Test Automation
Does anybody use or have experience with test automation?
We're working on using GO on the PC to run scripts, send binaries, send commands, capture results, and compare for differences.
Our project is putting the propforth kernels through their paces, but it might be usable with any spin code that can output results as text.
http://forums.parallax.com/showthread.php?138399-Propforth-5.0-is-available-for-download&p=1105252&viewfull=1#post1105252
If any folks have insight or interest, I would like to get your input.
Thanks!
Thanks!
...yes, but not in the noted field.
Doesn't have to be, just looking for general input.
So I guess your experience is with hardware test automation as opposed to software test automation? Any insights or recommendations?
...lemme ponder a bit.
