Transit of Venus tomorrow
The last transit of Venus for a century is tomorrow from 6:04 PM EDT to sunset. Back in 2004 I saw the transit of Venus at sunrise and it was pretty neat. What you see is a tiny intensely black dot against the surface of the sun. To view it helps to have a telescope equipped with a special filter. But lower tech approaches like a pair of eclipse glasses or pinhole projection will work. Heres more information:
http://www.transitofvenus.org/june2012/eye-safety/281-six-ways-to-see-the-transit-of-venus
Back in the mid 90s I watched an eclipse using pinhole projection and it worked surprisingly well.
Hopefully the weather will cooperate where you are.
I will be doing the same thing as for the annular solar eclipse a couple of weeks ago.
It will start at 5:05pm central time hear in Minnesota and goes till sunset.
I will get a better image for a longer time than eastern sites.
The further west the better, sorry Martin %^(
I use a 10x50 binocular on a tripod with a pair of holes used as a sun blocker.
The projection screen is a white cardboard box cover.
Since sunspots are easy to see, I saw 3 sets during the eclipse, Venus will be a snap.
Duane J
http://science.nasa.gov/science-news/science-at-nasa/2012/04jun_arcofvenus/
Amanda
-Phi;
t
The coating is precisely deposited on the film and is robust enough to prevent scratches.
The film thickness is very precisely controlled so it doesn't cause optical distortion.
The metallization is highly reflective especially in the infrared and ultraviolet for safety reasons.
The film doesn't even get warm.
You can buy it "raw" for use in your holder
or already mounted in a kind of cap to be placed over the telescope or binoculars.
This type of filter is quite safe as bright sunlight never enters the instrument.
When I was a kid I had a sun filter that was placed in front of the eyepiece.
This got quite hot and was very dangerous. OK, it never cracked for me but was not safe.
Basically keep the heat out in the first place.
Another method was to use a "Hershel Wedge".
http://en.wikipedia.org/wiki/Herschel_wedge
I used one of these many times but the heat still entered the telescope.
The modern film types is clearly the best method.
Another method is to use number #14 welding lenses.
Quite safe to use and cheap. Although optically not quite as good as they are made from float glass.
Outside of the welding lens, there are no reputable safe "home" alternatives.
Projection methods work very well and are safe.
Duane J
Even if they don't meet your expectations, please post a couple. I'd be very interested!
Thanks for the pointer. It looks like we're going to get rained out here as well. Too bad I was hoping to show my kids, but a video feed will have to do.
Mine is a full aperture solar filter made for the purpose. If I didn't have one I would use either eyepiece projection (on a scope I didn't care about) or pinhole projection. I wouldn't try to improvise because you can't get new eyes. When I was in high school I had a cheap dime store scope with an eye piece filter. I shudder to think of the risk I took because I didn't know how risky those were.
Pinhole projection works better than you would think. When I was in high school I used it to draw pictures of sunspots and measure the solar diameter. I also used it to view a solar eclipse back in the 90's before I got my solar filter.
Google - Viewing Venus Safely and read up on building a pin hole camera.
See "The Sunspot Projection Experiment" towards the end of this link...
http://users.erols.com/njastro/barry/pages/pinhole.htm
There is a piece of pinkish gel on the objective lens, otherwise the image was too bright for comfort or for the camera.
South San Francisco bay area, somewhere between 5:45 and 6:00PM, give or take.
Next thing to do on list: Travel there. Maybe science and technology in the near future will make this faster.
