Better ways to write repeated code
Hi
I am working on a barometric trend display Object. It works well but I can't help thinking that the code is way too long. Can anyone help on ways to streamline some of the lengthy tests etc?
Richard
Richard
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
ALTITUDE = 145 'Your altitude in metres ASL
'EEPROM locations for hourly observations
R0 = $9003
R1 = $9007
R2 = $900b
R3 = $900f
R4 = $9013
R5 = $9017
R6 = $901b
R7 = $901f
R8 = $9023
R9 = $9027
R10 = $902b
R11 = $902f
R12 = $9033
R13 = $9037
R14 = $903b
R15 = $903f
R16 = $9043
R17 = $9047
R18 = $904b
R19 = $904f
R20 = $9053
R21 = $9057
R22 = $905b
R23 = $905f
Time = $9063
'Flag for initial boot detection
Flag = $9067
'Storage for trend values
T3 = $906b
T1 = $906f
Ti = $9073
'By Richard Newstead, G3CWI, June 2012
OBJ
bar : "29124_altimeter"
rtc : "DS1302_full"
SN : "Simple_Numbers"
DEBUG : "Debug_LCD03"
EEPROM: "I2C_ROMEngine"
Var
byte hour, minute, second
Long time_long,Trend3,Trend1,Trendi
PUB Start 'Start everything running
rtc.init( 4, 5, 6 ) 'define ports for Real Time Clock
bar.start_explicit( 0, 1, true )
bar.set_resolution( bar#highest ) 'Set to highest resolution.
DEBUG.start( 15, 9600, 4 ) '4 lines serial LCD
EEPROM.ROMEngineStart( 29, 28, 0 )
Initialise_EEPROM
Main
Pub Main | p
DEBUG.CLS
DEBUG.Backlight(true)
DEBUG.Cursor(0)
Display
repeat
rtc.readTime( @hour, @minute, @second ) 'read time from DS1302
'Update everything once a minute
IF minute<>EEPROM.ReadLong(Time)
p := bar.average_press 'Get the average pressure.
EEPROM.WriteLong(Time, minute) 'Store time
time_long := hour * 10000 + minute * 100 + second 'Concatenate
'Store hourly readings
Case time_long
000000:EEPROM.WriteLong(R0, p)
010000:EEPROM.WriteLong(R1, p)
020000:EEPROM.WriteLong(R2, p)
030000:EEPROM.WriteLong(R3, p)
040000:EEPROM.WriteLong(R4, p)
050000:EEPROM.WriteLong(R5, p)
060000:EEPROM.WriteLong(R6, p)
070000:EEPROM.WriteLong(R7, p)
080000:EEPROM.WriteLong(R8, p)
090000:EEPROM.WriteLong(R9, p)
100000:EEPROM.WriteLong(R10, p)
110000:EEPROM.WriteLong(R11, p)
120000:EEPROM.WriteLong(R12, p)
130000:EEPROM.WriteLong(R13, p)
140000:EEPROM.WriteLong(R14, p)
150000:EEPROM.WriteLong(R15, p)
160000:EEPROM.WriteLong(R16, p)
170000:EEPROM.WriteLong(R17, p)
180000:EEPROM.WriteLong(R18, p)
190000:EEPROM.WriteLong(R19, p)
200000:EEPROM.WriteLong(R20, p)
210000:EEPROM.WriteLong(R21, p)
220000:EEPROM.WriteLong(R22, p)
230000:EEPROM.WriteLong(R23, p)
'Using obs, calculate 3 hour trend
Case time_long
000001..010000:Trend3:=EEProm.Readlong(R0)- EEProm.Readlong(R21)
010001..020000:Trend3:=EEProm.Readlong(R1)- EEProm.Readlong(R22)
020001..030000:Trend3:=EEProm.Readlong(R2)- EEProm.Readlong(R23)
030001..040000:Trend3:=EEProm.Readlong(R3)- EEProm.Readlong(R0)
040001..050000:Trend3:=EEProm.Readlong(R4)- EEProm.Readlong(R1)
050001..060000:Trend3:=EEProm.Readlong(R5)- EEProm.Readlong(R2)
060001..070000:Trend3:=EEProm.Readlong(R6)- EEProm.Readlong(R3)
070001..080000:Trend3:=EEProm.Readlong(R7)- EEProm.Readlong(R4)
080001..090000:Trend3:=EEProm.Readlong(R8)- EEProm.Readlong(R5)
090001..100000:Trend3:=EEProm.Readlong(R9)- EEProm.Readlong(R6)
100001..110000:Trend3:=EEProm.Readlong(R10)-EEProm.Readlong(R7)
110001..120000:Trend3:=EEProm.Readlong(R11)-EEProm.Readlong(R8)
120001..130000:Trend3:=EEProm.Readlong(R12)-EEProm.Readlong(R9)
130001..140000:Trend3:=EEProm.Readlong(R13)-EEProm.Readlong(R10)
140001..150000:Trend3:=EEProm.Readlong(R14)-EEProm.Readlong(R11)
150001..160000:Trend3:=EEProm.Readlong(R15)-EEProm.Readlong(R12)
160001..170000:Trend3:=EEProm.Readlong(R16)-EEProm.Readlong(R13)
170001..180000:Trend3:=EEProm.Readlong(R17)-EEProm.Readlong(R14)
180001..190000:Trend3:=EEProm.Readlong(R18)-EEProm.Readlong(R15)
190001..200000:Trend3:=EEProm.Readlong(R19)-EEProm.Readlong(R16)
200001..210000:Trend3:=EEProm.Readlong(R20)-EEProm.Readlong(R17)
210001..220000:Trend3:=EEProm.Readlong(R21)-EEProm.Readlong(R18)
220001..230000:Trend3:=EEProm.Readlong(R22)-EEProm.Readlong(R19)
230001..000000:Trend3:=EEProm.Readlong(R23)-EEProm.Readlong(R20)
'Using obs, calculate 1 hour trend
Case time_long
000001..010000:Trend1:=EEProm.Readlong(R0)- EEProm.Readlong(R23)
010001..020000:Trend1:=EEProm.Readlong(R1)- EEProm.Readlong(R0)
020001..030000:Trend1:=EEProm.Readlong(R2)- EEProm.Readlong(R1)
030001..040000:Trend1:=EEProm.Readlong(R3)- EEProm.Readlong(R2)
040001..050000:Trend1:=EEProm.Readlong(R4)- EEProm.Readlong(R3)
050001..060000:Trend1:=EEProm.Readlong(R5)- EEProm.Readlong(R4)
060001..070000:Trend1:=EEProm.Readlong(R6)- EEProm.Readlong(R5)
070001..080000:Trend1:=EEProm.Readlong(R7)- EEProm.Readlong(R6)
080001..090000:Trend1:=EEProm.Readlong(R8)- EEProm.Readlong(R7)
090001..100000:Trend1:=EEProm.Readlong(R9)- EEProm.Readlong(R8)
100001..110000:Trend1:=EEProm.Readlong(R10)-EEProm.Readlong(R9)
110001..120000:Trend1:=EEProm.Readlong(R11)-EEProm.Readlong(R10)
120001..130000:Trend1:=EEProm.Readlong(R12)-EEProm.Readlong(R11)
130001..140000:Trend1:=EEProm.Readlong(R13)-EEProm.Readlong(R12)
140001..150000:Trend1:=EEProm.Readlong(R14)-EEProm.Readlong(R13)
150001..160000:Trend1:=EEProm.Readlong(R15)-EEProm.Readlong(R14)
160001..170000:Trend1:=EEProm.Readlong(R16)-EEProm.Readlong(R15)
170001..180000:Trend1:=EEProm.Readlong(R17)-EEProm.Readlong(R16)
180001..190000:Trend1:=EEProm.Readlong(R18)-EEProm.Readlong(R17)
190001..200000:Trend1:=EEProm.Readlong(R19)-EEProm.Readlong(R18)
200001..210000:Trend1:=EEProm.Readlong(R20)-EEProm.Readlong(R19)
210001..220000:Trend1:=EEProm.Readlong(R21)-EEProm.Readlong(R20)
220001..230000:Trend1:=EEProm.Readlong(R22)-EEProm.Readlong(R21)
230001..000000:Trend1:=EEProm.Readlong(R23)-EEProm.Readlong(R22)
Case time_long
000001..010000:Trendi:=p-EEProm.Readlong(R23)
010001..020000:Trendi:=p-EEProm.Readlong(R0 )
020001..030000:Trendi:=p-EEProm.Readlong(R1 )
030001..040000:Trendi:=p-EEProm.Readlong(R2 )
040001..050000:Trendi:=p-EEProm.Readlong(R3 )
050001..060000:Trendi:=p-EEProm.Readlong(R4 )
060001..070000:Trendi:=p-EEProm.Readlong(R5 )
070001..080000:Trendi:=p-EEProm.Readlong(R6 )
080001..090000:Trendi:=p-EEProm.Readlong(R7 )
090001..100000:Trendi:=p-EEProm.Readlong(R8 )
100001..110000:Trendi:=p-EEProm.Readlong(R9 )
110001..120000:Trendi:=p-EEProm.Readlong(R10)
120001..130000:Trendi:=p-EEProm.Readlong(R11)
130001..140000:Trendi:=p-EEProm.Readlong(R12)
140001..150000:Trendi:=p-EEProm.Readlong(R13)
150001..160000:Trendi:=p-EEProm.Readlong(R14)
160001..170000:Trendi:=p-EEProm.Readlong(R15)
170001..180000:Trendi:=p-EEProm.Readlong(R16)
180001..190000:Trendi:=p-EEProm.Readlong(R17)
190001..200000:Trendi:=p-EEProm.Readlong(R18)
200001..210000:Trendi:=p-EEProm.Readlong(R19)
210001..220000:Trendi:=p-EEProm.Readlong(R20)
220001..230000:Trendi:=p-EEProm.Readlong(R21)
230001..000000:Trendi:=p-EEProm.Readlong(R22)
'Write trends to EEPROM so preserved in case of power down
EEPROM.WriteLong(T3,Trend3)
EEPROM.WriteLong(T1,Trend1)
EEPROM.WriteLong(Ti,Trendi)
Display
Pub Display | sp, cm, p
cm := ALTITUDE * 100
sp := bar.sealevel_press(p, cm)
DEBUG.cls
DEBUG.str(string("QNH :")) 'Print sea-level pressure heading.
DEBUG.str(bar.formatn(sp, bar#MILLIBARS | bar#CECR, 6)) ' Print sea-level pressure in millibars, clear-to-end, and CR.
DEBUG.nl
'Print medium-term trend narrative
Debug.Str(string("3hr :"))
Case EEPROM.Readlong(T3)
-9999..-600:Debug.Str(string("Very rapid fall"))
-599..-360 :Debug.Str(string("Falling rapidly"))
-359..-160 :Debug.Str(string("Falling"))
-159..-10 :Debug.Str(string("Falling slowly"))
-9..9 :Debug.Str(string("Steady"))
10..159 :Debug.Str(string("Rising slowly"))
160..359 :Debug.Str(string("Rising"))
360..600 :Debug.Str(string("Rising rapidly"))
600..9999 :Debug.Str(string("Very rapid rise"))
Other :Debug.Str(string("Error"))
DEBUG.nl
'Print short-term trend narrative
Debug.Str(string("1hr :"))
Case EEPROM.Readlong(T1)
DEBUG.nl
'Print instantaneous trend narrative
Debug.Str(string("inst:"))
Case EEPROM.Readlong(Ti)
Pri Initialise_EEPROM | p
'Fill EEPROM with default data
'if not already filled
If EEPROM.Readlong(Flag)<>$5555 'check fill flag
EEPROM.WriteLong(Flag,$5555)
'get starting minutes and store
could be something like
repeat a from 0 to ?? 'spin syntax a little rusty here
EEPROM.WriteLong(($9003+a), p)
And just for argument sake I would have longs start at long boundaries, so
Not sure if it is needed, but old habits die hard
Your algorithm ought to be able to handle any number of hours. From two to thousands (assuming you have the memeory to store the data).
You might want to include some out of bound checks if you make the number of samples easy to change (by changing a constant at the beginning of the program).
Just got around to implementing these changes. Thanks for the ideas.
Cheers
Richard
This is in the CON method: is there a more elegant way of defining these locations?
Cheers
Richard
Remember that I am very dim. I guess that is a method? i.e.
If so, I am guessing that you don't think that I need to define the locations in the Con block at all?
Or have I missed the point entirely?
Cheers
Richard
[Edit - I am begining to think that is exactly what you mean. There is really no need to define the locations]
{A trending barometer using the Parallax Barometer modules and a generic Real Time Clock module. Uses a serial 4 x 20 serial LCD to display: - Current Pressure - 3 hour tend (narrative) - 1 hour tred (narrative) - instantaneous trend (narrative) By Richard Newstead, G3CWI, June 2012} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ALTITUDE = 145 'Your altitude in metres ASL 'Define some EEPROM storage locations 'Note $9000 to $905C reserved Time = $9060 'Storage for trend values T3 = $9064 T1 = $9068 Ti = $906c 'Flag for initial boot detection Flag = $9070 OBJ bar : "29124_altimeter" rtc : "DS1302_full" SN : "Simple_Numbers" DEBUG : "Debug_LCD03" EEPROM: "I2C_ROMEngine" Var byte hour, minute, second Long time_long,Trend3,Trend1,Trendi PUB Start | temp 'Start everything running rtc.init( 4, 5, 6 ) 'define ports for Real Time Clock bar.start_explicit( 0, 1, true ) bar.set_resolution( bar#highest ) 'Set to highest resolution. DEBUG.start( 15, 9600, 4 ) '4 lines serial LCD EEPROM.ROMEngineStart( 29, 28, 0 ) Initialise_EEPROM Main Pub Main | p DEBUG.CLS DEBUG.Backlight(true) DEBUG.Cursor(0) Display repeat rtc.readTime( @hour, @minute, @second ) 'read time from DS1302 'Update everything once a minute IF minute<>EEPROM.ReadLong(Time) p := bar.average_press 'Get the average pressure. EEPROM.WriteLong(Time, minute) time_long := hour * 10000 + minute * 100 + second 'Concatenate 'Store hourly readings If minute := 0 and second :=0 EEPROM.WriteLong($9000+hour*4, p) 'Using obs, calculate 3 hour trend and store Trend3 := EEPROM.ReadLong($9000+hour*4) - EEPROM.ReadLong($9000 +((hour+21)//24)*4) EEPROM.WriteLong(T3,Trend3) 'Using obs, calculate 1 hour trend and store Trend1 := EEPROM.ReadLong($9000+hour*4) - EEPROM.ReadLong($9000 +((hour+23)//24)*4) EEPROM.WriteLong(T1,Trend1) 'Using obs, calculate instantaneous trend and store Trendi := p - EEPROM.ReadLong($9000 +((hour+23)//24)*4) EEPROM.WriteLong(Ti,Trendi) Display Pub Display | sp, cm, p p := bar.average_press cm := ALTITUDE * 100 sp := bar.sealevel_press(p, cm) DEBUG.cls DEBUG.str(string("QNH :")) 'Print sea-level pressure heading. DEBUG.str(bar.formatn(sp, bar#MILLIBARS | bar#CECR, 6)) ' Print sea-level pressure in millibars, clear-to-end, and CR. DEBUG.nl 'Print medium-term trend narrative Debug.Str(string("3hr :")) Trend_Test(EEPROM.ReadLong(T3)) 'Print short-term trend narrative Debug.Str(string("1hr :")) Trend_Test(EEPROM.ReadLong(T1)) 'Print instantaneous trend narrative Debug.Str(string("inst:")) Trend_Test(EEPROM.ReadLong(Ti)) Pri Initialise_EEPROM | p, Loc 'Fill EEPROM with default data 'if not already filled p := bar.average_press If EEPROM.Readlong(Flag)<>$5555 'check fill flag Repeat Loc from $9000 to $905c step 4 EEPROM.WriteLong (Loc, p) EEPROM.WriteLong(Flag,$5555) 'get starting minutes and store rtc.readTime( @hour, @minute, @second ) EEPROM.WriteLong(Time, minute) Pri Trend_Test (Trend) Case Trend -9999..-600:Debug.Str(string("Very rapid fall")) -599..-360 :Debug.Str(string("Falling rapidly")) -359..-160 :Debug.Str(string("Falling")) -159..-10 :Debug.Str(string("Falling slowly")) -9..9 :Debug.Str(string("Steady")) 10..159 :Debug.Str(string("Rising slowly")) 160..359 :Debug.Str(string("Rising")) 360..600 :Debug.Str(string("Rising rapidly")) 600..9999 :Debug.Str(string("Very rapid rise")) Other :Debug.Str(string("Error")) Debug.nlThanks for all the help - this has been a very useful learning exercise.
Added to OBEX:http://obex.parallax.com/objects/868/[URL="http://obex.parallax.com/objects/868/]"]
[/URL]
Cheers
Richard
You can make some optimizations, limiting the number of reads/writes from/to the EEPROM:
1) Read the needed values first, and then calculate the trends.
2) Trend1 and Trend3 only need to be re-calculated and written when you write the new hourly value.
like this:
'Using obs, calculate instantaneous trend and store hour1 := EEPROM.ReadLong($9000 +((hour+23)//24)*4) EEPROM.WriteLong(Ti,p-hour1) If minute := 0 and second :=0 EEPROM.WriteLong($9000+hour*4, p) 'Using obs, calculate 3 hour trend and store hour3 := EEPROM.ReadLong($9000 +((hour+21)//24)*4) EEPROM.WriteLong(T3,p-hour3) 'Using obs, calculate 1 hour trend and store EEPROM.WriteLong(T1,p-hour1)
