Looking for a small calculator type display. LCD, 7 segment etc.
I am looking for a small LCD, 7 segment or similar display that has to show at least 4 numbers. All it will display is a number that ranges from 0 - 9999. IIt cant be back lit as in it has to look like a calculator display - any light given off by the display will cause interference with the instrument .
The size has to be under 40mm and I have to be able to buy from1 to 10K units.
Any ideas, links and comments is greatly appreciated.
http://www.mouser.com/ProductDetail/Lumex/LCD-S401C39TF/?qs=FxUKTwyvCu6TgpFBmpw%252bgI7PhA%252bc0uFKCuqpbm%2fVWQc%3d
http://www.mouser.com/ProductDetail/Lumex/LCD-S401C39TR/?qs=FxUKTwyvCu7gg9AEorxAk8A%2fedTDdXj55EFd%252bGv6aZ0%3d
Oh, nevermind. That's the same one that RobotWorkshop recommended. But which dimension has to be 40mm? The viewing area or the module size. You may be restricting yourself too much if it's the latter.
I have found some that are in China yet I would have to order 500. If I can get a sample and it works for the project then heck ill order a 1000!
good luck with your project
Electronic Goldmine LCD
Duane J
Bits, take a look at this one:
It's not 7-segment, but it will accommodate your needs with the right programming. Although it comes with a backlight, you don't need to use it, since the display is transflective.
The Lattice Pico Board I have here, has a small 4 digit LCD, 7 segment, 4 digits, Package is ~ 21mm wide x 11mm, so that is under 40mm.
It has 12 pins down one side, looks like 1.5mm pitch. No backlight (reflective?)
Given it is used on a low cost eval Board, it has to be both cheap, and available.
Edit: I'd guess it is one of the LCD-S401xx Lumex series from Mouser, 74c/1000+
http://www.nexternal.com/eink/8-x-7-p19.aspx
Phil that display, is there a object out there that could "hello world" for me? I am about to order it but dont have a lot of time for the learning curve.
Ill give it a shot. It might take me a day or two but at least its cheap and small.
Here is the search link. Look at the ones with 0.17" character height.
http://www.mouser.com/Search/Refine.aspx?Keyword=LCD-S401
Mouser quoted me a price but I have to buy 500 and wait 6 weeks. Not a big deal expect I would have liked a sample first before ordering 500 units and waiting 6 weeks, shoot my boss cant wait 2 hours for lead times.
Be sure you understand the interface requirements for the Lumex units. It's not simply digital. They're raw LCDs that require an AC drive voltage.
