Better ways to write repeated code — Parallax Forums
g3cwig3cwi Posts: 262
edited 2012-06-07 14:19 in Propeller 1
Hi
I am working on a barometric trend display Object. It works well but I can't help thinking that the code is way too long. Can anyone help on ways to streamline some of the lengthy tests etc?
Richard
CON
  _clkmode      = xtal1 + pll16x
  _xinfreq      = 5_000_000
  ALTITUDE      = 145 'Your altitude in metres ASL
  'EEPROM locations for hourly observations
  R0   = $9003
  R1   = $9007
  R2   = $900b
  R3   = $900f
  R4   = $9013
  R5   = $9017
  R6   = $901b
  R7   = $901f
  R8   = $9023
  R9   = $9027
  R10  = $902b
  R11  = $902f
  R12  = $9033
  R13  = $9037
  R14  = $903b
  R15  = $903f
  R16  = $9043
  R17  = $9047
  R18  = $904b
  R19  = $904f
  R20  = $9053
  R21  = $9057
  R22  = $905b
  R23  = $905f
  Time = $9063
  'Flag for initial boot detection
  Flag = $9067
  'Storage for trend values
  T3   = $906b
  T1   = $906f
  Ti   = $9073
'By Richard Newstead, G3CWI, June 2012
OBJ
  bar   : "29124_altimeter"
  rtc   : "DS1302_full"
  SN    : "Simple_Numbers"
  DEBUG : "Debug_LCD03"
  EEPROM: "I2C_ROMEngine"
Var
  byte hour, minute, second
  Long time_long,Trend3,Trend1,Trendi
PUB Start 'Start everything running
  rtc.init( 4, 5, 6 ) 'define ports for Real Time Clock
  bar.start_explicit( 0, 1, true )
  bar.set_resolution( bar#highest )  'Set to highest resolution.
  DEBUG.start( 15, 9600, 4 ) '4 lines serial LCD
  EEPROM.ROMEngineStart( 29, 28, 0 )
  Initialise_EEPROM
  Main
Pub Main | p
  DEBUG.CLS
  DEBUG.Backlight(true)
  DEBUG.Cursor(0)
  Display
  repeat
    rtc.readTime( @hour, @minute, @second )  'read time from DS1302
    'Update everything once a minute
    IF minute<>EEPROM.ReadLong(Time)
      p  := bar.average_press 'Get the average pressure.
      EEPROM.WriteLong(Time, minute) 'Store time
      time_long := hour * 10000 + minute * 100 + second 'Concatenate
        'Store hourly readings
        Case time_long
          000000:EEPROM.WriteLong(R0,  p)
          010000:EEPROM.WriteLong(R1,  p)
          020000:EEPROM.WriteLong(R2,  p)
          030000:EEPROM.WriteLong(R3,  p)
          040000:EEPROM.WriteLong(R4,  p)
          050000:EEPROM.WriteLong(R5,  p)
          060000:EEPROM.WriteLong(R6,  p)
          070000:EEPROM.WriteLong(R7,  p)
          080000:EEPROM.WriteLong(R8,  p)
          090000:EEPROM.WriteLong(R9,  p)
          100000:EEPROM.WriteLong(R10, p)
          110000:EEPROM.WriteLong(R11, p)
          120000:EEPROM.WriteLong(R12, p)
          130000:EEPROM.WriteLong(R13, p)
          140000:EEPROM.WriteLong(R14, p)
          150000:EEPROM.WriteLong(R15, p)
          160000:EEPROM.WriteLong(R16, p)
          170000:EEPROM.WriteLong(R17, p)
          180000:EEPROM.WriteLong(R18, p)
          190000:EEPROM.WriteLong(R19, p)
          200000:EEPROM.WriteLong(R20, p)
          210000:EEPROM.WriteLong(R21, p)
          220000:EEPROM.WriteLong(R22, p)
          230000:EEPROM.WriteLong(R23, p)
        'Using obs, calculate 3 hour trend
        Case time_long
          000001..010000:Trend3:=EEProm.Readlong(R0)- EEProm.Readlong(R21)
          010001..020000:Trend3:=EEProm.Readlong(R1)- EEProm.Readlong(R22)
          020001..030000:Trend3:=EEProm.Readlong(R2)- EEProm.Readlong(R23)
          030001..040000:Trend3:=EEProm.Readlong(R3)- EEProm.Readlong(R0)
          040001..050000:Trend3:=EEProm.Readlong(R4)- EEProm.Readlong(R1)
          050001..060000:Trend3:=EEProm.Readlong(R5)- EEProm.Readlong(R2)
          060001..070000:Trend3:=EEProm.Readlong(R6)- EEProm.Readlong(R3)
          070001..080000:Trend3:=EEProm.Readlong(R7)- EEProm.Readlong(R4)
          080001..090000:Trend3:=EEProm.Readlong(R8)- EEProm.Readlong(R5)
          090001..100000:Trend3:=EEProm.Readlong(R9)- EEProm.Readlong(R6)
          100001..110000:Trend3:=EEProm.Readlong(R10)-EEProm.Readlong(R7)
          110001..120000:Trend3:=EEProm.Readlong(R11)-EEProm.Readlong(R8)
          120001..130000:Trend3:=EEProm.Readlong(R12)-EEProm.Readlong(R9)
          130001..140000:Trend3:=EEProm.Readlong(R13)-EEProm.Readlong(R10)
          140001..150000:Trend3:=EEProm.Readlong(R14)-EEProm.Readlong(R11)
          150001..160000:Trend3:=EEProm.Readlong(R15)-EEProm.Readlong(R12)
          160001..170000:Trend3:=EEProm.Readlong(R16)-EEProm.Readlong(R13)
          170001..180000:Trend3:=EEProm.Readlong(R17)-EEProm.Readlong(R14)
          180001..190000:Trend3:=EEProm.Readlong(R18)-EEProm.Readlong(R15)
          190001..200000:Trend3:=EEProm.Readlong(R19)-EEProm.Readlong(R16)
          200001..210000:Trend3:=EEProm.Readlong(R20)-EEProm.Readlong(R17)
          210001..220000:Trend3:=EEProm.Readlong(R21)-EEProm.Readlong(R18)
          220001..230000:Trend3:=EEProm.Readlong(R22)-EEProm.Readlong(R19)
          230001..000000:Trend3:=EEProm.Readlong(R23)-EEProm.Readlong(R20)
        'Using obs, calculate 1 hour trend
        Case time_long
          000001..010000:Trend1:=EEProm.Readlong(R0)- EEProm.Readlong(R23)
          010001..020000:Trend1:=EEProm.Readlong(R1)- EEProm.Readlong(R0)
          020001..030000:Trend1:=EEProm.Readlong(R2)- EEProm.Readlong(R1)
          030001..040000:Trend1:=EEProm.Readlong(R3)- EEProm.Readlong(R2)
          040001..050000:Trend1:=EEProm.Readlong(R4)- EEProm.Readlong(R3)
          050001..060000:Trend1:=EEProm.Readlong(R5)- EEProm.Readlong(R4)
          060001..070000:Trend1:=EEProm.Readlong(R6)- EEProm.Readlong(R5)
          070001..080000:Trend1:=EEProm.Readlong(R7)- EEProm.Readlong(R6)
          080001..090000:Trend1:=EEProm.Readlong(R8)- EEProm.Readlong(R7)
          090001..100000:Trend1:=EEProm.Readlong(R9)- EEProm.Readlong(R8)
          100001..110000:Trend1:=EEProm.Readlong(R10)-EEProm.Readlong(R9)
          110001..120000:Trend1:=EEProm.Readlong(R11)-EEProm.Readlong(R10)
          120001..130000:Trend1:=EEProm.Readlong(R12)-EEProm.Readlong(R11)
          130001..140000:Trend1:=EEProm.Readlong(R13)-EEProm.Readlong(R12)
          140001..150000:Trend1:=EEProm.Readlong(R14)-EEProm.Readlong(R13)
          150001..160000:Trend1:=EEProm.Readlong(R15)-EEProm.Readlong(R14)
          160001..170000:Trend1:=EEProm.Readlong(R16)-EEProm.Readlong(R15)
          170001..180000:Trend1:=EEProm.Readlong(R17)-EEProm.Readlong(R16)
          180001..190000:Trend1:=EEProm.Readlong(R18)-EEProm.Readlong(R17)
          190001..200000:Trend1:=EEProm.Readlong(R19)-EEProm.Readlong(R18)
          200001..210000:Trend1:=EEProm.Readlong(R20)-EEProm.Readlong(R19)
          210001..220000:Trend1:=EEProm.Readlong(R21)-EEProm.Readlong(R20)
          220001..230000:Trend1:=EEProm.Readlong(R22)-EEProm.Readlong(R21)
          230001..000000:Trend1:=EEProm.Readlong(R23)-EEProm.Readlong(R22)
        Case time_long
          000001..010000:Trendi:=p-EEProm.Readlong(R23)
          010001..020000:Trendi:=p-EEProm.Readlong(R0 )
          020001..030000:Trendi:=p-EEProm.Readlong(R1 )
          030001..040000:Trendi:=p-EEProm.Readlong(R2 )
          040001..050000:Trendi:=p-EEProm.Readlong(R3 )
          050001..060000:Trendi:=p-EEProm.Readlong(R4 )
          060001..070000:Trendi:=p-EEProm.Readlong(R5 )
          070001..080000:Trendi:=p-EEProm.Readlong(R6 )
          080001..090000:Trendi:=p-EEProm.Readlong(R7 )
          090001..100000:Trendi:=p-EEProm.Readlong(R8 )
          100001..110000:Trendi:=p-EEProm.Readlong(R9 )
          110001..120000:Trendi:=p-EEProm.Readlong(R10)
          120001..130000:Trendi:=p-EEProm.Readlong(R11)
          130001..140000:Trendi:=p-EEProm.Readlong(R12)
          140001..150000:Trendi:=p-EEProm.Readlong(R13)
          150001..160000:Trendi:=p-EEProm.Readlong(R14)
          160001..170000:Trendi:=p-EEProm.Readlong(R15)
          170001..180000:Trendi:=p-EEProm.Readlong(R16)
          180001..190000:Trendi:=p-EEProm.Readlong(R17)
          190001..200000:Trendi:=p-EEProm.Readlong(R18)
          200001..210000:Trendi:=p-EEProm.Readlong(R19)
          210001..220000:Trendi:=p-EEProm.Readlong(R20)
          220001..230000:Trendi:=p-EEProm.Readlong(R21)
          230001..000000:Trendi:=p-EEProm.Readlong(R22)
    'Write trends to EEPROM so preserved in case of power down
      EEPROM.WriteLong(T3,Trend3)
      EEPROM.WriteLong(T1,Trend1)
      EEPROM.WriteLong(Ti,Trendi)
      Display
Pub Display | sp, cm, p
      cm := ALTITUDE * 100
      sp := bar.sealevel_press(p, cm)
      DEBUG.cls
      DEBUG.str(string("QNH :")) 'Print sea-level pressure heading.
      DEBUG.str(bar.formatn(sp, bar#MILLIBARS | bar#CECR, 6))   ' Print sea-level pressure in millibars, clear-to-end, and CR.
      DEBUG.nl
         'Print medium-term trend narrative
        Debug.Str(string("3hr :"))
        Case EEPROM.Readlong(T3)
          -9999..-600:Debug.Str(string("Very rapid fall"))
          -599..-360 :Debug.Str(string("Falling rapidly"))
          -359..-160 :Debug.Str(string("Falling"))
          -159..-10  :Debug.Str(string("Falling slowly"))
          -9..9      :Debug.Str(string("Steady"))
          10..159    :Debug.Str(string("Rising slowly"))
          160..359   :Debug.Str(string("Rising"))
          360..600   :Debug.Str(string("Rising rapidly"))
          600..9999  :Debug.Str(string("Very rapid rise"))
          Other      :Debug.Str(string("Error"))
        DEBUG.nl
         'Print short-term trend narrative
        Debug.Str(string("1hr :"))
        Case EEPROM.Readlong(T1)
        DEBUG.nl
          'Print instantaneous trend narrative
        Debug.Str(string("inst:"))
        Case EEPROM.Readlong(Ti)
Pri Initialise_EEPROM | p
 'Fill EEPROM with default data
  'if not already filled
  If EEPROM.Readlong(Flag)<>$5555 'check fill flag
    EEPROM.WriteLong(Flag,$5555)
  'get starting minutes and store
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2012-06-04 05:18
    It would be shorter to use loops. For example,
    could be something like
    repeat a from 0 to ?? 'spin syntax a little rusty here
    EEPROM.WriteLong(($9003+a), p)
  • rosco_pcrosco_pc Posts: 473
    edited 2012-06-04 06:18
    Just use, also untested, but I think I have the logic right
    EEPROM.WriteLoNg(R0+hour*4)
    Trend3 := EEPROM.ReadLong(R0+hour*4) - EEPROM.ReadLong(R0 +((hour+21)//24)*4)
    Trend1 := EEPROM.ReadLong(R0+hour*4) - EEPROM.ReadLong(R0 +((hour+23)//24)*4)
    Trendi := EEPROM.ReadLong(R0 +((hour+23)//24)*4)
    And just for argument sake I would have longs start at long boundaries, so
    R0=$9000
    Not sure if it is needed, but old habits die hard :)
    edited 2012-06-04 07:55
    I think rosco has the right idea of using an algorithm to determine the EEPROM location.
    Your algorithm ought to be able to handle any number of hours. From two to thousands (assuming you have the memeory to store the data).
    You might want to include some out of bound checks if you make the number of samples easy to change (by changing a constant at the beginning of the program).
  • g3cwig3cwi Posts: 262
    edited 2012-06-07 06:07
    Hi Rosco and Duane
    Just got around to implementing these changes. Thanks for the ideas.
    Cheers
    Richard
    edited 2012-06-07 06:33
    Okay, Rosco - your ideas worked fine (just one small changed needed to the Ti test). I have now used the same idea to streamline the code and there are no repeated blocks or lengthy tests now. It is running under testing now and I will see how it works over the next few hours. There is just one further part that I could do with advice on:
    This is in the CON method: is there a more elegant way of defining these locations?
      R0   = $9000
      R1   = $9004
      R2   = $9008
      R3   = $900c
      R4   = $9010
      R5   = $9014
      R6   = $9018
      R7   = $901c
      R8   = $9020
      R9   = $9024
      R10  = $9028
      R11  = $902c
      R12  = $9030
      R13  = $9034
      R14  = $9038
      R15  = $903c
      R16  = $9040
      R17  = $9044
      R18  = $9048
      R19  = $904c
      R20  = $9050
      R21  = $9054
      R22  = $9058
      R23  = $905c
      Time = $9060
    Cheers
    Richard
  • Mike GMike G Posts: 2,702
    edited 2012-06-07 06:38
    How about using pointer math.
    GetEepromAddr(idx)
      return $9000 + (idx * 4)
    edited 2012-06-07 06:55
    Hi Mike
    Remember that I am very dim. I guess that is a method? i.e.
    Pub GetEepromAddr(idx)
    If so, I am guessing that you don't think that I need to define the locations in the Con block at all?
    Or have I missed the point entirely?
    Cheers
    Richard
    [Edit - I am begining to think that is exactly what you mean. There is really no need to define the locations]
    edited 2012-06-07 07:10
    New and more elegant code:
    {A trending barometer using the Parallax
    Barometer modules and a generic Real Time
    Clock module.
    Uses a serial 4 x 20 serial LCD to display:
    - Current Pressure
    - 3 hour tend (narrative)
    - 1 hour tred (narrative)
    - instantaneous trend (narrative)
    By Richard Newstead, G3CWI, June 2012}
    CON
      'Define some EEPROM storage locations
      'Note $9000 to $905C reserved
      Time = $9060
      T3   = $9064
      T1   = $9068
      Ti   = $906c
      Flag = $9070
    OBJ
      rtc   : "DS1302_full"
    Var
    PUB Start | temp 'Start everything running
      Initialise_EEPROM
      Main
    Pub Main | p
      DEBUG.CLS
      DEBUG.Cursor(0)
      Display
      repeat
            If minute := 0 and second :=0
              EEPROM.WriteLong($9000+hour*4,  p)
            'Using obs, calculate 3 hour trend and store
            Trend3 := EEPROM.ReadLong($9000+hour*4) - EEPROM.ReadLong($9000 +((hour+21)//24)*4)
            'Using obs, calculate 1 hour trend and store
            Trend1 := EEPROM.ReadLong($9000+hour*4) - EEPROM.ReadLong($9000 +((hour+23)//24)*4)
            'Using obs, calculate instantaneous trend and store
            Trendi := p - EEPROM.ReadLong($9000 +((hour+23)//24)*4)
          Display
          DEBUG.cls
          DEBUG.nl
            Trend_Test(EEPROM.ReadLong(T3))
            Trend_Test(EEPROM.ReadLong(T1))
            Trend_Test(EEPROM.ReadLong(Ti))
    Pri Initialise_EEPROM | p, Loc
         Repeat Loc from $9000 to $905c step 4
            EEPROM.WriteLong (Loc, p)
    Pri Trend_Test (Trend)
      Case Trend
      Debug.nl
    Thanks for all the help - this has been a very useful learning exercise.
    Added to OBEX:http://obex.parallax.com/objects/868/[URL="http://obex.parallax.com/objects/868/]"]
    [/URL]
    Cheers
    Richard
    Good that it worked :)
    You can make some optimizations, limiting the number of reads/writes from/to the EEPROM:
    1) Read the needed values first, and then calculate the trends.
    2) Trend1 and Trend3 only need to be re-calculated and written when you write the new hourly value.
    like this:
    	hour1 := EEPROM.ReadLong($9000 +((hour+23)//24)*4)
            EEPROM.WriteLong(Ti,p-hour1)
    		hour3  := EEPROM.ReadLong($9000 +((hour+21)//24)*4)
    		EEPROM.WriteLong(T3,p-hour3)
    		EEPROM.WriteLong(T1,p-hour1)
