Question about RoboRealm
Has anyone used the RoboRealm software? http://www.trossenrobotics.com/p/roborealm-full-license.aspx
I was just wondering if it is worth the money and if it works as stated.
You can download a free 30 day trial:
http://www.roborealm.com/registration/index.php
I think it's worth trying out if you are at all interested in this kind of stuff.
RoboRealm is pretty sweet but it depends on what you use it for. It's insanely easy to use and has a ton of built in programs.
Here's a quick kinda cheesy video, but I used it to pull video from an IP cam, then communicate via XBee back to the robot to move the camera while tracking a color blob.
Since I got it I've had robots follow sidewalks, recognize my face, and write a bunch of external programs that interface with it.
[video=youtube_share;O0-YKMfFXsI]
Here's an example of my VBScript:
Note the variable 'cog_x' and 'cog_y' they're the 'center of gravity' of the blob. The serial code is for the XBee.
Set MSComm1=CreateObject("MSCOMMLib.MSComm") MSComm1.Settings = "9600,n,8,1" MSComm1.CommPort = 7 MSComm1.InBufferCount = 0 MSComm1.PortOpen = True If Err Then MsgBox "COM" & MSComm1.CommPort & ": !" End If cogx = GetVariable("cog_x") if cogx < 120 and cogx => 26 then MSComm1.Output="4" end if if cogx < 26 then MSComm1.Output="5" end if if cogx > 200 and cogx =< 300 then MSComm1.Output="6" end if if cogx > 300 then MSComm1.Output="5" end if if cogx < 200 and cogx > 120 then MSComm1.Output="5" end if cogy = GetVariable("cog_y") if cogy < 15 then MSComm1.Output="c" end if if cogy > 180 then MSComm1.Output="c" end if if cogy < 80 and cogy => 15 then MSComm1.Output="k" MSComm1.Output="c" end if if cogy > 120 and cogy =< 180 then MSComm1.Output="i" MSComm1.Output="c" end if if cogy =< 120 and cogy => 80 then MSComm1.Output="c" end ifanother video i found-
[video=youtube_share;-1PHL7M-2GQ]
