  • Sinista MaceSinista Mace Posts: 2
    edited 2009-07-27 19:31
    Oh yea, i need the output pwm to vary over a range of 0v to 1.6v. Any help would be greatly appreciated.
  • droumisdroumis Posts: 1
    edited 2012-06-26 12:47
    I'm trying to get my hands on an ezmouse from multilabs but it seems they've gone out of business. If someone could refer me to a similar item, or if someone has a spare that they are willing to part with I would greatly appreciate it!!
    thanks!
    dr
    Yep, they're long gone apparently. That previous post was 2009, BTW. A PAK coprocessor is available to read a PS/2 mouse: http://www.awce.com/pak11.htm
