What happens when you exceed the current rating on a voltage regulator?
I have a 5 volt regulator in the TO-92 case style which has a 150 ma current rating. While I don't plan to draw more than that, what happens when you do? I'm hoping a graceful failure or the device getting hot rather than instant magic smoke dispersal.
I am using the TL750L05CLP from TI and I found the data sheet http://www.ti.com/lit/ds/symlink/tl750l05.pdf and it does have over current thermal protection. I plan on putting 9 volts in from a battery, so I won't go over voltage. The microcontroller definitely won't go over the current budget, but I will be connecting a few sensors (IR LED wheel encoders, a Ping, and an IR line following module). Which is why I was concerned. My servos will have a separate power supply, so no worries there.
Robert
Absolutely. They always get way hotter than I like before the thermal shut down triggers.
A: http://forums.parallax.com/attachment.php?attachmentid=92496&d=1336959728
@erco - Unfair. That's a picture of a transistor (or maybe half a transistor), not a regulator that has current and thermal limit protection.
erco does not play fairly with others...
These were 6 diodes and some transistors in this circuit. After this accident, all transistors have 2 legs only, Third legs disappeared in magical way.
All 6 diodes exploded and emitted a lot of red light. These were not LEDs,
A lot of magic smoke emerges...
Peter
Which is often used in regulators so erco has a point. If the 3 terminal regulators did not have built in over current/temperature protection they might end up like that.
At least some one got my humor
Martin desmoking Eh ..
Worse I have seen is some one plugged a LM7805 in breadboard to a line cord and plugged it in .
He had tantalum caps on the input and output that became very fast moving projectiles .
What was there was in a cycle new forms of carbon and rare Gasses .. And one VERY shook up Freshman.
Peter
