PropBoe with lots of storage
ratronic
I had ordered a 32gb uSD card for something else but gave it a try using Kye's driver on the PropBoe. I was going to display bytes free but the Prop can't easily display a number that high. The card came preformatted with fat32 and has 31,902,400,512 bytes storage. Attached is a picture of the Parallax serial terminal after running this program. I had already transfered some .txt files to it on my computer. That is a lot of storage and that card found a new home with my PropBoe!
Con
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
DO = 22
CLK = 23
DI = 24
CS = 25
Var
Obj
io : "parallax serial terminal"
sd : "sd-mmc_fatengine"
Pub Init | a, b, c
io.start(115200)
waitcnt(clkfreq*2+cnt)
if sd.fatEngineStart( DO, CLK, DI, CS, -1, -1, -1, -1, -1)
sd.mountpartition(0)
io.str(string("Partition mounted!",13,13))
else
io.str(string("Problem starting fat engine",13))
error
a := sd.partitionusedsectorcount("F")
b := sd.partitionbytespersector
c := sd.partitionfreesectorcount("F")
io.str(string("File system ",11))
io.str(sd.partitionfilesystemtype)
io.str(string(13,"Used partition sectors ",11))
io.dec(a)
io.str(string(13,"Bytes per partition sector ",11))
io.dec(b)
io.str(string(13,"Current free partition sectors ",11))
io.dec(c)
io.str(string(13,13,"Total bytes used ",11))
io.dec(a * b)
sd.unmountpartition
Pub error
repeat
zip
33K
(512 bytes per sector * 62283712 sectors) + 13139968 bytes = 31902400512 /1024 / 1024 / 1024 = 29GB
What numbers did you get - bytes per sector, used partition sectors, free partition sectors?
