EB500 Bluetooth module vs Easy Bluetooth Module
Hi folks!
I have just purchased a boe bot kit and iam thinking of using Microsoft Robotic Studio for communicating with the robot. My question is is there any different between EB500 Bluetooth Module and the Easy Bluetooth Module? I dont seem to find the EB500 Bluetooth Module for purchase, has that been discontinued?
Thanks for your answer! Do you have any idea if Microsoft Robotic Studio has support for Easy Bluetooth Module?
Okej, thanks again for the answers.
I could be wrong but I believe it does support it. I thought I had a EB500 but after looking I think it is just an EBT an dit works with MSRDS.
I thought I had a .pdf on this. Just found and uploaded as it is no longer on the Parallax site.
Thats some good news man, thanks!
Mike, Do you know if there is a way to program the EBT module to have an RTS pin? In looking at the differences in the EBT and the EB500 one of the main differences is that the EBT does not use RTS. This is pin 5 on the EB500 and is needed when trying to communicate with MSRS. Pin 5is not even an option on the EBT as it uses the even series side. It appears that pins 4-14 are not used so if there is a way to program RTS I could use one of those pins.
