Here is a real good deal at Electronc Goldmine
super bright (280 LED) light panels
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17973
They run on 24 volts @ 420 milliamps of power and they are real bright at 100 milliamps which is about 17 volts they glow a little
I bought two already and bought two more today
If want to buy some do not wait long because they had the same type a month or so ago those had 60 to 80 bad LED on the board for $18.00 they where gone in about two weeks I miss out on them
From the picture, these are cool white LEDs, so the light will appear fairly cold. If you want a more natural color balance you'll need to add a filter over it.
For a bench worklight, I think a fluorescent tube lighting fixture may provide the best illumination. Those have decent efficiencies, too.
-- Gordon
They are very bright close up maybe 3 to 4 feet away so if you have long work table you might need 3 or 4 of them to have good lighting
" A 60W bulb delivers about 800-900 lumens in a 360 degree circle. These put out that easily," but LED panels are very directionally down from the panel to the table
