$29 Walmart E-reader
http://www.walmart.com/ip/iTomic-IEBR7C-7-eBook-Reader/19887947?findingMethod=rr
At that price, I might have to get one just for the twins for their videos & music. I'd much rather have them drop that than my Nook tablet.
But for $29 seem worth it.
bean
OBC
@localroger: I did see those complaints about lack of support. I mainly want it as a disposable mp3/mp4 player, so I'm going in with low expectations.
1. It has a limited battery life.
2. Wal-mart doesn't ship internationally...
3. I already have a couple of Kindles(A third gen, and a Touch)
4. The weight of the bl**dy thing...
Most probably, they're shipping them in a fireproof metal canister because the eReadr uses Sony 'Zippo' series Li-Ion batteries...
OBC
http://news.yahoo.com/blogs/technology-blog/nook-version-war-peace-contains-embarrassing-search-replace-183348229.html
A little clunky as a web browser, but it works in a pinch. Haven't tried the ebook function yet.
It's good for at least 4 hours of continuous movie watching at moderate volume & (daylight) brightness levels. Might be even longer, but I've only tested it to 4 hours.
It comes with a nice protective case that would cost $29 alone if it were made for an iPad.
I was impressed by the iTomic's built-in text to speech app. Female voice, decent quality. It only works on eBooks so far, but it IS sold as an ereader.
Haven't found a way to watch Youtube videos on it yet. The WiFi connection is slow, though, so that may not be its forte.
BTW, battery life is up to 4.5 hours of movies and as Monty Python would say, "it's not dead yet".
i have the original nook classic with eink that you cant even tell has android on it unless youve done a ton of research. i love eink as im primarly isi g to read pdfs, the web browser is just to goofy without a touch screen.
heres what my nook does though i open a pdf set the font size to medium which is just right for my eyes. the problem is the Smile pdf software removes all pictures and tables unless the font size is small. so lets say i read the propeller manual, all the text is there but if there is a data table code example or picture i have to set the font size to small to get it to appear, the difference between small and medium is soo extreem too i have perfect vision and i cant read it on small. so basically i read things changing the font size back and forth when i can tell theres a picture or code example missing. this gets super annoying and sometimes makes it so hard to comprehend the text i give up and use my phone. if you get a chance to test some pdf files please lemme know ill sell my nook in a flash
...Goldilocks then came across 3 resistors. The first resistor was too big, it wouldn't allow enough current to flow , the second reisistor was too small and would cause too much current to flow and melt your I/O pin! Teh last reistor was just right (as youcan see by the applicaiton of Ohm's law) and it would cause just the right amount of current to flow. So goldilocks took the third resistor, soldered it in place and her LED glowed happily ever after. The End.
That said, too bad Goldilocks didn't realize that she could increase the resistance of the "too small" fixed resistor by slowly filing a triangular notch in its middle, or that she could parallel two "too big" resistors to reduce the paired resistance. Silly Goldilocks.
Good enough, order placed. The Chinese android tablet (for $99 even) died after 90 minutes, and even after 2-3 hours when turned off. The Itomic sounds like it might actually at least be useful for something portable.
OBC
But at $29, who cares? Lets see: 20 of these, or one iPad...
These could suffice as headrest video monitors in the car if you piped the sound through the car stereo.
OBC
You find more ways to help me spend my money..
OBC
That's more ways to $AVE you money...!
