Yeah!!! it's all under one roof. The Eddie and the PC Marriage time
Just received the new HP Pavilion dv6. It looks better than it does in it's pictures. Almost a shame to give it to a Robot but.....that's what it was bought for. Going through it and trashing all the HP stuff and anything else that might get in the way. I just want to plug it all in and play but I know that the ground work has to come first.
To get rid off junk on a new machine, I use PC Decrapifier. Looks like they have a version for Windows 7 now.
Jim
Deleting Windows??
Kidding! It amazes me what all they can cram onto a PC - actually, our work images are the worst....and we can't get rid of any of it!
This should be exciting, you have some very interesting plans for putting this all to good use!
You're probably better off running the Laptop on AC power during the configuration and development since it won't eat up battery power. If you eventually want to power everything from the Main Eddie battery then you could look for one of the laptop DC/DC adapters meant for charging and running the laptop on the road. I'm using one of those on my large robots and it works well.
Robert
Jim
HP doesn't seem to ship the recovery media any longer but you can call them and request a copy. If you just bought the system they will usually send you a set for free. Otherwise it usually runs about $10.60 for a recovery set of media. I purchased a set for each of the HP systems that I own and would recommend getting a set right from HP as soon as you can.
Robert
Sure, you could charge it and run the robot at the same time - just put it on top of a couple of books. Those sealed lead acid batteries are very flexible in this way. If there's ever a problem I'd gladly provide replacement parts for no charge. Go for it, have fun! Ken Gracey
Now if I can find out if I wired the encoders correctly all would be great!
