Setting up PropPlug in linux?
rwgast_logicdesign
Im sure theres some documentation around here but i didnt see it on the bst site. Anyways I just ran bst and it cant find the prop in linux when i hit manually search the list box is empty.. So how do I get ftdi devices and bst working in linux, im using fedora at the moment if that matters.
But if I dont su before I run bst it also cant find my hardware is that common?
Look at what group owns /dev/ttyUSB0 and make sure you're a member of that group. It's probably "dialout" but I'm not sure as I don't use Ubuntu.
I'm not an Ubuntu user either, fedora 17 elecrical engineering spin all the way
As a long time Redhat/Fedora user I'm wondering what things that MS has bullied Redhat/Fedora into omitting. I know that they don't include many/any codecs but I always thought that was for copywrite, patent reasons. To my knowledge none of the major distrubutions don't include many if any codecs. The same holds with libdvdcss. Fortunately it's all fairly easy to get from other sources.
