VGA using 8 bits RRGGBBII + HS & VS = 10 pins - Discussion....
Cluso99
Postedit- RRGGBBII where ii is intensity, seems the better option from the discussion below. Therefore I have changed the title from RRRGGGBB.
I am thinking that there is no more hub space taken using 6bit VGA versus 8bit VGA. I know it uses 2 more pins (or 1 with and XOR gate and 4 resistors - Phils circuit).
Has anyone tried this and does it produce a better display ???
Which color is best to be left at 2 bits (R,G or
I am thinking of putting this on an upcoming pcb so I am interested in comments. I have the pin(s).
Andy
I attached a GIMP palette which has the proper colors.
How come you have spare pins? Unfamiliar waters, surely?
I think it was Phil who said a long time ago that it should be possible.
One trick is going to be getting gray scale to come out right using a resistor DAC. I figured out how to do it for a 24-bit DAC, but it might be harder with resistors...
Yes, Bill implemented a HiRes video driver using RRRGGGBB for the Morpheus. Catalina supports this video mode. The resulting shortage of pins and Hub RAM on that CPU is not really a problem with Catalina because you can run your VGA display on one CPU and your other drivers (keyboard, mouse, SD card etc) on the other CPU. Your actual program can run on either CPU.
Ross.
Lawson
red and blue are about the same, but red usually gets the second bit.
Another option is RRGGGGBB. But, in the 80's people spent a lot of time on this and someone decided RRRGGGBB is best...
There was actually a computer system that used this mode (according to wikipedia anyway).
One possible glitch in this process is the generation of HSync and VSync. One thing I discovered when doing slides with a separate inset is that timing the overlay video with a system-clock offset from the video-generated syncs results in a shimmering effect as the pixels jiggle back and forth. The same would also be true for generating the syncs from the system clock, since it would not be synchronized to the video PLL. What might work is to switch vcfg back and forth between the color pins and the sync pins. This will restart the internal counters, but at least they'll be sync'd to the video PLL.
Do you think it is worth the trouble to use the 8 bits ??? Unless the VGA is much improved, there is no point in making non-standard video.
A quick question about the HS and VS... Does the HS activate during the VS ? Is the VS and HS normally a low going pulse or high going pulse ? (yes, I could look at the code but you probably know this) - I just want to be sure the XOR works on 1 pin.
Next question is what drive is required for the HS and VS ? ie. with your XOR circuit of 10K+5K+5K+10K can one of HS or VS be driven from the first 10K/5K junction without buffering?
With regard to the shimmering, why does using multiple cogs for generating alternate lines not have this problem (or does it)?
The advantages I can see for 8 bits, per the RRGGBBII scheme are the 16 gray levels and the subtle, non-saturated mid-tones, which would work well for skin tones and other natural shades. Unfortunately, my color compression would not work with it, since I need the extra two bits for indexing.
I've only worked with 640x480, and for that the syncs are negative-going. For some other resolutions, they're positive-going.
Regarding the buffering, I don't think a 5K source impedance is adequate. The syncs, in the XOR case, should be buffered.
Regarding the shimmering, multiple cogs probably begin by syncing their video PLLs to a common pin and remain in sync from there on. The shimmering occurs when two, non-synchronized clock sources are used for combining image signals, i.e. the video PLL and the system clock.
keep the same cog, PLLA etc, or does rewriting vcfg reset the plla?
That's what I was referring to when I suggested changing vcfg. That register is not double-buffered to sync with waitvid, so every change to it is immediate. Changing it might restart the internal video counter. But I think it's the best hope for a steady image.
1) use the I - bits and NAND gates to generate the sync signals. The I bits are synchronized to the pixel clock, so H and V will be also. Not sure if it is allowed to have a little voltage on R,G,B while the sync signales occure.
2) Only 128 colors and 8 gray levels. Then you can use the 8th bit for the H sync signal, which is the critical one. V sync is just another pin, not in the same VGA pin group. This would need only 3 additional resistors to the standard circuit.
Andy
If using two gates, then your option 1 seems likely to be the safest solution as shimmering should/would not be a problem here. However, because of feedback between the resistors, this may cause problems. So I will need to check this out, as I0 and I1 may need buffering/gating as well.
This should be compatible to the existing VGA drivers if you don't connect the 9th pin (Sync Enable). If the Sync Enable is pulled low by a 9th Prop pin you can use I0 and I1 for 256 colors according Phils circuit.
Andy
No, unfortunately it's not allowed. I ran into this problem when I wrote my VHDL VGA driver. You have to zero the colors while the VSYNC signal is returning to the top of the screen.
I can understand why blanking during VSYNC is desirable with a CRT display, since you don't want a visible retrace. But is it also necessary with an LCD?
BTW Using 74LVC00 & 74LVC08
There would be a small amount of crosstalk between the R,G & B via the I bits and the resistors.
I tried it on an HP2509 LCD and some other LCD display, and both rejected the signal unless I set the RGB channels to 0. The displays would receive the signal (indicated by the backlight being on, and the display not going into sleep mode with the orange LED), but they wouldn't display an image. I don't know if all LCDs need it, but it took me two days of debugging to figure this one out.
I based most of my design off of this document from Digilent, page 15: www.digilentinc.com/Data/Products/NEXYS3/Nexys3_rm.pdf Note that nowhere does it mention anything about zeroing the RGB channels during syncs.
As a side note, I think writing a VGA driver in VHDL is one of the most rewarding classroom experiences for VHDL there is. It's a bunch of fun to take a million unmolded gates and to create something uniquely yours. Much more fun than making an adder or memory.
Maybe something like this can be used for 8-bit Atari emulation....
Your circuit won't work, I'm afraid. When /sync is high, P16..P17 affect both sync and color. When /sync is low, they affect neither. What is needed is a circuit like this (yours with an added NOT function):
The important thing is that with P16..P17 low, changing the SyncEn input does not change either the color or the sync outputs. That way, it can be applied asynchronously to the video PLL. The other thing that's important is that neither I-MSB nor I-LSB suffer more than one gate delay between input and output. And those gates have to be really fast, since one pixel time is less than 40 ns. To avoid skew, it may be necessary to buffer the RGB outputs with the same logic family as the gates.
Most monitors will use the blanking period to do a "Black level clamping operation" so anything other than 0 Volts will confuse this.
