Setting up PropPlug in linux? — Parallax Forums
rwgast_logicdesignrwgast_logicdesign Posts: 1,464
edited 2012-06-20 06:16 in Propeller 1
Im sure theres some documentation around here but i didnt see it on the bst site. Anyways I just ran bst and it cant find the prop in linux when i hit manually search the list box is empty.. So how do I get ftdi devices and bst working in linux, im using fedora at the moment if that matters.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-06-19 13:45
    It should just work. It's probably /dev/ttyUSB0 or something along those lines.
    edited 2012-06-19 17:04
    Ok well I got this worked out, turns out my 9v just didnt have enough juice in it I hate that!
    But if I dont su before I run bst it also cant find my hardware is that common?
    edited 2012-06-19 17:30
    Find the bst thread. I am sure these problems were discussed and resolved there. Probably best to search backwards if the first post doesn't help.
    edited 2012-06-19 21:40
    Look at what group owns /dev/ttyUSB0 and make sure you're a member of that group. It's probably "dialout" but I'm not sure as I don't use Ubuntu.
    edited 2012-06-20 01:50
    Hmm interesting I totally didn't even think about the permissions on the hardware.
    I'm not an Ubuntu user either, fedora 17 elecrical engineering spin all the way ;)
    edited 2012-06-20 03:41
    Ubuntu support forums are usually very helpful. I gave up on Red Hat and Fedora because M$ has been able to bully them into omitting several significant features that are easily available outside the USA. It all has to do with the fact that you don't have to prove the merit of your legal case to sue someone in the USA. So deep pockets entitles one to bully the GNU community.
  • 4x5n4x5n Posts: 747
    As a long time Redhat/Fedora user I'm wondering what things that MS has bullied Redhat/Fedora into omitting. I know that they don't include many/any codecs but I always thought that was for copywrite, patent reasons. To my knowledge none of the major distrubutions don't include many if any codecs. The same holds with libdvdcss. Fortunately it's all fairly easy to get from other sources.
