Store ID tag numbers to one variable?
Luis_P
The project I'm working on reads the unique serial number on FOB KEY tag. The code use an array to SERIN one number at the time and DEBUG on screen . I need to combine all the numbers EX: 3501D5BDE2 and temporary store into one Variable. I want to do that so later in my code I can debug the names of ID holders, EX: IF 3501D5BDE2 THEN DEBUG "John Smith"
Main:
DEBUG "Ready..." ' Read unique ID from EM4102 read-only tag
Read_Legacy:
SEROUT RFID_TX, Baud, ["!RW", RFID_ReadLegacy]
SERIN RFID_RX, Baud, [STR buf\12] ' Get header and data
IF buf(0) <> $0A THEN Read_Legacy ' If we don't receive the correct header, keep trying until we do
FOR idx = 1 TO 10 ' Display the data (ignore final \r byte sent by the reader)
DEBUG buf(idx)
NEXT
DEBUG CR
DEBUG STR buf\12 '<= THIS DISPLAY ALL THE NUMBERS FROM THE ID TAG
PAUSE 1000
goto Main
Main:
Read_Legacy:
DEBUG buf(idx)
NEXT
DEBUG CR
PAUSE 1000
goto Main
Is possible to use RW tags and instead of a numbers store a name in the tag? so that way the tag reads a person name?
