Any explanation for weird memory behavior?
Why doesn't this code rotate the array? It loads up the array with the last value only. That is it it fails to copy the first element. Any ideas anyoune?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
_RED = $FF0000 '' Offer up some basic color schemes
_GREEN = $00FF00
_BLUE = $0000FF
_PINK = $FF0F0F
_LTGRN = $0FFF0F
_LTBLU = $0F0FFF
_YELLO = $FFFF00
_MAGEN = $FF00FF
_CYAN = $00FFFF
NUMLED = 50
NUMLETTER = 5
LEDPERLETTER = NUMLED/NUMLETTER
OBJ
pst : "Parallax Serial Terminal"
VAR
long RGB[NUMLED]
long colorArray[NUMLETTER + 1]
PUB LED
pst.start(115200)
setColorArray
rotateColorArray
PRI rotateColorArray | idx
long[@colorArray][NUMLETTER] := long[@colorArray][0] '' set last value in array = to first value
pst.hex(long[@colorArray][NUMLETTER], 6)
pst.char($0D)
repeat idx from 1 to (NUMLETTER ) '' rotate values down
long[@colorArray][idx-1] := long[@colorArray][idx]
PRI setColorArray
long[@colorArray][0] := _PINK
long[@colorArray][1] := _YELLO
long[@colorArray][2] := _LTGRN
long[@colorArray][3] := _BLUE
long[@colorArray][4] := _RED
pst.hex(long[@colorArray][0], 6)
pst.char($0D)
IOW, the rotation function is perfectly fine.
CON _clkmode = XTAL1|PLL16X _xinfreq = 5_000_000 _RED = $FF0000 '' Offer up some basic color schemes _GREEN = $00FF00 _BLUE = $0000FF _PINK = $FF0F0F _LTGRN = $0FFF0F _LTBLU = $0F0FFF _YELLO = $FFFF00 _MAGEN = $FF00FF _CYAN = $00FFFF NUMLED = 50 NUMLETTER = 5 LEDPERLETTER = NUMLED/NUMLETTER OBJ pst: "Parallax Serial Terminal" VAR long RGB[NUMLED] long colorArray[NUMLETTER + 1] PUB LED pst.start(115200) waitcnt(clkfreq*3 + cnt) pst.char(0) setColorArray display pst.char(13) repeat 5 rotateColorArray display PRI rotateColorArray | idx colorArray[NUMLETTER] := colorArray[0] '' set last value in array = to first value repeat idx from 1 to NUMLETTER '' rotate values down colorArray[idx-1] := colorArray[idx] PRI display | idx repeat idx from 0 to NUMLETTER-1 '' rotate values down pst.hex(colorArray[idx], 6) pst.char(32) pst.char(13) PRI setColorArray colorArray[0] := _PINK colorArray[1] := _YELLO colorArray[2] := _LTGRN colorArray[3] := _BLUE colorArray[4] := _RED DAT-Phil
Edit: I see Phil bet me to it.
D'oh!
I have a string of 50 RGB leds grouped into letters of 10 leds each. When I use the rotateColorArray routine it all turns red. Here is the complete listing. It is really baffling to me because it should be working.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 DQ = 0 '' Set WS2801 Data Pin CLK = 1 '' Set WS2801 Clock Pin _RED = $FF0000 '' Offer up some basic color schemes _GREEN = $00FF00 _BLUE = $0000FF _PINK = $FF0F0F _LTGRN = $0FFF0F _LTBLU = $0F0FFF _YELLO = $FFFF00 _MAGEN = $FF00FF _CYAN = $00FFFF NUMLED = 50 NUMLETTER = 5 LEDPERLETTER = NUMLED/NUMLETTER OBJ SPI : "SPI_Asm" ''The Standalone SPI Assembly engine pst : "Parallax Serial Terminal" VAR long RGB[NUMLED] long colorArray[NUMLETTER + 1] PUB LED | char '' -----[ Initialization ]-------------------------------------------------- ''Serial communication Setup pst.start(115200) '' Initialize serial communication to the PC through the USB connector '' To view Serial data on the PC use the Parallax Serial Terminal (PST) program. SPI.start(1,0) '' Initialize SPI Engine with Clock Delay of 15 and Clock State of 1 waitcnt(cnt+clkfreq*10/1000) '' Pause for 10ms repeat pst.char(pst#CS) pst.str(string("0 to reset color array, 1 to rotate array")) char := pst.charin case char "0": setColorArray letterColor loadLED "1": rotateColorArray letterColor loadLED PRI letterColor | letter, idx repeat letter from 0 to NUMLETTER-1 longfill(@RGB + letter * LEDPERLETTER * 4, colorArray[letter], LEDPERLETTER) PRI rotateColorArray | temp temp := colorArray[0] longmove(@colorArray, @colorArray[1], NUMLETTER-1) colorArray[NUMLETTER] := temp PRI setColorArray colorArray[0] := _PINK colorArray[1] := _YELLO colorArray[2] := _LTGRN colorArray[3] := _BLUE colorArray[4] := _RED PRI loadLED | idx repeat idx from 0 to NUMLED - 1 SPI.SHIFTOUT(DQ, CLK, SPI#MSBFIRST , 24, RGB[idx]) ''send color valuesI don't know if that's the only problem, but it should help.
I really appreciate you guys who help out. You have talent and share it willingly: a great and rare commodity these days.
Why did that work? The dimension of colorArray is NUMLETTER + 1, so the last element is colorArray[NUMLETTER].
I didn't notice the size was "+1".
But since only 4 elements had been shifted (from 1 through 4 to 0 through 3), then element #4 is the one I thought was supposed to receive the value from (the previous) element #0.
You may have been thinking about strings, which are byte arrays whose size needs to be one greater than the number of actual characters, in order to accommodate the zero termination byte.
I need a strategy for fadeLED(@RGB, @RGB2).
PUB led letterColor(@RGB2) ' store color values in RGB2 rotateColorArray ' rotate the color sequence letterColor(@RGB) ' store new sequence in RGB fadeLED(@RGB, @RGB2) ' SHIFTOUT routine to transition letters to new color values PRI fadeLED(ledArray1, ledArray2) | idx1, idx2, delta repeat idx1 from 0 to 20 ' start with twenty step trasnition repeat idx2 from 0 to NUMLED - 1 delta := (ledArray1[idx2] - ledArray2[idx2]) / 20 ledArray2[idx2] += delta SPI.SHIFTOUT(DQ, CLK, SPI#MSBFIRST , 24, ledArray2[idx2]) ''send color values PRI letterColor(ledPtr) | letter, idx repeat letter from 0 to NUMLETTER-1 longfill(ledPtr + letter * LEDPERLETTER * 4, colorArray[letter], LEDPERLETTER) PRI rotateColorArray | temp temp := colorArray[0] longmove(@colorArray, @colorArray[1], NUMLETTER-1) colorArray[NUMLETTER-1] := tempIt is not clear to me what the most aesthetic traverse of color space would be. Here is my attempt at it but it washes out color.
PRI fadeLED(inc) | idx1, idx2, r1, g1 ,b1, r2, g2, b2 repeat idx1 from 0 to inc ' start with twenty step transition waitcnt(clkfreq / 5 + cnt) repeat idx2 from 0 to NUMLED - 1 r1 := ((RGB[idx2]>>16)& $FF) g1 := ((RGB[idx2]>>8)& $FF) b1 := (RGB[idx2] & $FF) r2 := ((RGB2[idx2]>>16)& $FF) g2 := ((RGB2[idx2]>>8)& $FF) b2 := (RGB2[idx2] & $FF) r2 += (r1-r2) / inc g2 += (g1-g2) / inc b2 += (b1-b2) / inc RGB2[idx2] := r2<<16 | g2<<8 | b2 SPI.SHIFTOUT(DQ, CLK, SPI#MSBFIRST , 24, RGB2[idx2]) ''send color values
