What happens when you exceed the current rating on a voltage regulator? — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2012-05-20 16:54 in General Discussion
I have a 5 volt regulator in the TO-92 case style which has a 150 ma current rating. While I don't plan to draw more than that, what happens when you do? I'm hoping a graceful failure or the device getting hot rather than instant magic smoke dispersal.
    edited 2012-05-17 10:21
    The old standby 7805 linear series claims to have thermal shutdown protection, but they can get plenty hot in normal use. Which regulator RU using?
    edited 2012-05-17 10:59
    All single chip voltage regulators have overcurrent protection and thermal shutdown. Their datasheets usually provide graphs showing how the device responds to heat. Usually, they can get quite hot to the touch at the point where the shutdown process kicks in. Some regulators are not protected against reverse voltages (although many are) and all regulators will let the magic smoke out (and maybe some flames too) if subjected to high enough voltage spikes with enough energy available. Believe the datasheet when it says "Absolute Maximum".
    edited 2012-05-17 11:20
    OK thanks.
    I am using the TL750L05CLP from TI and I found the data sheet http://www.ti.com/lit/ds/symlink/tl750l05.pdf and it does have over current thermal protection. I plan on putting 9 volts in from a battery, so I won't go over voltage. The microcontroller definitely won't go over the current budget, but I will be connecting a few sensors (IR LED wheel encoders, a Ping, and an IR line following module). Which is why I was concerned. My servos will have a separate power supply, so no worries there.
    edited 2012-05-17 11:29
    150mA seems pretty tiny when you start adding up all the extra's that you want to power from it. I'd prefer to have a little more of a safety margin on that part and not try to work it at the limit by default. There should be plenty of small 5V regulators that can easily put out up to 500mA which may be a better option.
    Robert
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-05-17 12:10
    Absolutely. They always get way hotter than I like before the thermal shut down triggers.
  • tobdectobdec Posts: 267
    edited 2012-05-17 12:45
    I just bought a surplus of 5amp regulators to use on all my projects...that way I never have to worry no matter what im doing.
    edited 2012-05-17 16:46
    Q: What happens when you exceed the current rating on a voltage regulator?
    A: http://forums.parallax.com/attachment.php?attachmentid=92496&d=1336959728
    edited 2012-05-17 19:38
    That is definitely a case of catastrophic magic desmoking.
    edited 2012-05-17 20:07
    @tobdec - Remember that a 5A regulator will supply up to 5A into a short circuit (as long as the unregulated supply can provide that). Make sure to have a fast acting fuse in the circuit. You might have a large heatsink as well if you plan to actually use much over 1A. Even a 2V drop across a regulator at 5A will produce 10W of heat that has to be dissipated.
    @erco - Unfair. That's a picture of a transistor (or maybe half a transistor), not a regulator that has current and thermal limit protection.
    edited 2012-05-17 20:14
    Yup Mike ive been to that play before.....I use fuses on like everything!
    edited 2012-05-17 20:21
    Mike Green wrote: »
    erco does not play fairly with others...
  • pik33pik33 Posts: 2,409
    edited 2012-05-19 02:06
    In the ancient times I accidentally powered an electronic circiit directly from 220V AC.
    These were 6 diodes and some transistors in this circuit. After this accident, all transistors have 2 legs only, Third legs disappeared in magical way.
    All 6 diodes exploded and emitted a lot of red light. These were not LEDs,
    A lot of magic smoke emerges...
    edited 2012-05-19 18:56
    Yea a NPN .. a TIP120 . a VERY common device too..
    Peter
    edited 2012-05-19 23:12
    Peter
    Which is often used in regulators so erco has a point. If the 3 terminal regulators did not have built in over current/temperature protection they might end up like that.
    edited 2012-05-20 07:59
    No sir, that is a PNP TIP125... :smile:
    Ttailspin wrote: »
    At least some one got my humor :)
    Martin desmoking Eh ..
    Worse I have seen is some one plugged a LM7805 in breadboard to a line cord and plugged it in .
    He had tantalum caps on the input and output that became very fast moving projectiles .
    What was there was in a cycle new forms of carbon and rare Gasses .. And one VERY shook up Freshman.
    Peter
