Porting Atmel C to PASM ... — Parallax Forums
MacTuxLinMacTuxLin Posts: 821
edited 2012-05-31 01:33 in Propeller 1
Hello All,
After getting this chip (AT88SA102S) & mounted it on my board, I realised I had problems with this chip despite thoroughly reading the datasheet, which I later found it had missed out an important sleep_to_wake time that I discovered in the source code. But still, does not seems to solve the problem. Basically, I'm trying to get a response from the chip to ensure my timing are OK but it just did not initiate a t_start.
To access this chip, I need to send a Wake Token, followed by a Transmit Flag with a sleep_to_wake time in between & I ought to get a $11 in return. Please excuse the mess as they are still work-in-progress. I must have err somewhere.
As always, thanks a lot.
' ### AT88SA102S ### - (New 29 May 2012)
' input:  declared inside
' output: 1 byte, suppose to reply from Wake Token signal
_at_newWaketoken        mov     bitCnt, #8              ' read an 8-bit byte
                        'Set pin as output
                        mov     dira, dataMask
                        mov     value, #$F0     ' Set value
                        mov     cnt, cnt
                        add     cnt, #9
                        'Send Wake Signal
:_at_sendWakeAgain      waitcnt cnt, write_t_szhilo
                        or      dira, dataMask  'Low
                        andn    dira, dataMask  'High
                        shr     value, #1 wc
                        muxnc   dira, dataMask            ' low/high
                        waitcnt cnt, write_high_short
                        andn    dira,dataMask            ' low/high
                        djnz    bitCnt, #:_at_sendWakeAgain
                        '* Sleep-Wake Delay (30 May 2012), found this in Atmel's code for AT88SA102S
                        waitcnt cnt, sleepWake_Delay
                        'Send Transmit Flag
                        mov     value, #$88
                        mov     bitCnt, #8
:_at_newTransmit        waitcnt cnt, write_t_szhilo
                        shr     value, #1 wc
                        djnz    bitCnt, #:_at_newTransmit
                        waitcnt cnt, #0
                        'Set pin as input
                        andn    dira, dataMask
                        'Read byte from AT88SA
                        mov     shiftCnt, #32           ' get shift count
                        sub     shiftCnt, bitCnt
                        mov     cnt, cnt
                        add     cnt, #9
:_at_newReadBlock       waitcnt cnt, readByte_LH  'readByte_HighLong
:_at_newReadBitLow      test    dataMask, ina wz        ' Should be Low
              if_nz     jmp     #:_at_newReadBitLow     ' Waiting for start signal (low) from IC   <--- !!!! STUCK HERE !!!!
                        add     cnt, readByte_LH
:_at_newReadBitHigh     test    dataMask, ina wc
              if_nc     jmp     #:_at_newReadBitHigh
                        ror     value, #1
                        waitcnt cnt, readByte_HighLong
                        'Check to make sure it is High
:_at_newReadMakeSure    test    dataMask, ina wc
              if_nc     jmp     #:_at_newReadMakeSure
                        djnz    bitCnt, #:_at_newReadBlock
                        shr     value, shiftCnt
                        'Reset pin as output
                        mov     dira, dataMask          ' Bring up again
_at_newWaketoken_ret
_at_new_ret             ret
'-------------------- constant values -----------------------------------------
wake_whi                long    12_000           '3.2ms, Min is 2.5ms but since _delay is multiple of 4 so use 3.2ms
t_timeout               long    40_000          'Min is 45 msec
'--- New --- (29 May 2012)
wake_low                long    6_400           'Try 80 usec, min is 60 usec in datasheet
wake_high               long    200_000         'Try 2.5 msec, min is 2.5msec in datasheet
write_t_szhilo          long    347             '4.34 usec (t_start, t_zhi, t_zlo) all shares the same value.
write_high_long         long    2_425           't_bit - t_start - t_zhi = 30.32 usec
write_high_short        long    2_079           't_bit - t_start - t_zhi - t_zlo = 25.98 usec
readByte_LH             long    480             'Both Low & High is 6 usec (typ value), min 4.6 usec, max 8.6 usec
readByte_HighLong       long    2_880           '36us ,Read from 102s remaining time after last low in logic 0
sleepWake_Delay         long    135_040         '2_000 usec - 8-bytes * 39 usec = 1_688 usec = 135_040 ticks
I'm trying to port the same flow as these shown over to PASM (full source attached)
    // Setup the communication timer
    TCCR1B &= ~(_BV(CS12) | _BV(CS10)); // clock source disabled
    // Clear the counter registers
      TCNT1 = 0;
    // Clock source enabled. We use a pre-scaler value of 64
    TCCR1B |= (_BV(WGM12) | _BV(CS11) | _BV(CS10));
    // Clear the timer compare flag.
    TIFR1 |= (1 << OCF1A);
    // Set the timer to time the entire packet process
    //   (Wake+WakeDelay+Transmit+Command+MacOut+ExecutionDelay+Transmit+TurnaroundDelay+Transmit+DigestOut)
    OCR1A = MAX_MAC_TIME;
    // Send the wake token
    SendByte(WAKE_TOKEN);
    // Mandatory sleep->wake delay (not in spec)
    while (TCNT1 < SLEEP_TO_WAKE_TIME)
    // Send transmit flag
    SendByte(FLAG_CLIENT_TRANSMIT);
    // Get the wakup "SYNC" packet
    if (!ReceivePacket())
        // Send the command flag + command payload + transmit
        for (index = 0; index < sizeof(cmd_MAC); index++)
            SendByte(cmd_MAC[index]);
        // Wait tExec, send transmit flag
        while (TCNT1 < MAC_COMMAND_TEXEC_WAIT)
        // We can now wait here until the chip responds or the overall timer
        // fires.
        returnVal = ReceivePacket();
    // Send Sleep flag
    SendByte(FLAG_SLEEP);
    return returnVal;
sa10.c 10.7K
  • pedwardpedward Posts: 1,642
    edited 2012-05-30 13:08
    As an aside, I wrote a SHA-256 algorithm in PASM, so if that's all you are using this for, you could simply reuse that code. It's the code that was written for the P2 ROM code.
    edited 2012-05-30 13:09
    Have you put a scope or logic analyzer on the lines to see if the timing is correct, per the constants? You could use the Prop itself as a LA with 1 COG doing the timing analysis and dumping the data over a serial connection. MY experience has been that when you write "correct" code, the culprit is in the hardware and you have to rewrite your code to compensate.
  • MacTuxLinMacTuxLin Posts: 821
    That's right, I'll probe the Atmel board ... Thanks pedward.
