Parallax standard servo and DX6i
Guys
I have just purchased a Parallax standard servo (180 Degree rotation) however when I connect it to my Rx it only turns about 90 degrees even with all of my travel adjust set to max.
What am I missing?
Steve
What am I missing?
Steve
I just found my Parallax standard servo and I'll test it out and let your now what I find in a bit.
When I used very extreme ranges of 300us to 2492us the servo's rotation was much greater. I think it reached 180 degrees of rotation. I didn't think it rotated a full 180 degrees as I was making the video but when I played the video back, it looked like it was rotating a full 180 degrees.
[video=youtube_share;2EhV6xG0nIY]
YouTube says the upload will take another 14 minutes so check back in a bit to see the rotation for yourself.
Here's the link to the servo tesing software I was using.
So basically, these servos can rotate 180 degrees but you'll likely need a microcontroller to get them to do it.
Steve
