PropBoe with lots of storage
I had ordered a 32gb uSD card for something else but gave it a try using Kye's driver on the PropBoe. I was going to display bytes free but the Prop can't easily display a number that high. The card came preformatted with fat32 and has 31,902,400,512 bytes storage. Attached is a picture of the Parallax serial terminal after running this program. I had already transfered some .txt files to it on my computer. That is a lot of storage and that card found a new home with my PropBoe!
Con _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 DO = 22 CLK = 23 DI = 24 CS = 25 Var Obj io : "parallax serial terminal" sd : "sd-mmc_fatengine" Pub Init | a, b, c io.start(115200) waitcnt(clkfreq*2+cnt) if sd.fatEngineStart( DO, CLK, DI, CS, -1, -1, -1, -1, -1) sd.mountpartition(0) io.str(string("Partition mounted!",13,13)) else io.str(string("Problem starting fat engine",13)) error a := sd.partitionusedsectorcount("F") b := sd.partitionbytespersector c := sd.partitionfreesectorcount("F") io.str(string("File system ",11)) io.str(sd.partitionfilesystemtype) io.str(string(13,"Used partition sectors ",11)) io.dec(a) io.str(string(13,"Bytes per partition sector ",11)) io.dec(b) io.str(string(13,"Current free partition sectors ",11)) io.dec(c) io.str(string(13,13,"Total bytes used ",11)) io.dec(a * b) sd.unmountpartition Pub error repeat
(512 bytes per sector * 62283712 sectors) + 13139968 bytes = 31902400512 /1024 / 1024 / 1024 = 29GB
What numbers did you get - bytes per sector, used partition sectors, free partition sectors?
